Gta 5 how do you cap fps at 60 without vsync??
Joseph Ratcliffe
3 (0.00/day)
When I play gta 5 i get about 80-100 fps but there is massive stuttering but when i turn on vsync at a solid 60fps it is fine but it does go from 60-59 which causes stutter so is there a way to cap at 60 without vsync???
6,881 (1.43/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
-frameLimit 1
in a text file called commandline in games dir
cdawall
where the hell are my stars
27,683 (4.06/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
gsync and freesync if you have a nice monitor or turn of vsync. It isn't going to be perfect, but that's how -framelimit works anyway.
798 (0.21/day)
Processor I5 4690K @ 4.8 Ghz
Motherboard Gigabyte Z97X Gaming 7
Cooling Swiftech H140X
Memory 16GB Crucial BallistiX 1866Mhz
Video Card(s) GTX 1070 G1 Gaming
Storage 850 PRO 1TB SSD, 840 EVO 500GB SSD, 850 EVO 500GB
Display(s) Nixeus EDG 27-Inch IPS 1440P, 144HZ 16:9
Case NZXT H440 Red/Black
Mouse G600
Keyboard G710+
Software Win 10 64B
-frameLimit 1
This works, however Its a bit odd that this game file isn't pre-created in the game directory.
I personally use Afterburner (Rivatuner) to limit my FPS to 59.
Either works just fine.
Also too, the game seems to run better with the In-game VSYNC disabled, and force enabled through the NVCP - assuming your using a Nvidia card.
49 (0.01/day)
System Name Lynn
Processor Intel Core i7 860 @ 4.0Ghz LGA1156
Motherboard ASUS P7P55 LX Intel P55 Express LGA1156 DDR3 ATX
Cooling Cooler Master Hyper 212 EVO
Memory 24GB DDR3 G-Skill Ripjaw X-Series
Video Card(s) XFX RX480 8GB GDDR5
Storage 250B SSD for Windows 500gb for Steam 100GB SSD for Origin games 150gb HDD for school
Display(s) Acer 24in 1080p + HP 19inch 1080p
Case NZXT S340 Mid Tower Matte Black/Blue
Audio Device(s) N/A
Power Supply Cooler Master 750w
Mouse Razer Deathadder Chroma
Keyboard Razer Blackwidow Chroma
Benchmark Scores Never benchmarked but it's good
If you have the Steam version of the game, open Steam (I think that is the only version) then right click on the game and go to Properties. Now click on Set Launch Options. You are going to want your fps cap to be double your (monitor refresh rate x 2)+1. For example, if you have a 60hz monitor you would want a 121fps cap. Anyways now in the Set Launch Options box you will want to type in "fps_max *Desired fps limit*"
798 (0.21/day)
Mouse G600
Keyboard G710+
Software Win 10 64B
Not sure where you got that info.
The refresh rate is the amount of frames the monitor can render at a time. 60 hz = 60 fps max. I like to sit 1 fps below at 59fps
18,584 (2.65/day)
System Name AlderLake
I use nvidia inspector to cap the fps, which works well for me!
cdawall
27,683 (4.06/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
49 (0.01/day)
System Name Lynn
Audio Device(s) N/A
I don't understand why all these people have frame issues this has never happened to me...
qubit
Overclocked quantum bit
17,865 (2.83/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Don't forget that the framerate will drop below 60fps too sometimes and then you will see stutter. Make sure that you have the latest Windows updates and especially the video driver is the latest one. Dropping quality settings will increase the fps that the card is capable of and help to keep the minimum above 60. You're best off doing this and turning vsync back on.
