GPU-Z numeric PerfCap reasons?
dononelson
3 (0.00/day)
Hi all, newbie to this forum here. I recently started using gpu-z, and decided to log the results to a file. After importing the log into Excel, I found that the PerfCap reasons were numeric. Can anyone translate what reason "0" (zero) is? I know that 16 is probably "Util", but during a session of Crysis 3, it changed to zero. During that time, GPU load was 99%.
Any help is much appreciated.
W1zzard
Administrator
27,439 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Code:
     * Power. Indicating perf is limited by total power limit.
    NV_GPU_PERF_POLICY_ID_SW_POWER = 1,
     * Thermal. Indicating perf is limited by temperature limit.
    NV_GPU_PERF_POLICY_ID_SW_THERMAL = 2,
     * Reliability. Indicating perf is limited by reliability voltage.
    NV_GPU_PERF_POLICY_ID_SW_RELIABILITY = 4,
     * Operating. Indicating perf is limited by max operating voltage.
    NV_GPU_PERF_POLICY_ID_SW_OPERATING = 8,
     * Utilization. Indicating perf is limited by GPU utilization.
    NV_GPU_PERF_POLICY_ID_SW_UTILIZATION = 16,
     * SLI GPUBoost Synchronization.
    NV_GPU_PERF_POLICY_ID_SW_SLI_GPU_BOOST_SYNC = 32,
The value can be a combination of two or more flags, in which case they get added (technically OR'd). E.g.: 18 would be SW_THERMAL + SW_UTILIZATION (2 + 16)
dononelson
3 (0.00/day)
hmmm, then I wonder what zero is? This is a GEForce 660M. Here is a snippet of the log:
W1zzard
Administrator
27,439 (3.71/day)
Memory 48 GB
Zero means no perfcap active
dononelson
3 (0.00/day)
That's interesting - when the card is idle, it has a PerfCap of 16 (Utilization), but when GPU load is 99%, it has no PerfCap active... :wtf:
985 (0.22/day)
Ireland
Performance is limited (capped) due to very low utilization (load).
The card is working on full power, hence it's performance is not capped. Also it means that card is not overheating, no being over-volted and so on.
