Gigabyte z97x gaming 5 and Help
127 (0.03/day)
Malaysia Sabah Sandakan
System Name World Tank Blitz
Processor 8700k
Video Card(s) Asus Gtx 770 OC & 1080 TI
Storage Samsung EVO 850 120GB
Audio Device(s) Logitech
Power Supply Cooler Master V750 Fully Modular
Mouse CM Storm Reaper + MM520
Keyboard MasterKey Pro LRGB and XTI
18,438 (2.47/day)
Don't touch the WD Green, it's a pile of crap.
127 (0.03/day)
Processor 8700k
18,438 (2.47/day)
The Samsung drive should be fine.
Toothless
Tech, Games, and TPU!
9,815 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
It'll work. You won't get nvme speeds though.
Source: I had that board.
15,612 (6.81/day)
Midlands, UK
Processor AMD Ryzen 7 7800X3D @ 45 W TDP Eco Mode
Case Corsair Crystal 280X
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
Why is that? The data sheet of the board says there's 1 PCI-e m.2 slot, which I suppose should work at PCI-e 3.0 x4 spec.
OP: That SSD looks awfully slow for a PCI-e nvme drive. I'd choose one with PCI-e x4 interface if I were you - unless you really don't care, and you can get this SSD a lot cheaper than you would others.
Toothless
9,815 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
It's not full NVME. You'll get at most 700-1000MB/s from it. Tried this on multiple Z97 boards and multiple NVME drives.
15,612 (6.81/day)
Midlands, UK
In that case, OP's choice of PCI-e x2 SSD will do, I guess.
Toothless
9,815 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
It was better to use a PCIe to NVME card. I would get closer to native speeds doing that than using the NVME port on the board itself. Still could boot off it too.
127 (0.03/day)
Processor 8700k
Toothless
9,815 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Doesn't matter what you pick. Just get a drive and be done. All M.2 will work.
ixi
1,482 (0.38/day)
Hello guys
Own this board GA-Z97X-Gaming 5 (rev. 1.0) for long time and last night my SSD down
Now in my mind is to get m2 and list as below
Samsung 860 EVO M.2 SATA 250GB
Western Digital WD Green SATA 6Gb M.2 2280 240GB
May i know which one is support my board and which is better ?
Many Thanks
That site looks dodgy as hell. You're from Asia?
Every m.2 ssd will work in m.2 ssd slot (unless mobo aib is dumb and messing things up). Only thing you need to check is lenght on m.2 drive. Check mobo size support for m.2.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Wow, the specs and manual don't even say what bandwidth that slot is
It could be PCI-E 2.0 x2 for all we know (edit: that is standard for Z97, with some boards making it 2.0 x4 if you disable SATAe)
Other Z97 boards state it's a "10Gb NVME slot" which is 1.2G5B/s max, which on some boards can be doubled if you disable SATA Express ports (or certain SATA ports) in the BIOS
127 (0.03/day)
Processor 8700k
Oh ok , My bad and thanks for input bro
Yes bro :)
Actually i am nub about this so need mentor to help me and many thanks ya
Hugis
844 (0.15/day)
Spain(Living) / UK(Born)
System Name Office / Gamer Mk IV
Processor i5 - 12500
Motherboard TUF GAMING B660-PLUS WIFI D4
Cooling Themalright Peerless Assassin 120 RGB
Memory 32GB (2x16) Corsair CMK32GX4M2D3600C18 "micron B die"
Video Card(s) UHD770 / PNY 4060Ti (www.techpowerup.com/review/pny-geforce-rtx-4060-ti-verto)
Storage SN850X - P41Plat - SN770 - 980Pro - BX500
Display(s) Philips 246E9Q 75Hz @ 1920 * 1080
Case Corsair Carbide 200R
Audio Device(s) Realtek ALC897 (On Board)
Power Supply Cooler Master V750 Gold v2
Mouse Cooler Master MM712
Keyboard Logitech S530 - mac
Still battling onwards with my Z97(see sig) this is what i get with nvme in m2 slot(win 11)
127 (0.03/day)
Processor 8700k
mean by disable ?
blur at here :(
Mussels
58,412 (7.78/day)
Oystralia
mean by disable ?
blur at here :(
What do you mean?
Some boards let you get higher bandwidth by disabling other features in the BIOS. Yours may not.
127 (0.03/day)
Processor 8700k
Thanks for guys for your all input .
