GTX 1080Ti crashing at 1940 Mhz
trinxo
6 (0.00/day)
Spain
Last month i bought a second hand gtx 1080ti (msi armor oc), i did some test and the card performed well (average with other stock gtx 1080ti by userbenchmark) , i also bought a 4k monitor and i wanted to overclock the card for extra fps (needed in 4k, nowodays games are design to work with dlss).
My surprise comes when i saw that i coud only do a +60 core overclock with the power limit set the highest (117). If i try +70 kombustor stress test crash in seconds. All of this with no memory overclock. This card is well-known to rich high tempertures so when i amb playing the frequency starts at 1920-25 and drops below 1900 as the temperature get high.
More interesting here is that the power limit do almost nothing, with 100% i can apply a +40 core and only +60 with at 117%. If i set the vcore limit to maxium, frequency can get to 1940 in soft gaming, but with this card is not a option since it gets pretty hot.
For what i have seen gtx1080ti in theory can go at least to 2000 mhz. I tryed a few things like change software (afterburner to asus gpu tweak) , reinstalling drivers, change power managment options in nvidia control panel,all makes no difference, I also look in bios for some power saving option, but everything looks fine.
My specs:
i7-6700k
Msi armor oc GTX 1080 Ti
asus z170 pro gaming
corsair 750W with gold standard ( i don't think it can be the power supply)
If someone had or have a problem like this or you think you may know the answer, I will appreciate some help.
thanks,
Marc
18,311 (2.71/day)
Memory 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 / 8GB DDR4 HyperX CL13
2 things, cooling and silicon lottery.
trinxo
6 (0.00/day)
Spain
That's nice to know, searching on internet it seems that each card was getting a good overclock, but your strix it's probably more overclocked by factory.
Thanks,
Marc
418 (0.23/day)
Processor R5 5600X
Memory 32 GB 3600 MT/s CL16
Video Card(s) Sapphire Vega 64
Storage 2x 500 GB SSD, 2x 3 TB HDD
Case Phanteks P300A
Software Manjaro Linux, W10 if I have to
According to MSI that card is specced at 1645 MHz / 1531 MHz (Boost / Base)
21,500 (6.00/day)
Case Fractal Design Define R5
Mouse XTRFY M42
Software W10 x64
Reduce your power target. Don't increase it.
Heat = current leakage = more voltage needed = more heat = GPU gets unstable. That is how your OC works right now. Or, doesn't work.
Start with +0 Core OC, 95% power target and work your way up slowly - ONLY on the core overclock. When you reach the limit of stability, dial it back 10-20 mhz and put +300-500 mhz on Memory. Save. Done. Happy gaming.
Why does it work like that? Because GPU Boost will already bring your clock to near-maximum, the cards come with a predefined voltage/clock curve and adapt on it based on temperature. Higher temps will lead to lower boost clocks, so if you OC the core too much, boost can't dial 'down' properly within the same voltage bracket and becomes unstable.
Some other points of interest:
- Delete Kombustor and use something that stresses the GPU properly, like 3DMark. All you get with Kombustor is heat. Not stability or a good OC (ex: your experience).
- An OC won't turn 4K into playable - reducing quality settings can.
trinxo
6 (0.00/day)
Spain
Thanks for that, i've done what you said and with 95% of power limit i can do almost the same overclock than before but the temperatures still the same or even more, what makes no sense for me. Despite limiting the power, what i can see in the graph is that the power goes up constanly over 95, maybe afterburner can't control the spikes.
Marc
21,500 (6.00/day)
Mouse XTRFY M42
Software W10 x64
Marc
No, its because the card will stlll boost, that is also why you're not losing much performance. You can lop off another 5% and see what happens, too and find a sweet spot where noise and temps are minimal but performance still great.
What are your core/mem OC settings now with the lower power target? Still trying to go hard on core? That might be the reason it edges over the specified range in AB.
FreedomEclipse
~Technological Technocrat~
23,543 (3.74/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
The thing is. Pascal starts to 'throttle' the moment temps start going over 60'c. Thats how the boost works. To get the best out of it youre going to need a better cooler. The one of the Armor OC isnt a good one
GN's article has a lot to say about the card, also lots of feedback from people who bought the card on newegg and amazon with 99% of them saying the cooler is crap and the card runs hot.
Get yourself an after market cooler. Either something from Raijintek like a MORPHEUS II or an Accelero Xtreme III. I got the same Accelero cooler on my 1080Ti and got +100 on the core and +660 on the memory though I do have heatsinks on the memory as well though I dont know if those make any difference to my OC or not. I cant remove them now as they are glued on with thermal epoxy.
Your card will probably turbo over 1940mhz if you get a new cooler or find a way to cool it better.
trinxo
6 (0.00/day)
Spain
My actual configuration:
I am testing the stability with heaven benchmark 4.0 now. The result of the benchmark does not change for 90 or 95 power limit, temperature is around 1 degree more hot for 95%, while playing cyberpunk the max temperature is 79 degrees and 78 for heaven benchmark. I tryed to open the pc case and tempertures are better, 72ºC for heaven benchmark, so i will have to figure out how to improve the airflow. What's weird is that yesterday playing cyberpunk with 107% of power limit I was getting 76 ºC (it could be an external issue like room temperature or different zone in the game ).
About the overclock, +60 doesn't seem as stable as +50 , +70 results in crash no matters the memory clock.
Thanks
Marc
3,215 (1.15/day)
System Name The de-ploughminator Mk-II
Processor i7 13700KF
Motherboard MSI Z790 Carbon
Cooling ID-Cooling SE-226-XT + Phanteks T30
Memory 2x16GB G.Skill DDR5 7200Cas34
Storage Kingston KC3000 2TB NVME
Display(s) LG OLED CX48"
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Viper Ultimate
Keyboard Corsair K75
Software win11
Card probably went through mining for quite some time, don't expect the capacitors to give stable power to the chip, so yeah the chip won't be able to reach any high clock.
rtwjunkie
PC Gaming Enthusiast
13,909 (2.39/day)
System Name Bayou Phantom
Power Supply Seasonic X-850
@trinxo What @P4-630 says is correct, although simplistic. First, you may have gotten a lower-quality chip in the silicon lottery. I’d guess the vast majority are average, not special.
Second: temperatures. Pascal must be kept under 60 Celsius or it will begin to throttle. Focus on cooling. All raising the power limit does is increase heat unless cooling increases as well.
Keep in mind, with that card the only thing you are guaranteed is 1645 on the boost clock. Anything else is a bonus.
trinxo
6 (0.00/day)
Spain
Probably, I think i got a good deal for 300 EUR , but nothing is perfect. The card works well anyway.
21,500 (6.00/day)
Mouse XTRFY M42
Software W10 x64
Thanks
Marc
1, Increase the temp limit to 92C. Test it for clocking performance. It might improve because now the card can just run on its hardware limits. It will still hard cap voltage when it hits 84C so no harm done.
2. If your card has the option, unlock the core voltage (that greyed out top slider) and give it a little kick, see what happens to clocks and OC capability now. Temps will suffer.
Beyond that you're pretty much out of options, don't go about changing BIOS please. :)
Well said, I'd agree especially in these times.
trinxo
6 (0.00/day)
Spain
Well, I set the vcore limit to +50% and keep the power limit at 95%. That's all I can do and I'm okay with that. I will look to improve the airflow and that will be all.
Thanks guys for your answers.
Marc
1,252 (0.30/day)
Motherboard MXI APEX
Storage 660P 1TB, 860 QVO 2TB
Case Open Benchtable V2
Audio Device(s) SB X-Fi
Power Supply MSI A1000G
Mouse G502
Keyboard G815
Software Gentoo/Windows 10
If you really want to crank this thing beyond 2GHz, you'll need an Accelero Extreme or AIO, if not going full water route. Keeping the GPU under 40C, I can get 2114MHz at 1.081v stable for 99% of games, and 2100MHz for 100% of them. Mine is essentially an MSI Gaming X, but not sure if they bin it better than the Armor edition.
349 (0.09/day)
Oztralia down under
System Name K9
Processor i9 9900K @ 5.1Ghz and 32deg C - delid + Grizzly Conductonaught LM
Motherboard Gigabyte Aorus Z390 Gaming X
Cooling Custom water cooling loop - GPU + mobo (+VRM's) + CPU
Memory G Skill - Trident Z RGB DDR4 - 3866Mhz x 32Gb @ 3800Mhz
Video Card(s) Gigabyte Aorus 11Gb GTX 1080 Ti Waterforce Extreme @ 2250Mhz
Storage Samsung 500Gb M2 970 EVO + Samsung 850 Pro SSD + ADATA 512Gb SSD + Samsung 1Tb & 3T + WD 1Tb + 3Tb
Display(s) ASUS 27" ROG Swift 1440p @ 165Hz & BenQ 27" LED
Case Thermaltake Core P7 - Open frame
Audio Device(s) Logitech Z906 - 5.1ch
Power Supply EVGA 1200W
Mouse Roccat LeadR + Razer Nagar V2 Pro
Keyboard Corsair K70 LUX with Cherry Red switches
Software Win 10 Pro 64bit
Benchmark Scores v/fast
Marc
hi trinxo,
I have a Gigabyte gtx1080Ti Extreme Waterforce card in my rig and it clocks to 2045mhz using Afterburner.
My system has a custom water loop and the card usually sits around 26C during normal work load = Photoshop, AutoCAD, etc.
It goes up to about 50-55C when gaming/stress testing/benching.
As others have said - I don't think you're going to do much better on air cooling + silicone lottery.
regards
811 (0.28/day)
Riverwood, Skyrim
System Name Storm Wrought | Blackwood (HTPC)
Processor AMD Ryzen 9 5900x @stock | i7 2600k
Motherboard Gigabyte X570 Aorus Pro WIFI m-ITX | Some POS gigabyte board
Cooling Deepcool AK620, BQ shadow wings 3 High Spd, stock 180mm |BQ Shadow rock LP + 4x120mm Noctua redux
Memory G.Skill Ripjaws V 2x32GB 4000MHz | 2x4GB 2000MHz @1866
Video Card(s) Powercolor RX 6800XT Red Dragon | PNY a2000 6GB
Storage SX8200 Pro 1TB, 1TB KC3000, 850EVO 500GB, 2+8TB Seagate, LG Blu-ray | 120GB Sandisk SSD, 4TB WD red
Display(s) Samsung UJ590UDE 32" UHD monitor | LG CS 55" OLED
Case Silverstone TJ08B-E | Custom built wooden case (Aus native timbers)
Audio Device(s) Onboard, Sennheiser HD 599 cans / Logitech z163's | Edifier S2000 MKIII via toslink
Power Supply Corsair HX 750 | Corsair SF 450
Mouse Microsoft Pro Intellimouse| Some logitech one
Keyboard GMMK w/ Zelio V2 62g (78g for spacebar) tactile switches & Glorious black keycaps| Some logitech one
VR HMD HTC Vive
Software Win 10 Edu | Ubuntu 22.04
Benchmark Scores Look in the various benchmark threads
Well with my Gigabyte Aourus xtreme, I've never been able to go above +80, just because of thermals and silicon lottery, even though it is one of the top cards from gigabyte, so sometimes you get luckier then others with how good a card you get.
Glitch_Neutrino
1 (0.00/day)
Hi.
Using GV-N108TAORUSX-W-11GD-rev-1
Power target merely allow card to USE more power if needed. Please calculate available PRODUCTION.
Consult your PSU.
Strategy :
Fan maximum
Temperature Maximum
Voltage maximum
Power Maximum
Run test. (0 Core/Memory boost)
Note result.
Cont'n'd :
Fan maximum
Temperature Maximum
Voltage maximum
Power Maximum
Core +1 Mhz until crash, yes. Do 49 times if required.
Compare result.
You have ascertained stability.
Set fan to aggressive Auto.
Save in profile.
Future improvement only available with COOLING.
Current leakage in ALL electronics, that is why brain voltage low and activity compartmentalised.
All energy same.
You are all wrong. Pascal reduce clock @>25°C
5,243 (4.06/day)
São Paulo, Brazil
System Name Project Kairi Mk. IV "Eternal Thunder"
Motherboard MSI MEG Z690 ACE (MS-7D27) BIOS 1G
Cooling Noctua NH-D15S + NF-F12 industrialPPC-3000 w/ Thermalright BCF and NT-H1
Memory G.SKILL Trident Z5 RGB 32GB DDR5-6800 F5-6800J3445G16GX2-TZ5RK @ 6400 MT/s 30-38-38-38-70-2
Storage 1x WD Black SN750 500 GB NVMe + 4x WD VelociRaptor HLFS 300 GB HDDs
Display(s) 55-inch LG G3 OLED
Case Cooler Master MasterFrame 700
Audio Device(s) EVGA Nu Audio (classic) + Sony MDR-V7 cans
Mouse Razer DeathAdder Essential White
Keyboard Galax Stealth STL-03
Benchmark Scores "Speed isn't life, it just makes it go faster."
This is a two year old thread, my friend. It might not be as relevant as it used to be. However, to address the timeless:
Compare result.
This is pointless, NVIDIA hardware operates in ~13 MHz clock steps (otherwise known as GPU Boost bins). This has been roughly the same since Kepler.
It's common knowledge that the lower the operating temperature of a processor, the better the frequencies it will achieve. I don't see how the others are wrong. You won't be achieving 25°C load temps on a GP102 unless you're using a chiller or even more exotic cooling methods.
