GPU Hot Spot Temperature 105 Celsius, fans at 3000 RPM, while GPU Temperature is max 70 Celsius
11 (0.01/day)
Croatia
Processor AMD Ryzen 7 5800X
Motherboard Asrock B550 Pro 4
Cooling Be Quiet Silent Loop 2 280
Memory Kingston HyperX 16GB 3200Mhz
Video Card(s) Gainward GeForce RTX 3060Ti
Storage XPG Spectrix 1TB NVMe
Display(s) Philips 328E1CA
Case Be Quiet Silent Base 802
Audio Device(s) Corsair HS70 Pro WiFi
Power Supply Be Quiet Dark Power 12 850W
Mouse Razer Pro Click
Keyboard Logitech K780
Hi, I have a rather puzzling problem that I cant resolve for 2 weeks now.
All was good, when all of the sudden while playing WoW my GPU fans started spinning at 100% on my 7900 XT gpu
HWinfo showing 65 C GPU temp, shile hot spot temp was above 100 C
checked all psu cables connections, GPU PCIE slot, moved SSD from 1 slot to another, pulled memory and put it back in
Computer is all fine, when its used for anything except for gaming, its even ok in new Cinebench GPU bench, but now while actual gaming
My rig where the problem first came up:
Asus TUF B760M DDR4
i5 12400f
LE720 360mm water cooling
Corsair Vengeance DDR4 3200MHz 2x8GB
Kingston SX2000 1TB NVMe
SF750 PSU
Lian Li O11D Mini
PowerColor RX 7900 XT
I did this:
BIOS update, updated all drivers for everything, mbo, gpu, peripherals, monitor etc, same problem
put in my 3070 card and repeated all of the above, same problem
put in different memory, same problem
put in different psu, same problem
reinstall win 11, repeated all of the above same problem
reinstall to win 10, repeated all of the above same problem
Sold CPU, water cooling, case, ssd and 7900 XT - went to shop, and bought new MBO, CPU, MEMORY, COOLER, SSD and Case:
My rig now:
Asrock B760M-itx
i5 12400f
NH-L9i
Fury DDR4 3200MHz 2x8GB
Seagate Firecuda 512GB NVMe
SF750 PSU
Lian Li Dan A4-H20
Gainward RTX 3070
Plugged it in - same problem
changed my psu cable
plugged it in a different outlet
computer passes all the stress test like, AIDA, OCCT, Cinebench, CPU-Z, y-cruncher etc
It ramps up the fans to 100% and hot spot temperature is 105 C, only in gaming and in OCCT 3D stress test, while its ok in cinebench GPU test
I am all out of ideas :(, and i was not able to find solution, or similar problem, so this is my last resort
is it possible that my PSU does something to my CPU, and then it send some instructions to GPU that makes the GPU do some work that is maxing hot spot but not "normal" gpu temperature
PSU is the only variable that I didnt change, i did try with different PSU, but only after the problem was there, but now when i have all the news stuff, and the problem is the same with the original SF750 PSU its the only thing i suspect
Help if you can guys
900 (0.67/day)
System Name 1. Glasshouse 2. Odin OneEye
Processor 1. Ryzen 9 5900X (manual PBO) 2. Ryzen 9 7900X
Motherboard 1. MSI x570 Tomahawk wifi 2. Gigabyte Aorus Extreme 670E
Cooling 1. Noctua NH D15 Chromax Black 2. Custom Loop 3x360mm (60mm) rads & T30 fans/Aquacomputer NEXT w/b
Memory 1. G Skill Neo 16GBx4 (3600MHz 16/16/16/36) 2. Kingston Fury 16GBx2 DDR5 CL36
Video Card(s) 1. Asus Strix Vega 64 2. Powercolor Liquid Devil 7900XTX
Storage 1. Corsair Force MP600 (1TB) & Sabrent Rocket 4 (2TB) 2. Kingston 3000 (1TB) and Hynix p41 (2TB)
Display(s) 1. Samsung U28E590 10bit 4K@60Hz 2. LG C2 42 inch 10bit 4K@120Hz
Case 1. Corsair Crystal 570X White 2. Cooler Master HAF 700 EVO
Audio Device(s) 1. Creative Speakers 2. Built in LG monitor speakers
Power Supply 1. Corsair RM850x 2. Superflower Titanium 1600W
Mouse 1. Microsoft IntelliMouse Pro (grey) 2. Microsoft IntelliMouse Pro (black)
Keyboard Leopold High End Mechanical
Sounds like a cooling issue. Blockage or water pump maybe?
Edit: sorry, just saw the air cooler on the second setup.
Frick
Fishfaced Nincompoop
19,046 (2.83/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
I do believe I read some stuff about the Powercolor cards specfically had a tendenecy to be poorly assembled, . Check the card for loose screws.
9,203 (3.34/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
I don't understand you had this problem before as well with a different GPU ? So both the 3070 and 7900XT were hitting the same temperatures ? That seems really unlikely.
freeagent
7,961 (3.73/day)
Winnipeg, Canada
Processor AMD R9 5900X
Display(s) LG 50UP7100
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
If that is the case, then it has to be his lack of case flow. If he does have good case flow, then silence and high performance do not go hand in hand.
21,562 (6.00/day)
Case Fractal Design Define R5
Mouse XTRFY M42
Software W10 x64
Yeah I had a lengthy post regarding that, I thought he had those 7900XT temps in two systems, and that would have been plausible, seeing as its the same card. Deleted my post :p
578 (0.38/day)
System Name Mini efficient rig.
Processor R9 3900, @4ghz -0.05v offset. 110W peak.
Motherboard Gigabyte B450M DS3H, bios f41 pcie 4.0 unlocked.
Cooling some server blower @1500rpm
Memory 2x16GB oem Samsung D-Die. 3200MHz
Video Card(s) RX 6600 Pulse w/conductonaut @65C hotspot
Storage 1x 128gb nvme Samsung 950 Pro - 4x 1tb sata Hitachi 2.5" hdds
Display(s) Samsung C24RG50FQI
Case Jonsbo C2 (almost itx sized)
Audio Device(s) integrated Realtek crap
Power Supply Seasonic SSR-750FX
Keyboard Redragon K539 brown switches
Software Windows 7 Ultimate SP1 + Windows 10 21H2 LTSC (patched).
Benchmark Scores Cinebench: R15 3050 pts, R20 7000 pts, R23 17800 pts, r2024 1050 pts.
You already applied liquid metal and torqued the mounting screws to spec, right?
11 (0.01/day)
Croatia
i have a feeling you didn't read or understand the post guys
what liquid metal, what torqued, what case flow, what side panels :D, that is not the issue
the problem is not with the case flow, or the GPU temperature, since that is not getting above 70C, with both 7900 XT and 3070, the problem is the GPU HOT SPOT TEMP, that is getting 105+ C
two different GPUs, 2 different MBOs, two different memory, two different CPUs, two different SSDs, two different OS, in all possible combinations, two different case, only variable that is not changed is PSU
Lian Li O11D Mini, and A4-H2O have insane good airflow and i used in one case 7xA12 and 2xA14 Noctuas, and in other 2xA12 Noctua fans
HOT SPOT temp 105+ C and fans at 100% happen when i play games or run heavy GPU test
so my question was, since i changed everything two fold, could it be PSU doing something or CPU doing something, that is making HOT SPOT that hot?
and like i said al was fine, until one day it was not fine
9,203 (3.34/day)
Case Phanteks NV7
No, if you get the same temps on two different GPUs from two different manufacturers the only possible explanation is that the case cooling is really bad.
Remove the case panel like suggested and see what happens. The only other plausible explanation is that you have a crypto miner or something running.
5,853 (2.96/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Gpu temps won't be solved be ditching your entire setup and swapping to even smaller case. Stop using your wallet.
3,023 (1.03/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Storage Too much
Case Thermaltake Core X9
Mouse G305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
At any point have you tried breadboarding the system? It's not something you noted as having done. To do it you simply take your motherboard, CPU, 1 stick of RAM, and in your case the GPU and hook it up to the PSU outside the case. You then only connect what input perifs you need (which should just be a mouse / keyboard). Then run whatever application that was causing high hotspot temps and see if the issue persists. It's possible you got two GPUs with high hotspot temps but improbable. I have never seen PSU selection impact something as specific as GPU hot spot temp but even if we assume it could, it would have to be extra-ordinarily rare and yet you are exhibiting it across two different GPUs. Probabilities tells us that it's far more likely something else. On the list of potential issues, the PSU causing high hotspot temps is below that of metal whiskering.
11 (0.01/day)
Croatia
to repeat again.
Lian Li O11D Mini with 7(seven) 120mm Noctua fans, 2(two) 140mm Noctua, of which 3 120mm fans are below GPU as intakes, 3 120mm fans at the top as exhaust, 2 140mm fans on the side as intake, and 1 120mm at the rear as exhaust was the case i used for 6 months before this issue.
Never ever was CPU temp above 60C , GPU temp above 70C, GPU Hot Spot temp above 80C, GPU memory junctions temperature above 90C, while gaming at 4k resolution in WoW, Diablo 4, Cyberpunk, Apex etc.
and to miner issue, as I wrote i formatted 2 disks, and installed win 11 and win 10 on both of them 2 times clean
it is not case issue, airflow or any similar thing since the problem is the same on the table, when the system is not in the case
yes i have done that also, as I wrote, peripherals, memory stick, 2 motherboards, 2 gpus, 2 cpus, 4 memory sticks, 2 ssds, 2 operating system 2 different power socket
i would not come here if i didn't do every single thing i could come up with :)
gpus work perfectly fine in other systems that i have which is in Meshlicious with worst cooling than this two are :)
my question was, is it possible that the SF750 did something to CPU, that makes the cpu send instructions/signals to GPU that makes the GPU do heat up the hot spot, or something
thing is, when the problem popped up i did try with with different PSU, it was the same thing, so i thought that its not psu
but if the original PSU did the damage, then the other psu would would not matter
and when i bought new components i put he SF750 again, i didnt not try first with different PSU, because i didnt think the problem is with PSU
9,203 (3.34/day)
Case Phanteks NV7
Then you are really unlucky and got two GPUs that just have bad temps. My reference 7900XT would hit 100C when overclocked.
11 (0.01/day)
Croatia
i wrote above that both GPU work just fine in, since i tried them both in different system, and there is no problem with any of them
1,044 (2.17/day)
Processor Ryzen 7800x3d
Motherboard Asus B650e-F Strix
Cooling Corsair H150i Pro
Memory Gskill 32gb 6000 mhz cl30
Video Card(s) RTX 4090 Gaming OC
Storage Samsung 980 pro 2tb, Samsung 860 evo 500gb, Samsung 850 evo 1tb, Samsung 860 evo 4tb
Display(s) Acer XB321HK
Case Coolermaster Cosmos 2
Audio Device(s) Creative SB X-Fi 5.1 Pro + Logitech Z560
Power Supply Corsair AX1200i
Mouse Logitech G700s
Keyboard Logitech G710+
Software Win10 pro
Repaste gpu, and make sure the cooler is equally tightened on each corner.
11 (0.01/day)
Croatia
please read what I wrote, there is nothing wrong with any of the gpu :banghead:
122 (0.18/day)
System Name Phat Cat
Processor Ryzen 5 5600x
Motherboard MSI B550 Pro
Cooling ID Cooling SE-224XT with 120mm Noctua, 2x200mm Noctua, 2x140 Noctua
Memory 32GB Kingston Fury 3200mhz CL16
Video Card(s) Asus RTX 3070 TUF OC
Storage Kingston NV2 2 Tb
Display(s) Dell G3223D
Case Thermaltake Commander C32
Audio Device(s) Audigy 5/RX + Audigy 2 Bay
Power Supply Thermaltake Toughpower GF1-750W
Software Windoze 11
My 3070 never pass the +10~15 Celsius hot spot from the core temp. are you sure the 12V line is ok?
What about the Vcore?
About the 7900 not sure wht to say dont have one...
11 (0.01/day)
Croatia
ok, good idea
here is my screen shot.
do you see anything that is off, or anything that can indicate what the problem is?
only thing that i notice is different from yours, is you have full green line, while mine is grey/green, is that something that shows that my PSU is faulty?
1,044 (2.17/day)
Software Win10 pro
And have you tried repasting the gpu, since you can say that with 100% certainty ?
When there is a huge delta between gpu temp and hotspot, it is essentially always a bad mount or bad TIM that is the issue...
But for all i care you can just do whatever you want... buy a new psu, that will surely fix your gpu hotspot temp... lol
11 (0.01/day)
Croatia
i can say that with 100% certainty, since both gpus where tested in my other computer, and they both work fine, and don't have problem with hot spot or anything else in same testing conditions, in same software and games
i know that i wrote a lot of text and it can be boring to read through all of it, but please try, just to fully grasp the issue i am having
thank you for understanding
1,797 (0.40/day)
Romania
Were those cards new or ? It looks like a bad mount or thermal paste application. Do they still have those "warranty stickers". Do you have warranty for them ? If not i would repaste them or take them to someone that can do that for you, if you have not done that before. As a general rule the difference between GPU temp and hot spot should be around 15ºC with a good mount.
PS:
Until then you can undervolt them an lower the temperature and fans rpm.
122 (0.18/day)
Software Windoze 11
ok, good idea
is your cards bent or sagged, all looks good on monitoring side
188 (0.12/day)
WorldWideWeb
System Name MPG
Processor i3-10105F
Motherboard Z490 Gaming Plus (MS-7C75)
Cooling Be Quiet Dark Rock Advanced
Memory GSkill RipJawsV 32Gb 3200
Video Card(s) GTX1060 6Gb AERO ITX OC
Storage NVMW WD Black SN750 Samsung EVO 840 SSD and Mechanical TBs...
Display(s) Asus VS278Q
Case CM HAF-X
Audio Device(s) ALC1200 Yamaha AV Creative DTT2200
Power Supply Corsair RM-1000
Mouse SteelSeries Rival
Keyboard MS Sidewinder X6
Software Windows 10/11
A 7900XT packed in a "Glass box" really nice... that's a non-breathing case for such hw set...
And definitely to much delta values as previous droopyRO mentioned...
