- Sep 10, 2005
- 27 (0.00/day)
Hello I was trying to understand what is the best configuration to play with my OLed TV at 120Hz compatible Gsync
If I keep the 60Hz, 60fps, Gsync active and Vsync active video games are fluid, I only have problems when active the frame generator and I have to play full screen window (in fullscreen the games play at 30fps)
If I put the 120Hz, 60fps, Gsync Active, Vsync deactivated the video games are fluid but not like when I keep the 60Hz, in this situation I have no problems with frame generator
What is the best configuration in your opinion? Generally I put the Cap to the FPS because the 60 frames do not mind, I don't see great difference in using the more frames and getting the GPU to warm up and consume more
What do you think?
What do you think?
