GIGABYTE's 2021 AORUS Gaming Box eGPU Packs RTX 3080 Ti, Liquid Cooling
47,477 (7.50/day)
The 2021 GIGABYTE AORUS Gaming Box external GPU was debuted late last week. It introduces many firsts for a market less addressed this generation, particularly due to the GPU shortage. The lineup debuts with a model based on NVIDIA's flagship GeForce RTX 3080 Ti, and introduces a liquid-cooling. The box uses an all-in-one, closed-loop liquid cooler to tame the RTX 3080 Ti, using a 240 mm x 120 mm radiator and a pair of 120 mm fans located inside the box, while additional fans ventilate the rest of its innards.
For all its might, the card is bound to be bottlenecked by its interface—a single 40 Gbps Thunderbolt 3 connection that gives the GPU the equivalent of a PCI-Express 3.0 x4 interface. Our RTX 3080 non-Ti PCI Express Scaling article shows that the GPU loses 12% performance on PCI-Express 1.1 x16 (comparable bandwidth to PCIe 3.0 x4). Other features of the AORUS Gaming Box include a USB 3.0 hub, and addressable RGB lighting that you can control using the RGB Fusion software. The company didn't reveal pricing or availability, but one can expect a roughly $300-400 markup over whatever the running rate of an RTX 3080 Ti these days, is. GIGABYTE is expected to carve out more Gaming Box products based on the same chassis, but using different GPUs.
43,482 (6.76/day)
Let me guess proprietary?
Emerald_x86
2 (0.00/day)
A thunderbolt 3 controller does not provide the bandwidth of an x4 3.0 link (32Gbps) to an eGPU. It only allocates 22Gb to the PCI Express traffic.
3,549 (1.18/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
Okay why would anyone buy this instead of a mini-ITX PC? this looks about the same size as CoolerMaster NR200 case.
752 (0.44/day)
System Name Main PC
Processor AMD Ryzen 9 5950X
Motherboard ASUS X570 Crosshair VIII Hero (Wi-Fi)
Cooling EKWB X570 VIII Hero Monoblock, 2x XD5, Heatkiller IV SB block for chipset,Alphacool 3090 Strix block
Memory 4x16GB 3200-14-14-14-34 G.Skill Trident RGB (OC: 3600-14-14-14-28)
Video Card(s) ASUS RTX 3090 Strix OC
Storage 500GB+500GB SSD RAID0, Fusion IoDrive2 1.2TB, Huawei HSSD 2TB, 11TB on server used for steam
Display(s) Dell LG CX48 (custom res: 3840x1620@120Hz) + Acer XB271HU 2560x1440@144Hz
Case Corsair 1000D
Audio Device(s) Sennheiser HD599, Blue Yeti
Power Supply Corsair RM1000i
Keyboard Corsair Strafe RGB MK2
Software Windows 10 Pro 20H2
Ultralight laptop with TB3 + this = extreme portability while still being able to game when at home. All on one computer
And for the price of a GPU + $300-400 that's quite a bit cheaper than going with another secondary full system.
Mussels
Freshwater Moderator
58,413 (7.86/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
plug it into your macbook pro so it can actually do some rendering work
6,208 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Last week at GB HQ - "Prices are going down, quick let's make something that we can charge people extra for!"
3,549 (1.18/day)
Processor 9800X3D
Software win11
yeah except that can I build a mini-ITX PC with 11700F + 3070/3070Ti for the same price and it would outperform this eGPU hooked to the most expensive Ultrabook due to the higher TDP CPU.
The one eGPU that make sense to me is the Asus Flow X13 where you can carry the eGPU along with the laptop in your backback
752 (0.44/day)
System Name Main PC
Case Corsair 1000D
But you can't use that ITX machine as a laptop.
94 (0.02/day)
System Name Thebeast v5
Processor 5800x
Motherboard Gigabyte X570i ITX
Cooling Hyper 212 Black RGB
Memory 16gb Trident Z Royal 4000 CL15
Video Card(s) AMD RX 6900 XT
Storage WD SN850 1TB + 1TB SanDisk Ultra
Display(s) 27" Gigabyte M27q
Case NR200p
Power Supply Silverstone 750w SFX PSU
Mouse Logitech G PRO
Keyboard CORSAIR K65 MINI 65%
Software 10 x64 PRO
Yeah, you would use the laptop as a laptop except with out any of the hassle of messing with cables/docks. Not only that you would now have multiple computers..
752 (0.44/day)
System Name Main PC
Case Corsair 1000D
I can't for the life of me understand what point you're trying to make here. Apologies, I might be a bit of a dumbass as evident by my comment history.
Could you perhaps rephrase it for me?
A positive for some, a negative for others. I don't think that's either a good or bad thing necessarily, so I didn't bother pointing it out. Most people I would assume want to have everything on one machine, but I know other people will curse me out for that and say "keep work and personal stuff separate!!".
94 (0.02/day)
Processor 5800x
Case NR200p
Software 10 x64 PRO
Sorry, that's my bad. I have had a bad experience with a TB3 external GPU dock needing specific cables and also having to reseat the TB cable to get it to work and even when it did work I notice massive dips from using the same card in my rig. I have since moved to an ITX gaming computer and haven't looked back. So maybe my experience doesn't apply to all.
I just don't see the utility in buying a expensive proprietary box just to be able to turn your laptop into a gaming machine when a SFF build takes the same foot print. I also think the whole liquid cooling system is such a waste when it probably wont even preform as good as a regular air cooled desktop 3080 due to the bandwidth bottleneck. I agree with an earlier comment about the ASUS E-GPU that has a 3080 in it being much more interesting (Portable and it has pcie Gen3 8x) and I would have considered it if I didn't already build my ITX pc.
