GPU Recommendation For Triple Monitor Gaming
Durvelle27
6,798 (1.49/day)
Memphis, TN
System Name Black Prometheus
Processor |AMD Ryzen 7 1700
Video Card(s) ASUS DirectCU II R9 290 4GB
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Hey what’s up TPUers, I’m trying to decide on my next GPU that will perform decent on Triple Monitors (5760x1080@75Hz) sometimes I may play at 4K but not very often. I play most AAA titles; Crysis 3, BF1, BFV, Tomb Raider, CoD WWII, Black OPs IIII, Need For Speed etc...
GPUs I’ve looked at are the GTX 980, GTX 980 Ti, GTX 1070, RX 570, RX 580 (Multi GPU is an option a well)
Power isn’t a issue either as I’m using a Antec 850W modular PSU
the54thvoid
Super Intoxicated Moderator
13,124 (2.39/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
In first with RTX 2080ti.
:p
phill
17,005 (3.43/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
I use a EVGA 1070 SC at the moment, it's not too bad with triple 1080P screens (I guess that is the res your playing at??) but I think a 1080 might be better with newer titles and would definitely last a little longer again.. That said, maybe even a 1080 Ti or something around that if you'd like to future proof the system/experience :)
Durvelle27
6,798 (1.49/day)
Memphis, TN
:p
RTX is a no for me
I refuse to have to buy various adapters for my monitors
Yes Triple 1080p is (5760x1080)
1,806 (0.61/day)
BGD
System Name Minotaur
Processor Intel I9 7940X
Motherboard Asus Strix Rog Gaming E X299
Cooling BeQuiet/ double-Fan
Memory 192Gb of RAM DDR4 2400Mhz
Video Card(s) 1)RX 6900XT BIOSTAR 16Gb***2)MATROX M9120LP
Storage 2 x ssd-Kingston 240Gb A400 in RAID 0+ HDD 500Gb +Samsung 128gbSSD +SSD Kinston 480Gb
Case NZXT H5 Flow
Mouse Asus TUF-GAMING M3
VR HMD Oculus Rift DK2
Software Win 11
Benchmark Scores Fire Strike=23905,Cinebench R15=3167,Cinebench R20=7490.Passmark=30689,Geekbench4=32885
Well I am using my current GTX 970(OC) to play games on my triple monitor setup for res 4480x1080(my side monitors are smaller then the middle one) and honestly almost all games that I played can hit that magic 60 Fps on Avg(few tweaks here&there in settings) but to be honest I still prefer AMD cards(I used RX 470)when it comes to this because there is so much more settings&optimizations for Eyefinity in general then for Nvidia Surround beside that I am always using with Nvidia cards Windowed borderless gaming to play my games in this current triple monitor setup.....Now I believe that for 5760x1080 res in 75hz which means that you also expecting 75Fps on avg. you will need at least RX 580 or GTX 980 but If you can afford then go for GTX 1070 or GTX 980TI.....GL
Durvelle27
6,798 (1.49/day)
Memphis, TN
What your actual native individual monitor resolutions
I also prefer AMD cards as well but prices on them isn’t so decent for the performance
I don’t expect 75FPS but I do expect to be able to hit 60FPS Avg with no AA
1,806 (0.61/day)
BGD
Case NZXT H5 Flow
Software Win 11
My main monitor Acer is 1080p /1920x1080/ and I am using my "oldish" Eizo monitors (1280x1024) as side panels....it´s working GREAT but not via Nvidia surround options I am using that little program so that I can FORCE games to work in Resolution that I prefer.....It was a bit complicated before I figured all tricks...but now all games that I am playing working with no problems.....Depend of the game but AA is the first thing that I will also turned off otherwise it will EAT all my frames :laugh:....
Durvelle27
6,798 (1.49/day)
Memphis, TN
GTX 1080 Ti is too expensive
phill
17,005 (3.43/day)
Somerset, UK
Apologises @Durvelle27 , I was not paying attention to the first post..
I'd suggest 1080 personally, as mentioned, my 1070 seems to drop a few FPS when everything switched on so I tend to go with max details and then max possible res.. No point having a high end card if it's not making everything run very pretty in my eyes..
Although currently with Dirt 3 I'm playing, 100 to 120 fps is very do able on a single 1080 with everything set to Ultra and MSAA or whatever it is, set to 4x.. 8x messes it up... I have to also run older drivers as newer drivers seem to stop Dirt 3 playing altogether....
Any sort of budget with this upgrade? I'm not sure how good SLI 1070's might be, might be lucky with some of the games mentioned above :)
303 (0.11/day)
SoCal
System Name unnamed currently :*(
Processor Intel Core i7-5960x
Motherboard ASUS ROG RAMPAGE V EDITION 10
Cooling EKWB/Bitspower CPU, motherboard & GPU WB
Memory Corsair Dominator Platinum 4x4gb ddr4 2666
Video Card(s) nVidia GTX 1080 Ti FE 11GB
Storage Samsung 960 Evo 1 TB M.2 SSD & WD Black 5TB HDD
Display(s) Asus SwiftROG PG278Q & Asus PB277Q
Case Corsair 900D
Audio Device(s) Sound Blaster Zx
Power Supply Corsair Axi1200
Mouse Steel Series Sensei RAW
Keyboard Corsair K70
Benchmark Scores 4.8 ghz @ 1.37 - 5930k - old cpu 4.6 GHZ @ 1.3 - 5960X - current cpu
It's a good time to be a buyer if you need a card.
BHPhoto is having sales for the EVGA 10 series cards.
1080 Ti is $599
1080 is $450
1070 Ti is $399.
EVGA also has the stepup program that's running for people who buy 10 series cards now.
https://www.evga.com/support/stepup
https://www.bhphotovideo.com/c/product/1430950-REG/evga_geforce_gtx_1070_ti.html
https://www.bhphotovideo.com/c/product/1430949-REG/evga_08g_p4_6284_kr_geforce_gtx_1080_ftw.html
https://www.bhphotovideo.com/c/product/1430948-REG/evga_geforce_gtx_1080_ti.html
Durvelle27
6,798 (1.49/day)
Memphis, TN
I decided
I may end up going with a GTX 1060. That should do nicely for me until next Gen
Toothless
Tech, Games, and TPU!
9,663 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
I'm running a 1080Ti and anything with cryengine or something like TC:Wildlands will eat it up on triple 1080p. I've had to lower settings on a few games.
