- May 4, 2009
- 1,972 (0.34/day)
- Bulgaria
System Name | penguin |
Processor | R7 5700G |
Motherboard | Asrock B450M Pro4 |
Cooling | Some CM tower cooler that will fit my case |
Memory | 4 x 8GB Kingston HyperX Fury 2666MHz |
Video Card(s) | IGP |
Storage | ADATA SU800 512GB |
Display(s) | 27' LG |
Case | Zalman |
Audio Device(s) | stock |
Power Supply | Seasonic SS-620GM |
Software | win10 |
I decided the prices are finally right to warrant an update and wanted to ask if anyone's done the same on a similar board. I'm going from a 2400G to a 5700G. The part that worries me is that the support for each is in on a totally different BIOS versions and that each version doesn't support the other CPU. Has anyone gone through a similar update on a similar board? If so do you have any tips and tricks or a quick guide? Should I update straight to the latest beta bios?
https://www.asrock.com/mb/AMD/B450M Pro4/index.asp#BIOS
I'm currently on bios version 3.50:
I'm planning on doing the following:
- Update to the latest stable (5.30) while still using the 2400G.
- Shut down, turn off and swap the CPUs.
- Take out the CMOS and wait 2 mins.
- Pray to all the deities that I didn't brick it
- Put everything back together and boot it back up
