GTX 1080 will not downclock. Stuck on 1633Mhz core clocks
227 (0.07/day)
Manchester, UK
System Name Full LC'd Node 202 || Asus X202e
Processor i7-7700K || i3-2365M
Motherboard Asus Z270I || HM76 int.
Cooling Full Custom Loop|| Stock
Memory Hyper Fury DDR4 32GB || 4GB 1333
Video Card(s) GTX 1080 FE || HD3000
Storage 950 Pro M.2 +WD 2TB M.2 SSD || Sandisk 256 SSD
Display(s) Asus MG278Q
Case Fractal Node 202
Audio Device(s) OnBoard
Power Supply Corsair SF600
Mouse Logitech G502 ||Asus WT710
Keyboard Logitech G410 || Logitech K830
I apologise if this is the 1000th time this has been posted but I couldn't find any existing threads regarding this matter.
As the title says, my card will not return to it 139/405Mhz clocks, even after a restart.
What I've tried:
Fresh Windows 10 install but Win OS installed 388.13 drivers. So I DDU'd, set for windows update not to pull down drivers and installed the latest, 419.35 but the problem still persists. I also flashed the BIOS, DDU'd and reinstalled the latest driver.
What I've found works temporarily till I launch a GPU intensive task (gaming) is going to device manager and disabling and re-enabling display driver. I'm looking for a permanent fix.
Is this a bug?
p.s I've updated my System Specs
8,086 (1.35/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
Is there any load on the card?
227 (0.07/day)
Manchester, UK
847 (0.36/day)
Haswell, USA
System Name Bruh
Processor 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv |
Motherboard Z490 TUF Wifi | Apple QMS180 |
Cooling EVGA 360MM | Laptop HS |
Memory DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 |
Video Card(s) Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)|
Storage Many SSDs, ~24TB HDD/8TB SSD
Display(s) S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017
Case NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced
Audio Device(s) Lol imagine caring about audio
Power Supply 850GQ | Apple 87W USB-C |
Mouse Whatever I have on hand + trackpads (Lanchead TE)
Keyboard HyperX Origins Alloy idk
Software W10 20H2|W10 1903 LTSC/MacOS 11
Benchmark Scores No.
What power plan?
And (not trying to be rude, so excuse me) but why does it matter?
41,966 (6.61/day)
2 monitors or 1?
2,899 (1.15/day)
Buenos Aires, Argentina
System Name System V
Processor AMD Ryzen 5 3600
Motherboard Asus Prime X570-P
Cooling Cooler Master Hyper 212 // a bunch of 120 mm Xigmatek 1500 RPM fans (2 ins, 3 outs)
Memory 2x8GB Ballistix Sport LT 3200 MHz (BLS8G4D32AESCK.M8FE) (CL16-18-18-36)
Case NZXT Source 210
Power Supply Corsair CX650M
Benchmark Scores Corona 1.3: 3120620 r/s Cinebench R20: 3355 FireStrike: 12490 TimeSpy: 4624
I take it you already tried to reset the clocks through other programs, like MSI Afterburner?
I think we both know people here that would pay for a card that can't or won't downclock :laugh:
However, it is still a problem, besides the energy waste, the card's life span could be shortened... Sadly.
847 (0.36/day)
Haswell, USA
System Name Bruh
It's not going to be shortened by a amount that would matter, but I do see the energy thing coming into play.
Have you checked window's power plans?
@/OP
Try low power/balanced
841 (0.16/day)
Edmonton, AB, Canada
System Name Project Neverending
Processor i9 9900K @ 5.0GHz
Motherboard Asus Maximus Formula XI
Cooling Corsair HX 150i Pro, Corsair ML 120/QL 120 fans
Memory 32 GB Corsair Vengeance Pro RGB 3200
Video Card(s) Asus RTX 2080Ti
Storage Samsung 970 Evo NVMe, 2 Samsung 860 Evo 1TB
Display(s) Acer Predator X34 (3440X1440), Samsung U28D590 (3840X2160)
Case Lian Li 011 Dynamic XL
Audio Device(s) Supreme FX X-Fi, Logitech 5.1 speaker system
Power Supply Corsair HX 1000i
Mouse Logitech G703
Keyboard Logitech G105
Benchmark Scores Updates coming soon ®
If you've got more than one monitor connected nvidia cards don't drop to 2D speeds. There's millions of threads on numerous forums, most fixes I've tried don't work. My 1080 sli setup never dropped clocks in multi monitor, and neither does my 2080Ti.
41,966 (6.61/day)
Yup its because gpus cant handle multi monitor with clocks being too low
584 (0.26/day)
https://www.guru3d.com/files-details/nvidia-inspector-download.html
Find "Multi display power saver" on right click above the "Show overclocking" button.
[X] check your GPU, [X] check "Activate Full 3D by GPU usage" with 30% threshold.
Also add the games that you play to the list so GPU clocks up as soon as you start it (so it doesn't depend on usage, which might on occasion cause stuttering)
They can handle them just fine.
This is just Nvidia being Nvidia.
I have 4 monitors on one 1080, two of them are QHD and above, for a total of over 8000 x 1920 pixels.
Been working like this since I bought the card 2 years ago, and surprise, it works perfectly with 139 Mhz CORE and 101 Mhz MEM:
7,412 (2.79/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
never had problems with it,it's downclocking fine.
but agree it's been a pain in the ass for many users apparently.
FireFox
The Power Of Intel
7,507 (1.92/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
I have used multi Monitors for a long time and it worked without issues downclocking the GPU to 139MHz, I remember having the issue that the GPU didn't return to low clocks but that was with one monitor, the issue was some setting in Nvidia Control Panel ( Manage 3D Settings )
584 (0.26/day)
Obviously Orbmu2k who coded NVIDIA Inspector created the specifically named "Multi Display Power Saver" tool because there is a problem. Not because he was bored and had nothing better to do with his or her life.
It's a very known problem that has existed long before Pascal cards, I think since the age of Fermi ( 400 series ), but it might be even older, I don't really know.
I for one certainly had it with Maxwell. Before that I used a Radeon 7970 GE card which did downclock with multi-monitors no issue. And before that card I only had one monitor so no personal experience.
1,042 (0.34/day)
Pristina
System Name My PC
Processor 4670K@4.4GHz
Motherboard Gryphon Z87
Cooling CM 212
Memory 2x8GB+2x4GB @2400GHz
Display(s) HP envy 32 1440p
Case CM Mastercase 5
Audio Device(s) Sbz ZXR
Power Supply Antec 620W
Mouse G502
Keyboard G910
Software Win 10 pro
His monitor is 144Hz maybe if he sets it to 60Hz it will downclock?
FireFox
The Power Of Intel
7,507 (1.92/day)
Germany
If he sets it to 60Hz It will downclock, personal Experience.
227 (0.07/day)
Manchester, UK
2 monitors or 1?
Single monitor.
@/OP
I’ve tried changing power plans in Win OS and NV control panel, rebooting in between. No joy
Not sure why I’ll buy a 144Hz monitor and run at 60hz. Dropping to 120hz made no difference.
View attachment 118550View attachment 118551
What driver version?
Only have 1 connected.
FireFox
The Power Of Intel
7,507 (1.92/day)
Germany
Thats wasn't my suggestion i was just confirming to @kastriot that he was right.;)
227 (0.07/day)
Manchester, UK
What power plan?
It uses more power running at higher clocks whilst idling and runs warmer. I’d rather it didn’t.
I’ve tried all 3 plans.
41,966 (6.61/day)
Contact card maker and nvidia
430 (0.08/day)
Belgium
System Name Illidan
Processor AMD Ryzen 9 5900X
Motherboard Gigabyte B550 Aorus Pro V2
Cooling Scythe Mugen 4
Memory G.Skill Trident Z 32GB DDR4 3000MHz 14CL
Video Card(s) AMD Radeon RX 6900 XT
Storage Crucial P1 1TB + Sandisk Ultra II 960GB + Samsung EVO Plus 970 2TB + F3 1TB + Toshiba X300 4TB
Display(s) Iiyama G-MASTER G4380UHSU-B1
Case Corsair 750D Airflow
Audio Device(s) Sony WH1000-XM4
Power Supply Seasonic Focus PX-850
Mouse Logitech G604
Keyboard Corsair Vengeance K70 (Cherry MX Red)
That problem was (should have been?) fixed since Kepler series. My GTX1080 is downclocking to 139MHz atm.
Did some digging, lots of different setups still have it. Guess it's just really bugged :-D
7,252 (1.03/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
It's a known problem with 144hz on Nvidia cards that they don't downclock to idle when running 144hz but if you lower your refresh rate to 120hz then a lot of users report normal idle clocks.
I run 165hz on my screen never had a issue so investication shows it's only at 144hz not more or less.
227 (0.07/day)
Manchester, UK
Seeing as only restarting my GPU resolved the issue. Use a script to restart Device adapter at log on.
22,385 (6.03/day)
Take a look at your (if any) OC then as well, because Afterburner for example applies overclocking at startup. That might influence your script, you may want to have it start it up AFTER resetting the GPU.
227 (0.07/day)
Manchester, UK
I’ve delayed script to start up after MSIAB launches that seems to work fine. Will keep an eye on it. MSIAB doesn’t seem to like being delayed.
I run GPU at stock speeds and undervolted.
You were right, MSIAB profile isn’t active that way. I can’t get MSIAB to delay launch.
7,252 (1.03/day)
@EdInk it's didn't sound right you need to restart your
Graphics card to make it idle at what frequency us you running your monitor at¿
Plus have you tried running DDU and totally reinstall your Nvidia driver¿
