Gtx 1650 with uncertified power supply
El_Rolyman
3 (0.75/day)
I've been saving up to buy a GTX 1650 and I'd like to know if it would be okay like this, even though there's probably a bottleneck or the power supply is insufficient.
Cpu: i5 3330
8 GB DDR3 Dual Channel 1600 MHz
1 SSD and 2 Hard drives
Uncertified power supply (does not say the amount of watts)
I have a question about whether the GTX 1650 would cause a problem with the power supply and if I need to buy another one, apart there is a processor bottleneck. If you can help me I would be very grateful.
396 (2.79/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
It will probably be fine. They don't use much power (70-75 watt, something like that). Chances are that your power supply is at least a 250w.
More details about your computer would make it easier to determine.
El_Rolyman
3 (0.75/day)
Thanks, I don't know if these details are useful or useless but I have a motherboard Asus P8Z77 M Pro, a Sentey case with a single fan connected and then I only use the connected USBs. The GPU I currently use is the Radeon HD 5450
396 (2.79/day)
Texas, USA
I was just curious if it was an OEM system....it would make it pretty easy to figure out what was in it. I think you'll be fine.
A new power supply is never a bad idea if you have a questionable one, but anything 250w or more should do just fine. Probable that it is a Sentey power supply that came with the case.
Toothless
Tech, Games, and TPU!
9,674 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Snag a picture. Bet someone can find the model.
13,415 (1.99/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Uncertified can mean any number of things - some of which might set off safety alarms and red flags.
If you mean it is not 80 Plus certified for efficiency, then safety "may not" be a problem UNLESS it is underpowered.
I would not use any PSU (certified or not) unless I knew with a great deal of certainty it had the capacity to support the connected devices.
42,983 (6.72/day)
Yeah psus do require a part number on them for maintenance, so it should give us what max output is
5,203 (3.75/day)
Colorado, U.S.A.
Software Windows 11 Home
13,415 (1.99/day)
Nebraska, USA
Mouse Logitech M190
El_Rolyman
3 (0.75/day)
It is similar to this power supply, I do not send the one from my PC because I am not at home
21,588 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
I would replace that thing as soon as possible.
