GPU exceeds maximum temperature!
Status
Not open for further replies.
911 (0.22/day)
System Name BlueKnight
Processor Intel Celeron G1610 @ 2.60GHz
Motherboard Gigabyte GA-H61M-S2PH (rev. 1.0)
Memory 1x 4GB DDR3 @ 1333MHz (Kingston KVR13N9S8/4)
Video Card(s) Onboard
Storage 1x 160GB (Western Digital WD1600AAJS-75M0A0)
Display(s) 1x 20" 1600x900 (PHILIPS 200VW9FBJ/78)
Case μATX Case (Generic)
Power Supply 300W (Generic)
Software Debian GNU/Linux 8.7 (jessie)
I have a ZOTAC NVIDIA GeForce 9500GT (ZT-95TEH2P-FSL) which according to the manufacturer has a maximum temperature of 105°C, however my GPU reached temperatures significantly higher than that:
[image below]
The picture shows it was at 108°C but that was after I had the idea to open GPU-Z to check temperature, I believe it was higher than 110°, or maybe 115°C because the game frame rate dropped like a rock before that (and at 108°C it wasn't slow).
The GPU is still alive and well (and the fan is now working as it should).
I have a few questions:
1.Can we really trust the temperatures reported by the GPU. If yes, how much?
2.What happens if the GPU exceeds its supposed maximum temperature? Is there a risk of the hardware to stop working or that's just its maximum temperature if properly cooled?
Thank you for reading!
1,458 (0.30/day)
Processor Ryzen 9 7950X3D
Motherboard MSI X670E MPG Carbon Wifi
Cooling Custom loop, 2x360mm radiator,Lian Li UNI, EK XRes140,EK Velocity2
Memory 2x16GB G.Skill DDR5-6400 @ 6400MHz C32
Video Card(s) EVGA RTX 3080 Ti FTW3 Ultra OC Scanner core +750 mem
Storage MP600 Pro 2TB,960 EVO 1TB,XPG SX8200 Pro 1TB,Micron 1100 2TB,1.5TB Caviar Green
Display(s) Alienware AW3423DWF, Acer XB270HU
Case LianLi O11 Dynamic White
Audio Device(s) Logitech G-Pro X Wireless
Power Supply EVGA P3 1200W
Mouse Logitech G502X Lightspeed
Keyboard Logitech G512 Carbon w/ GX Brown
VR HMD HP Reverb G2 (V2)
Software Win 11
You could cook the GPU and cause it to fail, but if it's still running OK and your temps are now under control I wouldn't worry about it.
287 (0.07/day)
Chisinau, Moldova
System Name Winter Heater
Processor Intel Core I7 5820k@4250 Mhz
Motherboard ASUS x99 Deluxe
Cooling Cryorig H5
Memory 2x4GB Corsair Vengeance DDR4 + 2x4GB Kingston HyperX DDR4 @ 3000Mhz
Video Card(s) OEM GTX 970
Storage Seagate ST4000VN000, Hitachi 2TB, Crucial CX500 1TB
Display(s) LG 23EA63
Case Thermaltake Versa N21
Power Supply EVGA 650 GQ
I think it's time to clean that card of dust and reapply some new thermal paste, 100+ degrees is freaking hot for such a low-end card.
  • Like
Reactions: XSI
911 (0.22/day)
I reapplied thermal paste about 2 months ago (so it should still be ok). The thing that wasn't working was the fan, but I fixed it today by applying some cooking oil (that was the best I had).
[image below]
[image below]
And one more question, is it safe to use tooth paste in case I don't have thermal paste? It seems to be more refreshing!
Frick
Fishfaced Nincompoop
19,763 (2.86/day)
w
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
911 (0.22/day)
Frick
19,763 (2.86/day)
w
How did cooking oil fix the fan?
911 (0.22/day)
I don't know exactly. I just know the fan wasn't spinning and after applying cooking oil(soybean oil) it is spinning normally!
1,715 (0.39/day)
Somewhere Over There!
System Name Gen2
Processor Ryzen R9 5950X
Motherboard Asus ROG Crosshair Viii Hero Wifi
Cooling Lian Li 360 Galahad
Memory G.Skill Trident Z RGB 64gb @ 3600 Mhz CL14-13-13-24 1T @ 1.45V
Video Card(s) Sapphire RX 6900 XT Nitro+
Storage Seagate 520 1TB + Samsung 970 Evo Plus 1TB + lots of HDD's
Display(s) Samsung Odyssey G7
Case Lian Li PC-O11D XL White
Power Supply Super Flower Leadex SE Platinum 1000W
Mouse Xenics Titan GX Air Wireless
Keyboard Kemove Snowfox 61
Software Main: Gentoo+Arch + Windows 11
Benchmark Scores Have tried but can't beat the leaders :)
cooking oil on fans..... hmmmmm.... doesnt sound right... lol.....
nah of course it could be that oil has somewhat loosen the stock parts of the fan.... but anyway, cooking oil is too thick. its very vulnerable in collecting dust..... there is a proper lubricating oil that can be bought on any hardware shops....
hair clippers lubricating oil is better than cooking oil. I think.......
911 (0.22/day)
I would like to announce that my GPU is officially dead.
Reasons:
1.0.I was watching HDTV today and after some minutes my screen started flashing and the system stopped responding.
1.1.As it never happened before I decided to test my GPU with furmark and other GPU test programs both on Windows and Linux.
1.2.When my GPU hit above ~62°C in all tests, the system(OS) simply stopped responding (both Windows and Linux, with the difference I was able to move cursor on Linux, but nothing more).
1.3.The above never happened, so the conclusion is ~99.8% safe.
I bought this card for $175 almost exactly 5 years ago, and it was a great GPU till it reaches 110°C+.
Conclusion:
Always check if your fan is working properly and try to put an alarm to alert you about possible overheating. This thing is serious and can kill your card in a matter of seconds.
Too sad I had to learn the hard way. Now I will have to buy a GT610 for $60 in 2014.
Thank you!
1,715 (0.39/day)
System Name Gen2
Reasons:
Conclusion:
Thank you!
well that is sad.... but a good gpu serve you well... in 5 years you have enjoyed your card.... I guess cards time has come...... its a lesson learned about checking, cleaning inside components once in while. Im sure your next gpu will be happy for your next treatment
911 (0.22/day)
Well, it is time to think again.
I did some "maintenance" on the card this morning and then I ran furmark for 30 minutes and for my surprise it survived very well. Reaching a maximum temperature of 77°C (which I consider amazing).
Hopefully, I won't need to buy another card in 2014. :)
Now, tell me if you can understand these GPUs...
qubit
Overclocked quantum bit
17,865 (2.85/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Applying cooking oil to what?
Toothpaste is better than nothing.
Also, does it really get that hot? Is the heatsink scorching to the touch?
Oh dear, you have "stolen" a picture from blessed hardwaresecrets and committed a "crime". :shadedshu: Better give yourself 12 lashes as punishment, lol.
Best copy said pic and upload it to techpowerup.org methinks. ;)
Frick
19,763 (2.86/day)
w
I did link back to the original article. Also, bandwidth is free right? ;)
1,715 (0.39/day)
System Name Gen2
I did some "maintenance" on the card this morning and I then ran furmark for 30 minutes and for my surprise it survived very well. Reaching a maximum temperature of 77°C (which I consider amazing).
It's alive! :clap::clap::clap::clap::clap:
AsRock
TPU addict
19,142 (2.98/day)
UK\USA
IF your not trying to kill it re apply the paste take that crappy shoud of the cooler get some zip ties and a 80-120mm fan attached to it and if thats not enough see if you can fit a fan in between the cpu cooler and the back of the card just be careful..
5,966 (0.94/day)
New York
Processor AMD Ryzen 9 5950x, Ryzen 9 5980HX
Motherboard MSI X570 Tomahawk
Cooling Be Quiet Dark Rock Pro 4(With Noctua Fans)
Memory 32Gb Crucial 3600 Ballistix
Video Card(s) Gigabyte RTX 3080, Asus 6800M
Storage Adata SX8200 1TB NVME/WD Black 1TB NVME
Display(s) Dell 27 Inch 165Hz
Case Phanteks P500A
Audio Device(s) IFI Zen Dac/JDS Labs Atom+/SMSL Amp+Rivers Audio
Mouse Logitech G502 SE Hero
Keyboard Corsair K70 RGB Mk.2
VR HMD Samsung Odyssey Plus
the cooking oil will work for a while but you will be using it again in a few months because it goes rancid and gums up the fan so you will have to clean it out and reuse it
asrocks idea for a 80mm fan would be pretty good if your up to it and have enough room.
scrolling down all that caught my eye was CRIME :laugh:
3,014 (0.64/day)
Zagreb, Croatia
System Name Windows 10 64-bit Core i7 6700
Processor Intel Core i7 6700
Motherboard Asus Z170M-PLUS
Cooling Corsair AIO
Memory 2 x 8 GB Kingston DDR4 2666
Video Card(s) Gigabyte NVIDIA GeForce GTX 1060 6GB
Storage Western Digital Caviar Blue 1 TB, Seagate Baracuda 1 TB
Display(s) Dell P2414H
Case Corsair Carbide Air 540
Power Supply Corsair TX v2 650W
Mouse Steelseries Sensei
Keyboard CM Storm Quickfire Pro, Cherry MX Reds
Software MS Windows 10 Pro 64-bit
From what I have gathered, that fan is 5 years old ... spare it of cooking oil and let it rest in peace, it's obviously time for a replacement
911 (0.22/day)
the cooking oil will work for a while but you will be using it again in a few months...
That's good! I was expecting much sooner than this.
Let's see what happens. I just used soybean oil because I didn't have a better solution.
I would like to buy a new fan too. But it is very hard for me to get money.
I don't have a 6 years old computer because I like, it is because it is very expensive for me to buy new hardware. Additionally, the hardware here cost almost 3 times more than in US.
3,629 (0.60/day)
System Name Ultra 64
Processor NEC VR4300 (MIPS R4300i)
Motherboard proprietary design
Cooling Fanless aircooled
Memory 4.5MB 250 MHz RDRAM
Video Card(s) 62.5 MHz Reality Coprocessor
Storage 32 - 512 Mbit ROM Cartridge
Display(s) 720x576
Case Clear Blue Funtastic
Audio Device(s) 16-bit CD quality
Power Supply proprietary design
Mouse N64 mouse for use with N64DD
Keyboard N64 keyboard for use with N64DD
They can be saved and kept alive dragging by their heels.
My reference 4850 is a prime example, when i bought it, it artefact'd. I baked it and its been grand. Month ago fan died and it reached temp's very close to yours. So i strapped as many fans as i could fit to it and its been nice and cool ever since :)
AsRock
TPU addict
19,142 (2.98/day)
UK\USA
You keep complaining about shit being so exspenive but your take silly risks and whats up with that ?..
Zip ties and a 80mm fan some paste problem solved. Sorry but people who aint got much money and shit costs a lot were they live tend to act more reasonable.
911 (0.22/day)
I like to take silly risks sometimes. Just for curiosity.
But I would not risk to damage a hardware if I have no other to replace. And if it's brand new, than there would be no reason to do things like that.
Things are more expensive here but that's not the main problem, the problem is that I don't have much that can be saved monthly.
911 (0.22/day)
Time to re-apply some cooking oil. The fan is making that typical (and annoying) noise when running at 75% or faster and running a bit slower than normal causing the temperature to reach 61ºC and increasing each day.
So, the cooking oil only lasted 1 month. Which is good enough for me...
Happy New Year!
343 (0.07/day)
Ft Stewart
System Name Queen Bee
Processor 3570k @ 4.0GHz
Motherboard Gigabyte UD3 Z77
Cooling Water Loop by EK
Memory 8GB Corsair 1600 DDR3
Video Card(s) MSI GTX 970 Gaming WaterCooled
Storage 1x Western Digital 500GB Black 1x Intel 20GB 311 SSD
Display(s) BenQ XL2420G
Case CoolTek W2
Power Supply Corsair 650Watt
Software Windows 7 Pro
What an adventure this thread is! :rolleyes:
I like AsRock's fix personally
My ATi 9700 pro still works! Well I think lol :roll:. It's AGP (Accelerated Graphics Port for you teenagers) and the hardware with that port died long tie ago. so last time I used it, it was alive and kicking. If I had something to plug it into I'm sure it would whir to life.
4,375 (0.94/day)
St. Paul, MN
System Name Bay2- Lowerbay/ HP 3770/T3500-2+T3500-3+T3500-4/ Opti-Con/Orange/White/Grey
Processor i3 2120's/ i7 3770/ x5670's/ i5 2400/Ryzen 2700/Ryzen 2700/R7 3700x
Motherboard HP UltraSlim's/ HP mid size/ Dell T3500 workstation's/ Dell 390/B450 AorusM/B450 AorusM/B550 AorusM
Cooling All stock coolers/Grey has an H-60
Memory 2GB/ 4GB/ 12 GB 3 chan/ 4GB sammy/T-Force 16GB 3200/XPG 16GB 3000/Ballistic 3600 16GB
Video Card(s) HD2000's/ HD 2000/ 1 MSI GT710,2x MSI R7 240's/ HD4000/ Red Dragon 580/Sapphire 580/Sapphire 580
Storage ?HDD's/ 500 GB-er's/ 500 GB/2.5 Samsung 500GB HDD+WD Black 1TB/ WD Black 500GB M.2/Corsair MP600 M.2
Display(s) 1920x1080/ ViewSonic VX24568 between the rest/1080p TV-Grey
Case HP 8200 UltraSlim's/ HP 8200 mid tower/Dell T3500's/ Dell 390/SilverStone Kublai KL06/NZXT H510 W x2
Audio Device(s) Sonic Master/ onboard's/ Beeper's!
Power Supply 19.5 volt bricks/ Dell PSU/ 525W sumptin/ same/Seasonic 750 80+Gold/EVGA 500 80+/Antec 650 80+Gold
Mouse cheap GigaWire930, CMStorm Havoc + Logitech M510 wireless/iGear usb x2/MX 900 wireless kit 4 Grey
Keyboard Dynex, 2 no name, SYX and a Logitech. All full sized and USB. MX900 kit for Grey
Software Mint 18 Sylvia/ Opti-Con Mint KDE/ T3500's on Kubuntu/HP 3770 is Win 10/Win 10 Pro/Win 10 Pro/Win10
Benchmark Scores World Community Grid is my benchmark!!
Cooking Oil...pretty soon, you will have a GPU popcorn maker!:D
Status
