GTX 1050 Ti problem
zara
4 (0.00/day)
Hi i have just got a GTX 1050 TI , problem i got is the fans start when pc first boots up then their stop about 10 seconds later i have all the latest drivers installed , could you please help me
, thank you ps it does not have the 6pin power connecter
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
Read the manual. I think they only run when needed
Or run a bench test like Heaven 4.0 and watch the temps
A GTX 1050 TI should have a power connector. What card is it ?
229 (0.09/day)
Australia
Processor Intel Core i7-13700KF
Motherboard GIGABYTE Z690 AORUS ELITE
Cooling Dark Rock Pro 4
Memory G.Skill Ripjaws DDR4-4000 32GB (4x8GB)
Video Card(s) ASUS TUF Gaming Radeon RX 7900 XT OC Edition 20GB GDDR6
Storage Various
Display(s) GIGABYTE M32U 4K 144hz
Audio Device(s) External Amp
Software KDE Neon
May depend on which brand it is, and whether it has the fan stop feature. If so, the fans should kick in when the gpu reaches 60-65c. Below this they don't spin. Check.
zara
4 (0.00/day)
Photo of the box
12,340 (2.21/day)
Oregon
Photo of the box
Yea I may be wrong about the power cord. I have an EVGA I thought it had a power cord maybe not. I have too many cards
Install EVGA Precision and see if you can set the fan to 100%
zara
4 (0.00/day)
Just run the Haven benchmark and my fans kicked in at 60c , so could i lower that or is that the right temp for fans to kick in , so a big thank you for all your help
12,340 (2.21/day)
Oregon
No, you are good. Just leave it
14,541 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Display(s) DELL U2311H
Keyboard Microsoft Wired 600
The Gigabyte website doesn't make it clear these cards have the fan stop feature, but they do mention "semi passive 3D active fan" in their description under key features.
Gigabyte it should never add this feature with a basic cooling system in use, actually and MSI follow the wrong path at low cost cards and they are now MINI ovens.
ASUS did it right at the latest 1660 Super DUAL EVO & Also at DUAL MINI OC, at 55C the fan kick in and 66C this is target temperature for gaming.
It took me two weeks of research so to discover the truth.
