GPU Chamfering,,,
Status
Not open for further replies.
74 (0.06/day)
after lots of testing I can conclude that this will help a lot of you with a lot of random issues.
I chamfer every card I own and sell and NO ISSUES.
display subject
1st gen GT 730
I used silicon on a q tip then polished it to help find the high spots on the gpu die...
I marked the high spots in yellow so u can see what I see...
400 grit sand paper cut a tiny 1 half inch square and gently graze the edge of the gpu die to break off those high spots
BE CAREFUL AND GO SLOW
clean the tiny metal flakes and apply the thinnest amount of thermal paste across the whole chip and reassemble...
perfect temps and perfect junction also no weird glitches and bugs anymore hmmm.
NITRO out
5,213 (0.88/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [Asus TUF GAMING X570-PLUS]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Crucial Pro 3200MHz (32GBx2)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Fanmusic TRUTHEAR IEM, HyperX Duocast]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
This just seems like an incredibly reckless thing to do for extremely small gains.. I did learn what chamfering means tho, so that's a plus.
74 (0.06/day)
"extremely small gains"
you have no info to back that statement up so next time just say its dangerous which is what I said by "BE CAREFUL AND GO SLOW" so actually you should of just said nothing... thank you
try a 6c to 13c junction max float AFTER u do this... 6900xt 3ghz *MICDROP*
5,213 (0.88/day)
How much of those gains is from just reapplying TIM? Reseating the heatsink?
Also semi off topic, your posts I've seen around here you kind of come of like an asshole.
3,984 (1.14/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
He's not wrong.
But, its basically just lapping.
74 (0.06/day)
lapping is one direction,, I do 2 directions..
RX6800 non XT modified 244fps BFV 1440p RTX enabled at 4ms ALL DAY LONG --------
my 3090 rog can do 220fps at 1440p 7ms for "45"min before HEATWASHOUT and frame drop so I would say set and match... game over.
I'm done with these meat sacks. we have a lot of ditches to fill. START DIGGING.
2,830 (2.13/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~1800 Video Games
Status
