GTX 1060 OC
1 (0.00/day)
Processor Intel Core i5 6500
Motherboard MSI H110m PRO-VD
Memory 2 x 4 GB DDR4 HyperX Fury
Video Card(s) Gainward GTX 1060
Power Supply XFX TS-550W 80+ Bronze
Mouse Roccat Lua
Keyboard VicTsing Mechanical - blue switches
Seen people get higher overclocks, but rising the memory clock any further gives me green pixel artifacts.
Rising core clock also crashes either the stress test or my screen goes black.
Overall, I'm pretty happy with the overclocking capabilities of this card.
Stressed with MSI Kombustor (FurMark), which other stress testing software do you recommend?
1,269 (0.34/day)
Birmingham UK
System Name El Calpulator
Processor AMD Ryzen R7 7800X3D
Motherboard ASRock X670E Pro RS
Cooling ArcticCooling Freezer 3 360ARGB AIO
Memory 32GB Corsair Vengance 6000Mhz C30
Video Card(s) MSI RTX 4080 Gaming Trio X @ 2925 / 23500 mhz
Storage 5TB nvme SSD + Synology DS115j NAS with 4TB HDD
Display(s) Samsung G8 34" QD-OLED + Samsung 28" 4K 60hz UR550
Case Montech King 95 PRO Blue
Audio Device(s) SB X4+Logitech Z623 2.1+Astro A50 Wireless
Power Supply be quiet! Pure Power 12 M 1000W ATX 3.0 80+ Gold
Mouse Logitech G502X Plus LightSpeed Hero Wireless plus Logitech G POWERPLAY Wireless Charging Mouse Pad
Keyboard Logitech G915 LightSpeed Wireless
Software Win 11 Pro
Benchmark Scores Just enough
Imo the GPU clock is way to high and that is why you're getting those problems
9,642 (3.28/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
You are pushing your memory too far most likely , artifacting on Pascal is usually related to memory clocks. Most 1060s can do +500mhz plus on the memory and few up to 700mhz ( mine does +700 for example) , so nothing unusual there you were a tad unlucky.
If you want higher clocks maybe try setting a custom voltage/frequency curve in afterburner and set the voltage limit to 100%. Not guaranteed to give you higher clocks but in my case it allowed me to get an extra ~100mhz.
None , just play games. AND STOP USING FURMARK !
Not necessarily , my 1060 runs up to 2164mhz and doesn't crash/artifact , also those clocks reported by the specs page on GPU-z are inaccurate , you can't tell how high it goes in actual games.
1,269 (0.34/day)
Birmingham UK
Software Win 11 Pro
18,584 (2.67/day)
System Name AlderLake
9,642 (3.28/day)
Case Phanteks NV7
1,269 (0.34/day)
Birmingham UK
Software Win 11 Pro
Yes ,but you cannot determine that by just looking at the specs page on GPU-Z , that's what I meant to say.
Ok I understand.
OP,what OC software do you use? Take a screenshot of that software and upload it here. Also it would be very useful to know temps as well as the case you're using and if you have a decent airflow :)
88 (0.03/day)
System Name Xena
Processor 2x X5660 2.8 Ghz
Motherboard Tyan S7010
Memory 48 GB DDR3 1333Mhz ECC registered
Video Card(s) Gigabyte GTX 660 ti windforce
Storage 3 TB WD red
Case MaxData platinum 500
Power Supply Chieftec APS-850CB
Software Win 7 X64 ultimate
cdawall
where the hell are my stars
27,683 (4.09/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
My zotac short pcb1060 35th cards all do +200mhz core (22xx boost) and +800mhz memory. Those clocks seem rather low, but it could just be a junk card.
What's bad with furmark, it's great stability test for GPU
Not really all of the aforementioned programs are automatically throttled to low power 3d clocks. So all you are doing is creating useless heat. It doesnt test peak clocks at all as the card will bever reach them. May as well downclock your cpu and run prime95 to sww how it does with an overclock.
OneMoar
There is Always Moar
8,802 (1.63/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
the 1060 benefits more from memory clock
yours has Samsung memory it should easily be hitting +500 on the memory
core clock peaks between 2100 and 2200 are not unheard of
and furmark blows cards up do not use
9,642 (3.28/day)
Case Phanteks NV7
Go ahead and keep using it , it will be your VRMs that will blow up not ours.
You get 0 extra information about stabilty , Furmark is like prime95 but with an extra chance to start a fire.
I am exaggerating but you get the idea , don't use it.
43,342 (6.75/day)
Do not furmark the card.
Stability testing is any gpu based benchmark out there
2,707 (0.74/day)
On The Highway To Hell \m/
In a recent vid I heard der8auer say he runs Prime95 and Furmark at the same time to verify OC stability for the pre-built overclocked systems he tests for sale by Caseking.
Check the vid between 10:28 and 11:37
Anyway. All the shit talking about Furmark just makes me laugh. How many of you have actually killed a card with Furmark? How much sense does it make that MSI would contribute to the development of/sponsor, advertise with their name on, and release a piece of software through downloads on their website that is going to kill graphics cards? Kombustor is Furmark! Are they just hoping and wishing to be sued? Do they make more money through the RMA process of all their customer's cards that Kombustor kills? Is it that only MSI graphics cards are safe to run Kombustor/Furmark? Why is the latest version of Furmark now in the TPU downloads section? I mean it's going to kill graphics cards right? Yeah...not very damn likely. :shadedshu:
9,642 (3.28/day)
Case Phanteks NV7
It's more than that , Furmark stresses the GPU so much that it is guaranteed to throttle. As a stability test it is essentially useless for modern cards , you never get to run the card at it's peak clocks for extended periods of time.
It's not just Furmark , it's all of these benchmarks. Best way to find out how the card behaves when you use it is to test it with what you actually use , not a synthetic benchmark.
And it does kill cards , especially older ones that don't throttle , rarely but it does. Guess what most new cards can actually detect when you run Furmark (or programs that are alike ) and automatically throttles the card , I wonder why ?
Yeah , not damn likely , but possible.
Like I said , most recent cards detect at a driver level when a load like the one Furmark produces is applied and automatically throttles the card , he is wasting his time by using it.
All in all , useless piece of software that has spawned and is still spawning issues when it shouldn't have been the case.
88 (0.03/day)
System Name Xena
Storage 3 TB WD red
One big zero: 0
and if you ask how many cards i tried with furmark- more than 100
yes, it's set of different tests similar to furmark, and one of them fury donut
Why - to ppl test it's own cooling solutions (factory or custom) on their graphics cards
There is reason why it throttles and it is normal in that extreme usage
If graphics card pass synthetic benchmarks well (without crashing , system restart,etc.) it will work in any game very well, because games are not pushing card to the limits like synthetic tests does
OneMoar
8,802 (1.63/day)
Rochester area
One big zero: 0
you are wrong and dangerously so and blocked
8,226 (2.14/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
I love arguments like this **POPCORN** :D
9,642 (3.28/day)
Case Phanteks NV7
So what exactly are you looking for when you run it if you know what it will do ? :kookoo:
You are just simply wrong. It might have been somewhat true and useful in the past but nowadays it isn't.
You don't understand how clocks work on recent GPUs , if you did you'd know that running Furmark is a waste of time if you want to check for stability. Different levels of voltages are tied with frequency steps and also to power consumption and temperatures . When the card throttles because of those two last parameters so do the voltages and subsequently the clocks. But only the voltages and clocks are what dictates stability , not the temperature and power consumption which is all that Furmark is pushing for.
When you check for stability you want to know what happens when both voltages and clocks are it's peak. You can run Furmark all day and it wont crash , yet as soon as you will start to play a game that isn't pushing the card as much and the clocks reach it's peak it will.
Not to mention that every application applies a different type of workload , sometimes it might be fine , other times not. It's doesn't matter if that application is a "benchmark" or a "game". I stand by my opinion , you test for stability with what you use.
8,226 (2.14/day)
SE Michigan
System Name Dumbass
Yaa but.....(just for the sake of saying it, cuz someone wants to :D) "If the card is too hot, its not gonna be stable"
9,642 (3.28/day)
Case Phanteks NV7
cdawall
27,683 (4.09/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
Any modern card with throttle clocks before temperature is in that threshold
88 (0.03/day)
System Name Xena
Storage 3 TB WD red
Graphics card maximum temperature,because in games it will never reach that high
Exactly, i use it mostly for older GPU's
Thanks for info
43,342 (6.75/day)
The ignorance in here is strong.
You use furmark and your card dies, expect a verbal lashing for stupidity.
7,346 (1.04/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
Am I the only one who remembers what @W1zzard writes under Overclocking in all his reviews???
W1zzard said:
Every sample overclocks differently, which is why our results here can only serve as a guideline for what you can expect from your card.
U can't except all cards to overclock the same, but if u look around and check like EVGA SuperClock cards, MSI Gaming cards with their overclocked speeds and some other vendors with their features for overclock they don't do anything massively mby around 100-150mhz on the core because all cards can basically do that.
Nvidia GTX 1060 6GB FE core clock 1506 mhz
EVGA GTX 1060 6GB SC core clock 1607 mhz
EVGA GTX 1060 6GB FTW core clock 1620 mhz
EVGA GTX 1060 6GB FTW+/2 core clock 1632mhz
that's around 100/132mhz every card can do that without much tweaking and most of the cards without any voltage adjustment and in a case with decent air u can get even more, with Boost 3.0 it doesn't not only require volt or temps but a mix.
again @W1zzard made a great review: https://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_1080/29.html
