Going from Intel to AMD
1,177 (0.19/day)
System Name KOV
Processor AMD 5900x
Cooling H100i Cappellix White
Memory Corsair 3600kHz 32GB
Video Card(s) RX 7900XT
Storage Samsung 970 evo 500gb, Corsair 500gb ssd, 500GB 840 pro & 1TB samsung 980pro. M2.SSD 960 evo 250GB
Case Corsair 680x
Power Supply AX1200i Corsair
Software windows 11
Looking for some advice. Would it be advisable for a clean software install when changing my set up from Intel to AMD. I have just changed from i7 7700k to AMD5900x.
13,021 (1.95/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Actually, depending on your current Windows license, you may need to purchase a new Windows license too. Since you are moving from Intel to AMD that means you are changing motherboards too. And new motherboards (unless an exact replacement during a repair action) constitute a new computer. And new computers typically require new operating system licenses. Unless you currently have a full "Retail" license (and the vast majority of users do not), you will need to purchase a new license if you desire to be fully legal. OEM/System Builder licenses are not transferable to new computer under any conditions. Note - I'm just the messenger here. What I believe to be right or wrong is irrelevant.
So to answer you question, you may have to to be fully legal and like Hemminstamp, I would anyway. This is because a new motherboard surely would involved a bunch of new and different drivers. And to ensure the proper drivers are installed as well as preventing a ton of unused drivers and settings being orphaned and left behind in the registry and on your drives, I sure would start from scratch after backing up any personal data I did not want to lose.
qubit
Overclocked quantum bit
17,865 (2.89/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Try it and see. At most it will blue screen.
Bill's licensing issue in his advice will be the main problem here, though. If you have an old W7 or W8 disc, try installing and activating that and then upgrading to W10, which should have you fully activated.
1,491 (0.98/day)
System Name Chip
Processor Amd 5600X
Motherboard MSI B450M Mortar Max
Cooling Hyper 212
Memory 2x 16g ddr4 3200mz
Video Card(s) RX 6700
Storage 5.5 tb hd 220 g ssd
Display(s) Normal moniter
Case something cheap
VR HMD Vive
ive had a computer bee unable to boot going from intel 8th gen to 11th
1,533 (0.40/day)
Grunn
System Name Indis the Fair (cursed edition)
Processor 11900k 5.1/4.9 undervolted.
Motherboard MSI Z590 Unify-X
Cooling Heatkiller VI Pro, VPP755 V.3, XSPC TX360 slim radiator, 3xA12x25, 4x Arctic P14 case fans
Memory G.Skill Ripjaws V 2x16GB 4000 16-19-19 (b-die@3600 14-14-14 1.45v)
Video Card(s) EVGA 2080 Super Hybrid (T30-120 fan)
Storage 970EVO 1TB, 660p 1TB, WD Blue 3D 1TB, Sandisk Ultra 3D 2TB
Display(s) BenQ XL2546K, Dell P2417H
Case FD Define 7
Audio Device(s) DT770 Pro, Topping A50, Focusrite Scarlett 2i2, Røde VXLR+, Modmic 5
Power Supply Seasonic 860w Platinum
Mouse Razer Viper Mini, Odin Infinity mousepad
Keyboard GMMK Fullsize v2 (Boba U4Ts)
Software Win10 x64/Win7 x64/Ubuntu
I'm currently using a windows install on my 3600 rig which was originally made with a 7700k, it works fine. Best practice is to install fresh but generally it should work fine without...
1,177 (0.19/day)
System Name KOV
Processor AMD 5900x
Case Corsair 680x
Software windows 11
I've done it but what was my worry is that there would be old Intel drivers running in the background slowing things down. U did the upgrade for free from 7 to 10 ago I might get a USB version of 10.
Low quality post by Atomic77
534 (0.08/day)
West Bend, Wisconsin
System Name DELL Inspiron 5400 AIO / HP 17 ca1065cl
Processor 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz / Ryzen 5 3500u
Memory 16GB /12GB
Video Card(s) NVIDIA MX 330 / Radeon Vega 8
Storage 1TB +SSD
Display(s) 23.8 inch touch screen 17.3 touch screen
Case DELL AIO / HP LAPTOP
Mouse Dell Wireless /LOGITECH
Keyboard Dell Wireless / HP LAPTOP
Software WINDOWS 11
Hmm Why switch to AMD? isn't like the Intel Core i7 like one of the best processors around today? My DELL is intel core i7 while my almost year old HP Laptop is AMD Ryzen 5.
Low quality post by Hachi_Roku256563
1,491 (0.98/day)
System Name Chip
Processor Amd 5600X
Cooling Hyper 212
VR HMD Vive
and beets intel on almost all fronts
its why they are able to command higher prices
the i7 should beat the ryzen 5 cause that goes up against the i5
can your i7 beat a ryzen 7?
newtekie1
Semi-Retired Folder
28,473 (4.12/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
You don't have to do it that way, just install Windows 10 directly picking the correct version when installing, tell it you don't have a product key. Then when you are loaded into Windows 10 after it is installed, go to the activation area under Settings and you can put the Win7/8 key in there.
tabascosauz
8,108 (2.37/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
It's more than just advisable. There's a quite a bit of difference in how Windows handles old CPUs vs. new CPUs, and a lot of difference in how the Windows scheduler interacts with Intel vs. AMD CPUs. Fortunately, Ryzen 5000 does away with the need for chipset driver power plans, but you certainly don't want Intel ME firmware hanging around on a system that needs AMD's chipset drivers. Kaby Lake did have Speedshift, but AMD CPPC goes much further than that and is much more integral to performance.
If you were upgrading from a 6700K to a 7700K or a 3700X to a 5900X there probably wouldn't be as much reason to clean install (though honestly you always should when upgrading platform hardware).
Windows will probably let you transfer your existing activation easily if you usually log into Windows using your Microsoft account. Just note down what your current computer name shows up as in Windows, do the clean install, then under activation it'll ask which of the licences under your account you want to transfer over. If you don't usually login with your MS account, might have to use Produkey to dig up your *real* Windows key buried in the OS and manually enter that after clean installing.
7,473 (1.77/day)
Welcome to the light (bright?) side, anywho clean install is the best bet ~ switching between Intel & AMD CPUs while possible is going to be a major headache especially with your installation containing files that are unnecessary now, besides a new install is almost always faster. As for the Windows license, have you tied it with a digital (online) MS account? If so it can work with just logging in to your account on the newly installed OS.
1,177 (0.19/day)
System Name KOV
Processor AMD 5900x
Case Corsair 680x
Software windows 11
Thanks guys and knew usb stick containing windows 10 on its way
1,491 (0.98/day)
System Name Chip
Processor Amd 5600X
Cooling Hyper 212
VR HMD Vive
what as far as im awear microsoft does not ship windows on usb
they sell you a key and you download windows?
phill
16,792 (3.43/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
You can always run a driver removal program if you don't fancy installing from scratch although the time it takes to go from no install to installed is only about 15 minutes, that's with a SATA SSD as well, it's pretty quick :)
Just as a thought you could have always grabbed a new SSD/NVME drive for the new setup and just installed from scratch then... And in case anything goes nuts, you have a backup machine and OS in case you need it :)
Google Display Driver Uninstaller, it'll come back with what you need when you look down the list for Guru3D site. Just be sure to boot into Windows in Safe Mode just to make sure everything gets stripped out.
Hope that helps a little :)
Mussels
Freshwater Moderator
58,413 (7.97/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
What kind of question is that?
You know there are hundreds of i7's with all different performance, and dozens of ryzen 5s?
Vague blanket statements like "i7 is best" is absolutely not how tech works
3,252 (1.02/day)
Buenos Aires
System Name Ryzen Monster
Processor Ryzen 7 5700X3D
Software Windows 11 Start 11
Under those circumstances a clean install every time and if you're worried about activation, old Win 7&8 keys will still do the trick.
That way you end up with a virgin install, the way it's meant to be with such a huge hardware change.
2,866 (2.10/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
i have a drive that was cloned and used for many different CPUs and motherboards.
normally a fresh install is the way to go but i had a windows installation coming from Haswell over Coffee Lake, Coffee Lake R, Zen 2, Comet Lake, Zen 3 and back to comet lake.
uninstall chipset drivers and ME and you should be completely fine.
Ruru
S.T.A.R.S.
12,548 (2.89/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X @ PBO +200 -20CO
Cooling Arctic Freezer 50, EKWB Vector TUF
Memory 32GB Kingston HyperX Fury DDR4-3200
Storage A pack of SSDs totaling 3.2TB + 3TB HDDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p60
Audio Device(s) Asus TUF H3 Wireless / Corsair HS35
VR HMD Oculus Rift CV1
I personally keep the old install only if I'm going to change to a motherboard which has somewhat a similar chipset, like I did with X470 -> B450. Otherwise it's always a clean install.
And why you need to order a Windows USB key as MS has a tool which downloads and makes a bootable USB stick which has the installation media?
qubit
17,865 (2.89/day)
Quantum Well UK
Keyboard Yes
Good point, I’d forgotten about that and just went old skool lol.
1,177 (0.19/day)
System Name KOV
Processor AMD 5900x
Case Corsair 680x
Software windows 11
Now that sounds like a good idea.
r9
3,300 (0.56/day)
System Name Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck
Processor i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t
Memory 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5
Video Card(s) RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs
Storage 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme
Display(s) 50" 4k TV | Dell 27" |22" |3.3"|7"
VR HMD Samsung Odyssey+ | Oculus Quest 2
Software Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro
Yes.
And for the windows license, back it up first.
I upgraded from i5 6600k/z170 to i7 9700k/Z390 and Windows sorted all the drivers and such no issues at all not even with the Win license.
10 (0.01/day)
Brazil - São Paulo
System Name Windows 10 PRO 21H1 modded by me
Processor AMD A10 7800
Motherboard Gigabyte GA-F2A88XM-D3HP
Cooling Air colled for a while
Memory 2x HyperX 8GB DDR 3
Video Card(s) Radeon RX580 8GB Power Color
Storage CT120BX500SSD1+ ST2000DM008-2FR102
Display(s) 1 Sansung 18,5" LCD + 1 LG 22" LCD
Case Deep Cool Tesseract modified by me
Audio Device(s) Power Amplifier made and developed by me
Power Supply Corsair CX 750M
Mouse Philips wireless
Keyboard Philips wireless
Software severals
Benchmark Scores @SysSoft Sandra 8.9 KPT
yay congrats friend excellent decision:)
Mussels
58,413 (7.97/day)
Oystralia
While i'm against the idea of moving between hardware, one good tip is to 'reboot to safe mode' and then power off before it boots, so the new hardware gets a safe mode boot
