GPU too heavy?
86 (0.03/day)
Got a Zotac 1080 which is huge and seems to be getting a bit heavy for my board. Will this damage my board?
1,269 (0.34/day)
Birmingham UK
System Name El Calpulator
Processor AMD Ryzen R7 7800X3D
Motherboard ASRock X670E Pro RS
Cooling ArcticCooling Freezer 3 360ARGB AIO
Memory 32GB Corsair Vengance 6000Mhz C30
Video Card(s) MSI RTX 4080 Gaming Trio X @ 2925 / 23500 mhz
Storage 5TB nvme SSD + Synology DS115j NAS with 4TB HDD
Display(s) Samsung G8 34" QD-OLED + Samsung 28" 4K 60hz UR550
Case Montech King 95 PRO Blue
Audio Device(s) SB X4+Logitech Z623 2.1+Astro A50 Wireless
Power Supply be quiet! Pure Power 12 M 1000W ATX 3.0 80+ Gold
Mouse Logitech G502X Plus LightSpeed Hero Wireless plus Logitech G POWERPLAY Wireless Charging Mouse Pad
Keyboard Logitech G915 LightSpeed Wireless
Software Win 11 Pro
Benchmark Scores Just enough
I have a Palit 1080 Game Rock which is heavy but it don't think it will affect the MB in any way but then again my motherboard has metal reinforced PCI-e. Anyway I think you'll be fine, if you're very worried you can improvise some kind of support, I've done something similar as the card does not sit straight
86 (0.03/day)
what kind of support?
qubit
Overclocked quantum bit
17,865 (2.85/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Your mobo should be ok. It does mean that you have to be more careful when moving your PC not to bump it excessively though or that extra weight could potentially cause damage.
btw, it's a good idea if you fill in your system specs in your profile.
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (1.97/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Mouse cheap
Keyboard under going restoration
improvise if you dont want a shop bought support. LEGO can be colour coordinated.
peche
Thermaltake fanboy
6,709 (1.79/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
CAPSLOCKSTUCK
8,578 (1.97/day)
llaregguB...WALES
Mouse cheap
^^^^^^^^^^^ Thats good you can use it for bitcoin mining too and they put it on the advert.....wankers.
12,333 (2.24/day)
Oregon
Keyboard EVGA / Logitech K400
I'll take that weight off your hands
9,658 (3.28/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
I'm surprised cases still don't come with GPU holders as standard. Even though I have cheap one it did came with one of those.
hat
Enthusiast
21,750 (3.27/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Backplates are supposed to help with that, but a lot of cards don't come with this relatively cheap thing.
Anyways, you could improvise... my first thought was legos.
19,375 (3.51/day)
Backplates prevent pcb warp. Gpus can sag even with a straight pcb due to its weight. ;)
las
1,693 (0.38/day)
System Name Meh
Case Fractal Design North XL
Audio Device(s) FiiO DAC
It won't damage the slot or board.
3,652 (0.68/day)
Portugal
I use the PSU's PCI-e cables, pulling from the top of the case, so there's that too.
2,342 (0.44/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
Here is an extreme example of pcie slot damage, you can Google many of them:
21,667 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
They also said "gaming" so they are clearly just equal opportunity.
las
1,693 (0.38/day)
System Name Meh
A card won't do that type of damage unless the slot is damaged to begin with.
I've seen numerous people trying to rip the card out, before pressing the pin, and ruining the slot. Many of the images you find on Google is because of just that.
las
1,693 (0.38/day)
System Name Meh
Free pancakes at IHOP today.
12,333 (2.24/day)
Oregon
It can damage both the slot and the card. And its an easy fix
23,122 (6.10/day)
Hehe sounds familiar. Pretty neat solution IMO, but the sag does return a tiny bit over time. However this does prevent most of the risk of bumping your case and causing damage, because most of the weight is then carried by the cable.
471 (0.14/day)
System Name Specs Last Update: 8/April/2024
Processor Intel Core i5 9400f 2.9GHz/4.0 Turbo (NoOC)
Motherboard Gigabyte Z370M D3H rev. 1.0
Cooling be quite! Dark Rock Slim 180W TDP (The Silent Wings 3 120mm Fan)
Memory Corsair Red Line 8x2 16GB 3000MHz (NoOC) DDR4-3000 15-17-17-35 (CMK16GX4M2B3000C15R) V1.35 ver 4.24
Video Card(s) NVIDIA GeForce MSI 980 Ti Golden Edition (NoOC)| Spare: GTX 650 Ti 1 GB
Storage Samsung 870 EVO 4 TB | Samsung 860 EVO 1 TB | Cold Backup: WDC Black 930 GiB WD1003FZEX
Display(s) Asus VG248QZ 1920x1080 144hz 24" (Current: 60hz)
Case Corsair Air 540
Power Supply Corsair 850W RMi
Mouse Logitech M187 wireless (First day of use 30-9-2021)
Keyboard Logitech K270 wireless
Software Windows 10 21H2 LTSC 2021 / Linux: Candidates: Bazzite - Linux MX - Tuxedo - Kubuntu
^ Oooooooooooooohh!! ..... In all seriousness, Does it actually work??!
