- Oct 21, 2019
- 3 (0.00/day)
System Name | VERONICA |
Processor | AMD Ryzen 5 2600 3.9Ghz Max Boost (6 Cores/12 Threads Unlocked) |
Motherboard | GIGABYTE B450 AORUS M |
Cooling | 3×120mm front ADD-RGB fans (CF120) + 2x top blue LED 120mm and 1x rear Thermaltake Red LED 120mm |
Memory | CORSAIR Vengeance RGB Pro 16GB 3000MHz |
Video Card(s) | ZOTAC Gaming GeForce GTX 1660 AMP 6GB GDDR5 192-bit |
Storage | Samsung 860 EVO 500GB + Seagate BarraCuda 2TB HDD |
Case | DEEPCOOL Matrexx 55 ADD-RGB 3F |
Audio Device(s) | Beexcellent Ultra Light Gaming Headphones |
Power Supply | Thermaltake Smart 700W |
Mouse | Rii RGB LED Backlight Wired Gaming Mouse |
Keyboard | Rii RGB LED RK900+ Keyboard |
Software | Windows 10 Pro |
Benchmark Scores | 96% Rated PC |
Last night I realized that my GPU has these random spikes when on the desktop and not in a game,
usually the GPU Clock is 300Mhz while the Memory clock is around 405Mhz at idle
but I realize that for a split second while on idle the GPU Clock will skyrocket to 1530Mhz GPU Clock and the Memory Clock to 4001Mhz.....and this happens when I click to watch a youtube video!!!
temperatures are still fine but Is there anything wrong with my graphics card as this happens a few times a minute, while browsing the web or going from one program to another..
also I've realized it fluctuates a ton while in game
I'll post a graph below, but just not sure if it's normal as I JUST built this PC a month ago and there has been nothing helpful online that i've found for information.
Thanks,
Specs:
Processor: Ryzen 5 2600 6-Core 3.4Ghz + Wraith Stealth CPU Cooler
Motherboard: Gigabyte Aorus B450 M
GPU Zotac GTX 1660 AMP 6GB GDDR5 192-Bit, Boost: 1845Mhz
Fans: 3x120mm front ADD-RGB fans + 2x top blue LED 120mm fans and 1x real Thermaltake Riing 12 120mm Red LED Fan
PSU: Thermaltake Smart 700W
Ram: Corsair Vengeance RGB Pro 16GB
SSD: Samsung 860 EVO 500GB
HDD: Seagate BarraCuda 2TB
The graph below is when I was clicking from one youtube video to another and at the end that was watching a video.
Thanks,
Specs:
