GPU-Z 0.7.9 Detects Cuda not PhysX on GTX 970
7,200 (1.03/day)
Processor AMD Ryzen 7 7700 Raphael \ i5-1135G7 Tiger Lake-U
Motherboard ASRock B650M PG Riptide Bios v. 2.02 AMD AGESA 1.1.0.0 \ Lenowo BDPLANAR Bios 1.68
Video Card(s) Asus GeForce RTX™ 4070 Dual OC GPU: 2325-2355 MEM: 1462| Intel® Iris® Xe Graphics
Display(s) LG UltraGear 27GP850-B 1440p@165Hz | LG 48CX OLED 4K HDR | Innolux 14" 1080p
Software Win11 Pro 23H2 UK | Win11 LTSC UK / Arch (Fan)
I don't know if it's a bug or something but this version detected PhysX fine on my GTX 780 but with 970 it don't do anymore, i even install the new driver today version 344.48 from geforce.co.uk and PhysX was the same version as 344.11
normally i don't have a problem not even on my laptop with Intel HD Graphics and a Nvidia GTX 860M.
W1zzard
Administrator
27,528 (3.70/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
works for me
18,581 (2.72/day)
System Name AlderLake
I'm having the same problem with my GTX770M , not showing PhysX either, yet it is installed.
W1zzard
Administrator
27,528 (3.70/day)
Memory 48 GB
Is PhysX actually working? GPU-Z is behaving like a PhysX app, and tries to create a hardware context.
1,665 (0.33/day)
State College, PA, US
System Name My Surround PC
Processor AMD Ryzen 9 7950X3D
Motherboard ASUS STRIX X670E-F
Cooling Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans
Memory 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30
Video Card(s) MSI NVIDIA GeForce RTX 4090 Suprim X 24GB
Storage WD SN850 2TB, 2 x 512GB Samsung PM981a, 4 x 4TB HGST NAS HDD for Windows Storage Spaces
Display(s) 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD
Case NZXT Source 530
Audio Device(s) Sony MDR-7506 / Logitech Z-5500 5.1
Power Supply Corsair RM1000x 1 kW
Mouse Patriot Viper V560
VR HMD HP Reverb G2
Software Windows 11 Pro x64
Benchmark Scores Mellanox ConnectX-3 10 Gb/s Fiber Network Card
Could this be an issue with Nvidia disabling PhysX because you have a display connected to another GPU, possibly the integrated graphics?
7,200 (1.03/day)
works for me
just updated to version 0.8.0 and PhysX is checked no problem, so dunno if the full support for GTX 970/980 has made a difference:
18,581 (2.72/day)
The integrated graphics on my laptop(Asus G750JX) are disabled by default. Optimus is disabled on my laptop.
7,200 (1.03/day)
PhysX gets detcted fine on my re-branded Clevo laptop, but some parts are missong my GTX 860M maybe bcs it's not active atm i dunno:
12,062 (2.66/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
This may be a silly question, but I have to ask.
Have any of you bothered uninstalling and then manually reinstalling the PhysX by itself? (followed by a restart then reload GPU-Z)
7,200 (1.03/day)
on my desktop i always fully install the Nvidia driver, on my laptop i don't always uninstall it :p
18,581 (2.72/day)
Yes I did but I got some kind of error, I don't remember what it said.
I don't have games that use PhysX, so it's not that a big problem for me.
Maybe if I install a new driver it will display PhysX again in gpu-z
12,062 (2.66/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
Maybe run a driversweep program, restart and run a clean installation of the drivers. I think I have 3 games that use PhysX, but I don't play them either!
cammer78
2 (0.00/day)
Just because this "problem" will be reported again by someone else in the future i bet.. and because i got disgusted seen every ignorant throwing the "install latest drivers" gum-advice for almost every problem, i will recommend somethin simple that might be escaping from users who deal with it.
I have noticed that some users, modify nvcp settings manually, that means that some of them decide also to change the processor used for physx. So....in short, if someone chooses his CPU as physx processor and launch Gpu-z, he will see it unchecked, but if he leaves it on Auto or set his GPU as processor and launch Gpu-z, then by 95% physx field must be checked.
I do not think there is some relative bug here.
Somethin similar could occur for cuda indicator, if one disable it for some specific program.
