GPU not detected by AMD Driver (Error Code 182)
2 (0.00/day)
System Name ShootToDeath
Processor Core i9 11900K
Motherboard Asus Prime Z590-A
Cooling Cooler Master Liquid coolling
Memory Corsair 32GB DDR4
Video Card(s) AMD RX 5700
Storage 2 TB Samsung 980 PRO
Display(s) Dell 144hz 27 Inch
Case DeepCool Matrexx 50
Audio Device(s) JBL Charge 5
Power Supply Cooler Master 1250W Gold
Mouse Logitech Gaming Mouse
Keyboard SteelSeries Apex 5
Software Windwos 11
Having problems with installing AMD driver for Rx 5700, shows error code 182.
My system
CPU: Intel Core i9 11900K
Motherboard : Asus Prime Z590-A
Ram : Corsair 32 GB (16x2)
GPU : AMD Radeon RX 5700 (in GPUZ shows Vega20/VII)
SSD: 1 TB Samsung 980 PRo
PSU: Cooler Master Gold 1250W
Tried on fresh Windows 10 and Windows 11.
Im frustrated by seeing error code 182 every single time when i tried to install Radeon driver for my GPU.
Im using HDMI cable plugged with my GPU and the display working, But in the Adapter option it show Microsoft Basic driver.
I tried to install latest driver from AMD.com and but show Error code 182 (GPU not detected)
I changed bios setting for PCI to Gen 4 but didnt worked,
tried to clean install in safe mode but didnt worked.
Read all the blogs and tried all things but didnt helped.
If anyone can help me to get driver installed.?
thanks
6,242 (0.85/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
Sounds like your GPU needs to be returned for refund.
  • Like
Reactions: r9
r9
3,300 (0.54/day)
System Name Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck
Processor i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t
Memory 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5
Video Card(s) RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs
Storage 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme
Display(s) 50" 4k TV | Dell 27" |22" |3.3"|7"
VR HMD Samsung Odyssey+ | Oculus Quest 2
Software Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro
4,872 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
i recall someone posting about this issue a few months ago and it ended up being a setting in the BIOS the user had to change
1,891 (1.33/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
True, as i remember it was something regarding the main board BIOS.
44,011 (6.81/day)
My system
thanks
Looks like its a used card with the wrong bios, look at the default clocks
Do a motherboard bios update first, then get a pic of the white stickers on the card back(exclude the Serial Number)
Also it says Vega 20, not Navi, are you sure you have a navi card and not a vega? The bios installed stays true to the gpu core, eg you can't install a gf116(fermi) bios on a Maxwell (gm)or kepler (gk) core
1002 66AF tells me Radeon VII (Vega Based) but only the Vega 56/64 had 8G HMB, this is showing GDDR6
VII had hbm2 as well, looks like someone tried tampering with the bios and since Radeon RX Vega 56/64 the bios can't be modded in any way, the bios are digitally signed and if the bios is tampered with the drivers will fail to install every time, you can thank miners for this.
I suggest the pics then removing the gpu heatsink to get pics of the ram chips to include a close up of the White Silkscreen stencil on 1 ram chip.
2 (0.00/day)
Software Windwos 11
+1
If that is not an option try flashing the correct bios.
Worked,
By flash bios using ATIVBFLASH tool and AMD 5700 rom from https://www.techpowerup.com/download.
GPU detected correctly and the drivers get installed.
thanks
Worked,
thanks
44,011 (6.81/day)
