- Feb 24, 2023
- 2,600 (4.48/day)
- Russian Wild West
System Name | DLSS / YOLO-PC |
Processor | i5-12400F / 10600KF |
Motherboard | Gigabyte B760M DS3H / Z490 Vision D |
Cooling | Laminar RM1 / Gammaxx 400 |
Memory | 32 GB DDR4-3200 / 16 GB DDR4-3333 |
Video Card(s) | RX 6700 XT / R9 380 2 GB |
Storage | A couple SSDs, m.2 NVMe included / 240 GB CX1 + 1 TB WD HDD |
Display(s) | Compit HA2704 / Viewsonic VX3276-MHD-2 |
Case | Matrexx 55 / Junkyard special |
Audio Device(s) | Want loud, use headphones. Want quiet, use satellites. |
Power Supply | Thermaltake 1000 W / Corsair CX650M / DQ550ST [backup] |
Mouse | Don't disturb, cheese eating in progress... |
Keyboard | Makes some noise. Probably onto something. |
VR HMD | I live in real reality and don't need a virtual one. |
Software | Windows 10 and 11 |
I decided to put all the eggs in one basket.
10% difference and less is considered 0% difference (can you tell if your game is running at 50 FPS or 55 without overlay showing you the numbers?). This is why RX 6600 XT and 6650 XT, and a duo of 6700 XT and 6750 XT are considered the same GPU. Only buy the xx50 if the price difference is negligible (below 30 bucks). Doesn't apply to RX 6950 XT because this GPU is better binned than 6900 XT.
This chart is by all intents and purposes not exhausting and cannot be considered an ultimate guide.
Anything important (naming weirdness and tier shifting, for example, is not important since both AMD and nVidia are doing it to the same extent) I forgot to mention or was incorrect at is appreciated to be fixed.
The main purpose of this chart is mostly to answer the question what GPUs the hypothetical buyer should ignore. To a lesser extent, what they should purchase.
Arguments like "AMD GPUs don't last long, nVidia GPUs run out of memory" and similar stuff will be ignored. At least by me. Moderators' opinions may vary.
Intel GPUs are not on the chart due to their drivers immaturity and overall instability on older systems (yet I admit they had it miles worse a year ago). If you're considering Intel's dGPU you know what you are doing better than I do.
I am not capable of monitoring pricing worldwide. If, say, RTX 4070 is cheaper than RX 7700 XT in your particular country, this is nothing I can do and the former is a no-brainer for you. The chart is for scenarios when relative prices of different GPUs are close to those in the US.
