GPU-Z muddles up multiple installed driver versions
6,140 (0.84/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
Note the "Driver version" field: I have both 432.00 DCH and 342.01 drivers installed. GPU-Z seems to be reading both driver versions and amalgamating them, which isn't correct.
W1zzard
Administrator
28,243 (3.72/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Hmm how do you have two driver versions installed? One should replace the files of the other
1,100 (0.22/day)
Botevgrad, Bulgaria, Europe
System Name Main PC/OldPC/3rd PC
Processor Intel Core i7-3770K Ivy Bridge/Core i5-3470 Ivy Bridge/Core i3-4330 Haswell
Motherboard ASUS P8Z77-V/ASRock Z68 Pro3 Gen1/ASUS H81M2
Cooling Cooler Master Hyper 212 EVO/Intel Box cooler/Intel Box cooler
Memory 32GB Corsair Vengeance/32GB ADATA/16GB ADATA
Video Card(s) SAPPHIRE R9 290 Tri-X OC 4GB/MSI RX 480 8GB/SAPPHIRE R9 390 8GB
Storage 2x1TB ADATA SSDs in RAID0+3 HDDs/2xCrucial 1TB SSDs in RAID0+3 HDDs/Samsung 1TB SSD+8TB+4TB HDDs
Display(s) Philips 274E5QHAB@HDMI + Philips 273EQH@DVI (both 27")
Case Fractal Design Define R4 Titanium
Audio Device(s) Kenwood Mini HiFi system/Microlab speakers/Philips HDMI (main)+LG TV monitor HDMI + Apple headphones
Power Supply Cooler Master Silent ProM 600 W (modular)
Mouse Microsoft Ergonomic Sculpt Desktop 2.0 (combo)@Razer Goliath mousepad (Medium speed)
Keyboard Microsoft Ergonomic Sculpt Desktop 2.0 (combo)
Software Win10 64-bit (Main PC v.1809 RTM Enterprise/2nd PC v.1903 Insider Preview Pro/3rd PC - same as 2nd)
I am confused, how do you use TWO separate driver versions on ONE PC? :confused: Do you have 2 cards or something?
770 (0.15/day)
Germany
System Name Acer Nitro 5 (AN515-45-R715)
Processor AMD Ryzen 9 5900HX
Motherboard AMD Promontory / Bixby FCH
Cooling Acer Nitro Sense
Memory 32 GB
Video Card(s) AMD Radeon Graphics (Cezanne) / NVIDIA RTX 3080 Laptop GPU
Storage WDC PC SN530 SDBPNPZ
Display(s) BOE CQ NE156QHM-NY3
Software Windows 11 beta channel
Install 432.00 again (or a recent driver), select "experienced user", tick "clean install".
6,140 (0.84/day)
Ikenai borderline!
Mouse Logitech G604
For context: https://www.techpowerup.com/forums/threads/nvs-290-windows-10-and-displayport.263287/
I have an RTX 2070 SUPER for which I manually installed 432.00 DCH. But I removed it to test an NVS 290, and Windows automatically installed 342.01 for that card (the last driver version that supports that GPU). l have now removed the NVS 290 and have the RTX 2070 SUPER running, so 432.00 should be "active" and 342.01 should not be.
Seems like DCH and non-DCH can exist side-by-side.
1,100 (0.22/day)
Okay, if so, just do a full uninstall of all Nvidia drivers with this tool, in Windows 10 Safe Mode:
Then reinstall latest GeForce drivers for your RTX 2070 SUPER. :)
Note: IF you have an AMD CPU or Intel CPU with built-in GPU, and it is not disabled in BIOS, then you may need to reinstall the AMD/Intel GPU drivers as well.
6,140 (0.84/day)
Ikenai borderline!
Mouse Logitech G604
The problem is not that I have multiple drivers installed. The 2070 SUPER works fine.
The problem is that GPU-Z manages to pick up both installed versions in a single version string. That is clearly incorrect.
freeagent
9,822 (4.18/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Bad overclocks can cause all kinds of weirdness. Not saying yours is bad, but just throwing that out there.
770 (0.15/day)
Germany
Memory 32 GB
Trust us, there is only one driver installed.
On a standard Windows you can verify this with e.g.
dir c:\Windows\System32\nvcuda.dll
There will be only one file as result, there cannot be multiple files with the same name in a Windows folder.
If you llook at the properties of nvcuda.dll it will read version 432.00 in details tab.
After a clean install the leftovers from the legacy driver are gone.
I guess the device manager forgot to overwrite a registry entry when you inserted the Turing GPU last time.
That's why tools like DDU have been developed...
3,881 (0.83/day)
I was getting the same thing on my 5700.. Out of curiosity. I disconnected from the internet. Uninstalled, Switched to Safe Mode, used DDU. back to regular. Installed driver. Rebooted. and it still shows up with both.
770 (0.15/day)
Germany
Memory 32 GB
Find the old driver version with RegScanner
Search both 3.4201 and 342.01 (or whatever was the old version number)
6,140 (0.84/day)
Ikenai borderline!
Mouse Logitech G604
Finally remembered about this, screenshot attached shows I'm not crazy.
Note Device Manager: the 8400GS is disconnected and using 342.01, the 2070 is connected and using 445.78. GPU-Z correctly shows the driver details for the 2070, except the bit in brackets in the "Driver Version" field, which shows the incorrect version.
Guys, please stop telling me to uninstall the wrong driver version. That is not the issue here. The issue is that this is a bug in GPU-Z.
1,100 (0.22/day)
Thanks! :) Issue here is this is a fringe, rare case that people will not likely or easily get. :)
I am sure GPU-Z has at least several other major & minor issues, on which work is being done as we speak.
So, due to being a 1-man show work cannot happen on everything at once - minor issues are lower in priority, especially hard to get ones. :)
W1zzard
Administrator
28,243 (3.72/day)
Memory 48 GB
Thanks! Pm sent
W1zzard
Administrator
28,243 (3.72/day)
Memory 48 GB
@Assimilator thanks for letting me teamviewer into your machine.
I found the problem, the issue was some legacy code in GPU-Z that looked for an old NVIDIA DLL that isn't used anymore.
Since you had previously installed the old NVIDIA driver and the new one doesn't come with an updated version for that DLL, the old DLL was still on your system.. GPU-Z picked it up and used it as reference for the NVIDIA driver version number.
All future versions of GPU-Z will now instead use the same source for the version number that Windows Device Manager uses.
