- Oct 25, 2022
- 63 (0.08/day)
Processor | Ryzen 5 5500 |
Motherboard | ASUS Prime B450-Plus |
Cooling | 3x Inwin Saturn AS120 + 1x Aerocool Standard |
Memory | 2x8 GB XPG D50 3200 MHz - CL15 |
Video Card(s) | Gigabyte Gaming OC RX 6600 XT |
Storage | WD Blue SATA SSD 1TB + 500GB Hitachi HDD |
Display(s) | GAMEON 144hz IPS 1080p |
Case | Aerocool Rift Tempered Glass |
Power Supply | MSI MAG A550BN |
Hello. Recently my GPU RGB light has not been functioning properly, so I've tried reinstalling drivers and reinstalling GCC, both of which did not fix the issue. It refuses to activate even if I try and change it's color or brightness through GCC settings. This issue appeared when I had a videogame open and accidentally set the PC to sleep mode. While the computer was in the middle of entering sleep mode (takes a couple seconds), I spam pressed the space bar to try and cancel the sleep mode procedure. While all the lights on the PC were turning off, it did cancel eventually after enough pressing, and all of them turned back on EXCEPT for the GPU's RGB light, which never worked since then. |
