GPU-Z Not Showing Correct VRAM
mutleyman7
4 (0.00/day)
Hi
Currently running a Dell Precision with a Quadro 6000 and Tesla C2075.
Both cards have 6000MB of DDR5 VRAM.
However GPU-Z shows only 5376MB per card.
Any particular reason for this difference?
Thanks for your help.
W1zzard
Administrator
27,988 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
what do you see under advanced -> cuda?
2,750 (0.45/day)
Minnesota
Yes ECC memory. Would that make a difference? Thanks,
*Note: With ECC on, a portion of the dedicated memory is used for ECC bits, so the available user memory is reduced by 12.5%.
(e.g. 6.144 GB total memory yields 5.376 GB of user available memory.)
That could explain it for the Quadro 6000, but ECC is disabled for the C2075.
mutleyman7
4 (0.00/day)
Thanks for that. Just shows you are never to old to learn something new :--))
