GT 630 Problem
xicotripa
3 (0.00/day)
I have a GT 630 of 2gb and it after using more than 1GB of VRAM starts to present distortions in games, being impossible to play. I googled it and it looks a lot like the specs of a 1gb gt 630.
I've already installed several different drivers, changed thermal paste and cleaned the pci express contact. nothing resolved now, does anyone have any suggestions? GPU Z:
Ícone Verificada pela comunidade
1,890 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
Can you take it apart ?
VRAM chips and GPU die photos (with focus on text), would be helpful.
xicotripa
3 (0.00/day)
VRAM Chips
K4W2G1646C-HC11​
THE die chip is
34N3A7 1133A1 N4T067 01V​
the part showing the ''gf xxx xxx xxx'' is scraped off
seems to be a gt 540m chip
120 (0.10/day)
System Name Black Diamond
Processor AMD Ryzen 5 3600X 6-Core Processor 3.80 GHz
Motherboard msi a320 a pro max
Cooling Default
Memory 32 GB ddr4 3200mhz
Video Card(s) Rtx 2070, 86 F no extra fans or stuff.
Storage nvme samsung (the fastest one) 1tb
Display(s) Some sceptre monitor and a tv
Case rosewill
Power Supply rosewill
Mouse Verbatim
Keyboard Magic wings
Software Lots
Benchmark Scores IDk
I've already installed several different drivers, changed thermal paste and cleaned the pci express contact. nothing resolved now, does anyone have any suggestions? GPU Z: View attachment 206638
Things usually happen with a card that old bud :)
Toothless
Tech, Games, and TPU!
9,567 (2.47/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Sounds like a fake card, to be honest. Have you tried benching it to other 630's?
No, it doesn't happen after hitting X amount of vram usage.
41,882 (6.61/day)
630 ain't exactly a gaming card to begin with.
Gddr3 2G
X16
VRAM Chips
K4W2G1646C-HC11​
THE die chip is
Pull the card apart, get pics of die and ram chips front to back of card please
1,978 (1.55/day)
Lithuania
System Name Shizuka
Processor Intel Core i5 10400F
Motherboard Gigabyte B460M Aorus Pro
Cooling Scythe Choten
Memory 2x8GB G.Skill Aegis 2666 MHz
Video Card(s) PowerColor Red Dragon V2 RX 580 8GB ~100 watts in Wattman
Storage 512GB WD Blue + 256GB WD Green + 4TH Toshiba X300
Display(s) BenQ BL2420PT
Case Cooler Master Silencio S400
Audio Device(s) Topping D10 + AIWA NSX-V70
Power Supply Chieftec A90 550W (GDP-550C)
Mouse Steel Series Rival 100
Keyboard Hama SL 570
2,100 (0.48/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
Doesn't meant that it should have problems like these.
No, but you have to ask yourself, "is it really worth screwing with?", when there are much better cards out there dirt cheap.
This is typical of a 'faked' card.
1,978 (1.55/day)
Lithuania
System Name Shizuka
Sure, why not? It's not like it needs any expensive repairs it seems.
41,882 (6.61/day)
Yup tons of 450 gts here that appear as 1050s, 960s etc.
With the memory above which shows as samsung actually. 2Gibibits per chip is 0.25 GibiBytes. If thrre are only 4 chips on the card then it is 1G, if there are 8 then it is 2G.
From the ram decoding it appears it is 4 banks which to me is 1GB.
Open gpu-z again, click arrow next to uefi check box and attempt to upload the bios to the vga bios collection/database throuhh the program itself, you may be warned that bios is already in database with alink, copy and paste link here.
From bios version number it appears as this.
