GPU load calculation
tesmai4
5 (0.00/day)
What is meant by "GPU Load" in GPU-Z and how is it calculated?
Is it only a measure of the cores being used or does it comprises of multiple attributes?
Regards,
tesmai4
5 (0.00/day)
@Wizzard, Thanks for your reply. I have seen this reply before posting my question and was not sure about the answer.
Shall I consider it as an official reply that can be quoted.
I was having conversation with one of my colleague and we are not sure about the reported GPU load from GPU-Z.
GPU-Z show 7-10% of GPU load, even after my calculation has finished and the application has terminated. I am bit confused on it.
Regards,
tesmai4
5 (0.00/day)
Same thing that CPU load reports... how much of the core is used.
Sorry, I don't think your reply is correct. My application is using most of the GPU cores in my application. Still, GPU-Z displays only 10-15% of GPU usage.
Tatty_Two
Gone Fishing
26,029 (3.70/day)
Worcestershire, UK
Software Win 11 Home x64
Is GPU "Load" not different from GPU "activity"?
tesmai4
5 (0.00/day)
May be, I am referring to "GPU Load" from GPU-Z utility and want to what is exactly represented by it. My problem is that GPU-Z show 7-10% of GPU load, even after my calculation has finished and the application has terminated. I am bit confused on it.
Regards,
W1zzard
Administrator
28,599 (3.74/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
same thing. on both nvidia and amd the driver gives you a number between 0 and 100 that it calls gpu load/activity or other interchangeable terms, without any explanation what it really measures
Regards,
what kind of application is this? what hardware do you run on? any bottlenecks that are not gpu shaders?
19,379 (3.46/day)
Sorry, you misunderstood me. Read W1zzards link. ;)
Regarding your use on idle... do you have aero theme in windows or something? I sit a bit lower than that but there is always activity.
W1zzard
Administrator
28,599 (3.74/day)
Memory 48 GB
yes, windows aero will always have some activity, even without aero some functions like bitmap drawing, cursors etc are gpu accelerated, so there will be some load. also your browsers use the gpu
tesmai4
5 (0.00/day)
Thanks. I have two GPU in my system. Quadro 600 for display and Tesla for data crunching only. I am referring this activity on the Tesla card.
W1zzard
Administrator
28,599 (3.74/day)
Memory 48 GB
Maybe GPU-Z can not monitor the Tesla card correctly (I've seen that on K20c). Have you tried with NVIDIA's nvsmi tool?
