GPC PCB beding badly or not
codeuzi03
1 (0.25/day)
Is by gpu PCB bending badly
42,980 (6.72/day)
Yes its leaning, unplug your power supply from the wall, lay case on the side, remove your gpu, loosen your motherboard screws and make sure it is parallel on all 4 sides, tighten back up, then while the case is on its side put gpu in and let it float put the scews in.
