GPU Die 'Exploding'?!?!
4,213 (0.71/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
So I removed the Heatsink from one of my GPUs that has been having issues (frequent crashes when loaded) and I noticed a pit in the die.
I wondered if it was a manufacturing defect, but then I noticed a similar pit on the heatsink that lines up pretty much perfectly with the pit on the Die.
This is the first time I've removed the heatsink from the card and so the only thing that I can think could have caused this was part of the GPU die exploding! The pit on the heatsink isn't insubstantial and it can be clearly felt when running a finger across it.
Has anyone else experienced a problem like this with their GPU?
43,485 (6.76/day)
Could have been a defect or pitting corrosion
Toothless
Tech, Games, and TPU!
9,738 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Dude if your die exploded, there would be no die.
825 (0.43/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
No die exploding found, disappointed.
4,213 (0.71/day)
Vietnam
On both the gpu and heatsink?
The only thing that was in contact was thermal paste I'm not sure how corrosion would have happened.
Besides the hole in the die is not smooth, it's like part of it popped off.
I've had who cards die on showers of sparks before, but never the gpu itself.
14,275 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Looks like a drop of water (sweat) possibly got caught in the thermal paste and became super heated causing a small "explosion"
3,421 (2.51/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
it's actually very hard to get that kind of damage with paste and a cooler
104 (0.07/day)
I agree with bombay569. The silicon on processors is very hard stuff, but to get a divot in there like the OP has there would have to have been a foreign object caught in that spot and then the heatsink would be cranked down on it enough to chip it. Being the heatsink has something similar in it that just screams foreign body got in your application when your putting the TIM on the cpu. Did you put it together on the rug? If so, dont ever do that... that is just one of the MANY problems that comes with doing that. Being that the hole looks tapered like it is, it reminds me of what a drill bit does. This is def a first for myself and ive built alot of pc's from the cheapest garbage to really nice customs over 20 years straight.
1,067 (0.71/day)
System Name The Sparing-No-Expense Build
Processor Ryzen 5 5600X
Motherboard Asus ROG Strix X570-E Gaming Wifi II
Cooling Noctua NH-U12S chromax.black
Memory 32GB: 2x16GB Patriot Viper Steel 3600MHz C18
Video Card(s) NVIDIA RTX 3060Ti Founder's Edition
Storage 500GB 970 Evo Plus NVMe, 2TB Crucial MX500
Display(s) AOC C24G1 144Hz 24" 1080p Monitor
Case Lian Li O11 Dynamic EVO White
Power Supply Seasonic X-650 Gold PSU (SS-650KM3)
Software Windows 11 Home 64-bit
When I read "exploding" I thought you ran a thousand watts through the die or something.
But then if you'd done that, the VRMs would have popped alongwith the die.
freeagent
9,657 (4.13/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
One heck of a hard spot in that TIM :wtf:
Something must have been present when the two surfaces mated.
9,661 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
That's not the "die", it's a top layer over it.
  • Like
Reactions: Dux
1,016 (0.29/day)
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W) + Radeon MI25/WX 9100 16GB
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 11 Pro 64-Bit
I've had it happen with an XFX HD 7950 I had, the vapor chamber on the (defective) cooler expanded from the heat and crushed the die to pieces.
What the OP is seeing is likely a blowout from an internal short, must've happened in a non-critical area though since it still does something but it's toast.
11,880 (2.18/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
True , but that small portion is not going to be easy to keep cool, that's a hotspot cause, and a half.
Looks like something exited the chip package rather than got pushed into it too, very odd , never seen this like this before.
4,213 (0.71/day)
Vietnam
These are photos taken after i very first removed the HSF array to re-paste. The paste has never been cleaned before because I was saving the warranty. There was a sticker and I'm non-US.
There was nothing that I noticed when wiping it clean. Not that I couldn't have missed it, but the card is about 3 years old and has only been experiencing issues the past few months.
43,485 (6.76/day)
All it takes is a electrolyte to start the process, moisture.
My profession as an Aircraft Mechanic (A&P) sees that kind of corrosion from time to time, it is either rough like that or smooth. Either way the die is damaged and needs replacement.
578 (0.33/day)
System Name Mini efficient rig.
Processor R9 3900, @4ghz -0.05v offset. 110W peak.
Motherboard Gigabyte B450M DS3H, bios f41 pcie 4.0 unlocked.
Cooling some server blower @1500rpm
Memory 2x16GB oem Samsung D-Die. 3200MHz
Video Card(s) RX 6600 Pulse w/conductonaut @65C hotspot
Storage 1x 128gb nvme Samsung 950 Pro - 4x 1tb sata Hitachi 2.5" hdds
Display(s) Samsung C24RG50FQI
Case Jonsbo C2 (almost itx sized)
Audio Device(s) integrated Realtek crap
Power Supply Seasonic SSR-750FX
Keyboard Redragon K539 brown switches
Software Windows 7 Ultimate SP1 + Windows 10 21H2 LTSC (patched).
Benchmark Scores Cinebench: R15 3050 pts, R20 7000 pts, R23 17800 pts, r2024 1050 pts.
Looks like corrosion from the liquid that got out of that thermal pipe (manufacturing defect maybe), i had seen this on a couple of graphics cards that feature direct contact heatpipes.
43,485 (6.76/day)
Interesting you are the other to mention corrosion lol
3,831 (0.74/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
