GPU or CPU upgrade?
rezig824
5 (0.02/day)
Hi, i'm having a GTX 1650 with a Ryzen 3600 that i wan't to upgrade.
But i'm struggling to find out if i should upgrade the GPU or the CPU? (Can't do both atm) I do mostly gaming.
The GPU i have in mind is the RTX 4070 or RTX 4070 Super (if it is any good/ reasonably priced). Or should i wait until next gen GPU comes, and this time around upgrade my CPU to a 5700X3D?
,but the plan is to upgrade both in the future, so the question is more like, upgrade GPU now and get CPU in about a year or so, or CPU now and wait for next gen GPU until like 2025?
i have motherboard ASUS TUF GAMING B550-PLUS pcie-4.0 AM4 and Monitor ASUS TUF Gaming Vg24vq 144hz 1080p.
but i need more fps first Upgrade GPU RTX 4070/Super + ryzen 5 3600 , after waiting 3 months buy cpu upgrade AMD Ryzen 7 5700x3d + rtx 4070
msi geforce rtx 4070 super 12go gaming x slim vs asus tuf gaming geforce rtx™ 4070 super 12gb gddr6x oc edition What difference?
3,391 (4.85/day)
Russian Wild West
System Name DLSS / YOLO-PC / FULLRETARD
Processor i5-12400F / 10600KF / C2D E6750
Motherboard Gigabyte B760M DS3H / Z490 Vision D / P5GC-MX/1333
Cooling Laminar RM1 / Gammaxx 400 / 775 Box cooler
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333 / 3 GB DDR2-700
Video Card(s) RX 6700 XT / R9 380 2 GB / 9600 GT
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 / 500 GB HDD
Display(s) Compit HA2704 / MSi G2712 / non-existent
Case Matrexx 55 / Junkyard special / non-existent
Power Supply Thermaltake 1000 W / Corsair CX650M / non-existent
Software Windows 11 / 10 / 8
You will get a massive FPS boost even without upgrading your CPU. 4070 Super is ages better than 1650. Sure, you'll be bottlenecked but this is a very reasonable purchase.
I'd go for the GPU first (even disregarding the actual games you play because improvements will be massive all across the board, even in the games that have the least GPU importance such as Counter-Strike, DotA, CoD, and the likes).
The difference between these two 4070Ss is that the latter is usually more expensive. Buy the cheaper one (if both fit your PC case just fine), it doesn't matter. Quality is about 99.9% identical.
izy
1,062 (1.13/day)
If you grab the RTX 4070 instead of RTX 4070 S you might have some money left to get a 5700x3d or even a 5700x is a decent option, i also think you should get the cheaper option of the RTX 4070 / S .. u wont get significant performance increase.. maybe just a lil better cooling.
696 (1.80/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
Mostly gaming is one thing. What is the other? I'm not sure what advice to give so flip a coin.
I run a frightfully similar combination of R5 3600 and RX580.
Mostly gaming, if I'm in my gaming phase. Otherwise VR development, 3D stuff and watching streams, which can be offset to phone/tablet.
Going live is a whole other universe that I could do by phone and I just don't do that on my hardware as it's too troublesome to setup.
On a 1650 Super, all of that would be perfectly fine. So unless you need more than 1080p144 desktop or dual 2K90, just go a class up?
The RTX 2000 series is mad cheap but seems limited to 8GB. Not sure if that's a deal breaker for you. The 10GB+ RTX 3000 stuff looks cheap.
You missed the boat on discount RX 6000/7000 stuff by just over a month. No idea if those prices are ever coming back without a fight.
Also CES is coming up in a day with new product announcements and a lot of everything. So maybe it's best to just hold tight for now?\
Last year I made multiple attempts to sunset my 580 with the 7900 XT and it didn't go well.
Can't power them correctly or something where literally everyone missed the problem.
I'm willing to try it again if prices come down but I understand that the 3600 will heavily bottleneck it at 1080p, which is NOT my concern.
Since you have a bigger monitor and probably enjoy higher resolution devices, maybe you're headed for the same exit. Unless you're streaming.
Either way, retiring my GPU is a much bigger priority than a new CPU. I have no idea if your frames are suffering or whatever so it depends.
1,703 (1.07/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
A new generation of GPUs from both manufacturers will be available within weeks. So it isn't the best time to buy one now.
On the other hand, if you're not going for a full platform upgrade, the only CPU that makes sense for gaming on AM4 is the 5700X3D.
What kind of games do you mostly play? Do you expect them to run at your monitor's native 144 Hz? Do you mind lowering the settings if they don't? Alternatively, do you consider upscaling and/or frame generation to achieve your target fps?
Do you see RT as a requirement?
13,695 (6.22/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Case The smaller the better
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
I vote GPU.
But instead of the 4070, you may find a massive discount on the 7900 GRE, as it's being discontinued. Some places list it cheaper than the 4060 Ti, while it's way faster.
346 (1.91/day)
Something like a 7700xt would be better, you won't push 4070 Super at 1080p to its fullest using a 3600.
146 (0.03/day)
Israel
System Name 2024 Build
Processor AMD Ryzen 5 7600X
Motherboard ASUS Prime B650-Plus
Cooling Artic Freezer 36 A-RGD
Memory Corsair Vengeance RGB 2x16GB DDR5 6000MHz CL36
Video Card(s) Sapphire Radeon RX 7600 Pulse OC
Storage Samsung 990 Pro 2TB + Samsung 980 500GB + Transcend 230S SSD 512GB
Display(s) MSI G255F FHD 180Hz - FreeSync
Case Antec Three Hundred TWO - Optirec DVDRW AD-7280S
Power Supply Corsair RM650 650W 80 PLUS Gold
Mouse Logitech G502 X
Keyboard Logitech Prodigy G213 RGB
Software Win 11 Pro
ryzen 3600 is not the best those days. but its still good! and i think its better to upgrade your gpu.
dgianstefani
TPU Proofreader
5,202 (2.01/day)
Swansea, Wales
System Name Silent/X1 Yoga
Benchmark Scores Legendary
4070S now and 5700X3D later.
146 (0.03/day)
Israel
Software Win 11 Pro
a friend of my just upgarded to 4060 ti from 2070 for free...
and his next move is 5700x3d. he have the same cpu - 3600 ...
51 (0.01/day)
May as well wait for the 5070 now. Or keep waiting for the 6070. Your gpu is weak, get a new graphics card first. Get a x3D later. EZ or stop gaming and get nothing.
310 (0.72/day)
4070, but make sure your PSU isn't ancient otherwise this whole endeavor might be a very expensive lesson...
All GPUs after the RX6xxx and RTX3xxx series can be assumed to have some brutal transient power spikes that can cause at minimum instability issues and at worst hardware damage if your PSU isn't on the newer side.
dgianstefani
TPU Proofreader
5,202 (2.01/day)
Swansea, Wales
Actually it's specifically that generation that had that issue. RTX 40xx and presumably RTX 50xx have resolved this.
13,695 (6.22/day)
Midlands, UK
Cooling Yes
Storage A lot
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
So did RX 7000 (somewhat).
3,760 (1.91/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 200W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2605), upgraded from Win10 to Win11 on Jan 2024
As you said you are more comfortable to upgrade the system in 2 times.
1. GPU
2. CPU (after a few months)
It would be better to tell us how much you can spend on each, where are you, and what market choices you have.
I too vote that the GPU should go first, followed by the CPU later.
696 (1.80/day)
Seattle
System Name DevKit
VR HMD Oculus CV-1
If you need some logic behind the upgrade order, it goes something like this:
GPU and other accelerators that bottleneck the snot out of the CPU are welcome as they are an immediate massive improvement.
The CPU is already doing its best and a new CPU should unlock some fair improvements after the first change.
So it's no wonder I'm looking at doing exactly this. I'm sure many others will agree.
51 (0.01/day)
I agree. in most cases a new GPU will give much more of a WOW vs a cpu. I had a old Xeon quad (E5-1660 v2 @ 3.70GHz w 32GB of quad channel ECC ram.
First upgrade was to a 1080GTX and was a massive WOW at the time then.....I did it again
2nd upgrade was to a 4070FE and again WOW it was so smooth in new games almost all games could be maxed out and did not slow down under 60fps most 90-180 fps.
3rd upgrade was the cpu/mb/ram X3D amd system. and this was not a WOW more of a ok its a little smoother in this game. Like Red Dead on max went from 62fps to like 90fps, I did not really feel the new cpu in the game but when I benched yes it was faster.
Now if I kept my pre 1080gtx gpu and just did 3 cpu upgrades it would have been a major let down having over powered cpus with an old quadro graphics card.
Yes get a new GPU first.
Outback Bronze
Super Moderator
2,095 (0.43/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Asus
Keyboard Corsair
Software Win 11
I'd go for the GPU
100% agreed ;)
We will be having new GPU releases soon so just hold your horses. You should be able to pick up 4070's cheaper if that's the way you still want to swing.
