GPUZ-Low Power consumption/power utilization?
217 (0.03/day)
Mataram-NTB, Indonesia
System Name Folding System
Processor Ryzen 5 5500
Motherboard ASRock B540 Steel Legend
Cooling EK Clean CSQ WB + EK CoolStream RAD XTX 480 + Swiftech D5 Pump
Memory 4 x 8 GB DDR4 HyperX Fury
Video Card(s) Zotac RTX 3070 8Gb Twin Edge OC
Storage Team MP33 NVME 1TB | 4x Seagate 4TB Raid 0
Display(s) Titan Army 27G1 IPS 2K 144Hz
Case Corsair 900D + 1 Aerocool 14cm Fan, 3 CM Fan 12cm, 4 Scythe Slim Fan 12cm, 4 Corsair Fan 12cm
Audio Device(s) ASUS Xonar Phoebus + Hippo cri head amp + Sennheiser HD 598 + Razer Megalodon
Power Supply Seasonic P1000 Platinum
Keyboard Logitech G910 Mech Keyboard
Software Windows 11 Home
Hi guys,
About 10 days ago i noticed low fps while gaming in my PC, after checking and reinstall driver i found out from GPUZ sensor that my first 780Ti only run 30-46% TDP.
I have tried disable SLI and run with 1 GPU only but the max TDP usage still less than 50%, i also tried several version of older driver to the latest. even when i use burning/benchmark utility the TDP usage still low but the GPU load is full, the second 780Ti works normally and able to reach 99-100% TDP with full load.
The first GPU
The second GPU
both GPU cooled by custom watercooling setup.
any suggestion what may cause it? Thank you for the help guys.
