GPU-Z readings are strange - bug?
44 (0.02/day)
London, UK
System Name Custom Water-cooled Server / Desktop
Processor Dual Intel Xeon E5465 / i5-11400
Motherboard Asus Z8NA-D6 / Prime H570-plus
Cooling Custom built: DangerDen MC-TDX / H100i
Memory 24GB DDR3 / 16GB DDR4-3200
Video Card(s) GTX470 / RTX2080
Storage SSD + 1TB HDD / P5-Plus + BX500
Display(s) BenQ GW2765 1440p
Case CoolerMaster Full Tower / Cosmos
Power Supply PC Power & Cooling 750w (both)
Software Ubuntu / Windows 11
I have the EVGA RTX 2080 XC Gaming and been using it for Folding and I am getting some strange results - is it X1 or GPUz that is correct?
With 1920 OC in X1 - why does GPUz show same clocks as stock in main screen for GPU Clock?
If I reduce the OC to 1635 then it shows clocks are lower than stock?
Am I reading this wrong or any ideas?
Thanks.
newtekie1
Semi-Retired Folder
28,473 (4.09/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Apparently X1 is giving you the max boost for the clock speed, and I think 1920 is actually the stock max boost for that card not an OC. While GPUz is showing you the "standard" boost clock, not the maximum. I think that is pretty standard for GPUz, because it always shows a lower clock speed for the boost on the first tab than what my cards actually boost to.
W1zzard
Administrator
27,957 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
It's normal that way. The rated boost that you see listed in gpuz and mfgr specifications is a very conservative value, actual boost will almost always be higher, but there is no way read/detect it without fully loading the card and it varies too
44 (0.02/day)
London, UK
Thanks for the replies - I guess this is something new for me and maybe I didn't ask the right question above. I understand your point that it is Boost and not OC, but why are the clock speeds different on the two screens (main and sensors)?
newtekie1
Semi-Retired Folder
28,473 (4.09/day)
Indiana, USA
We both answered that question. The "rated" boost listed on the first tab is a conservative number, the actual boost is almost always higher. AFAIK, this is just the way nVidia does their rating and how GPUBoost works.
19,371 (3.54/day)
One is a REALTIME clock speed with boost (sensor tab), the other is the minimum rated boost (mfg specification like w1z said) for the card and a static value read from the card.
9,503 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
The boost figure is just an "average" or "likely" figure that Nvidia figured they should list. It's doesn't mean anything in particular.
44 (0.02/day)
London, UK
Thanks for the replies - I think I understand it now.
I removed EVGA Precision X1 and installed MSI Afterburner. Now it makes more sense having done the OC Scanner and played with the sliders.
It has been a while since I had a Geforce card.........
