GTX 1050 Ti PerfCap Vrel
Mike17
6 (0.00/day)
there is something I do not understand and I do hope there is somebody who is able to enlighten me ...
I ran a GTX 1050 Ti using an older mainboard and a not very powerful powersupply. The problem was, that despite the GPU load was at some 50 percent, PCIe Slot Voltage went down to slightly above 2 volts and PerfCap got active showing Vrel.
Well, I got myself a new mainboard and a new 750W powersupply, but the problem did not go away.
I do not understand why the GTX 1050 Ti ends at 50 percent GPU load. Shouldn't it be able to run up to 100 percent?
And why is that voltage dropping down? And what voltage is meant? The one of the PCIe 16x slot? The one of the 6-pin connector? I already measured the voltage at the 6-pin connector using a DMM and it showed some 12 volts, even with old and weaker power supply.
Thanks in advance.
1,838 (0.35/day)
London
System Name Jaspe
Processor Ryzen 1500X
Motherboard Asus ROG Strix X370-F Gaming
Cooling Stock
Memory 16Gb Corsair 3000mhz
Video Card(s) EVGA GTS 450
Storage Crucial M500
Display(s) Philips 1080 24'
Case NZXT
Power Supply Enermax 425W
Can we have your system specs please?
Mike17
6 (0.00/day)
Well ...
FreedomEclipse
~Technological Technocrat~
23,751 (3.75/day)
London,UK
System Name Codename: Icarus Mk.VI (Soon to be retired)
Processor Intel 8600k@Stock
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G502 X
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
Mike17
6 (0.00/day)
I was under the impression that GPU-Z provided all required data.
But of course there is nothing about the mainboard which is a ASUS ROG STRIX Z270F.
18,515 (2.72/day)
System Name AlderLake
Toothless
Tech, Games, and TPU!
9,472 (2.49/day)
Washington, USA
System Name Veral
Processor 5950x
Motherboard Asus Crosshair VIII Hero Wi-Fi
Memory 2x16GB G.Skill TridentZ
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Mate we can't help you unless you tell us EVERYTHING you have in that case and monitor.
Mike17
6 (0.00/day)
Well, I do not think that RAM and CPU are involved in supplying electrical power to the GTX 1050 Ti and considering the fact that I told you that the GTX 1050 Ti caused the very same problem in a totally different system (which excludes all components from being the cause of the problem), but ...
- power supply: 750W
- mainboard: ASUS ROG STRIX Z207F
- RAM: 2 x DDR4 8GB (PC4-29800)
- CPU: Intel Core i5 6400 2.7 GHz
- storage: Samsung M.2 SSD 850 EVO 256 GB
- GFX: GTX 1050 Ti 4G
Now, there is nothing more in that case except for the cables and air.
The monitor is 1680 x 1050 and is connected via HDMI.
Anything I might have forgotten?
31 (0.02/day)
UK
System Name Cube
Processor R5 3600 @ 4.325
Motherboard MSI B450m Mortar Max
Cooling Arctic Freezer 34 esports duo
Memory 4x8gb Ballistix @ 3733c15
Video Card(s) XFX 6700 XT Merc 319 Black
Storage WD SN750 500gb, Samsung 850 Evo 500gb
Display(s) Gigabyte M27Q
Case Thermaltake Core V21
Audio Device(s) Edifier R1700BT
Power Supply Corsair SF600 Platinum
Mouse Mionix NAOS 7000
I had Vrel issues on my gtx 1060 when it was overclocked, now it's undervolted and I don't get the issue anymore.
Mike17
6 (0.00/day)
Hi, I'ld call this an interesting hint, but I didn't configure any overclocking. In fact this PC was set up from scratch, just Windows, drivers and stuff the games brought with them. Maybe the GTX 1050 Ti is overclocked by default? But it would be senseless if it throttles itself at some 50 percent GPU load.
Mike17
6 (0.00/day)
To be honest I was hoping for - erm, a bit more. In fact I thought that those who write GPU-Z were able to tell without thinking to what PCIe Slot Voltage refers to and why it might go that down on a quite actual mainboard by using a graphics card that is way behind the power consumption of more recent ones. Well, maybe I'll stumble about the necessary piece of information by chance. Best and CU.
