GTX 1660 TI Mobile Clock Speed
657 (0.11/day)
Auburn Hills, MI
Processor Intel i9-13900KF
Motherboard ASUS Z790M-Plus
Memory 64 GB DDR5 @ 6000 G. Skill Trident Z
Video Card(s) ASUS TUF Gaming RTX 4090
Storage 2 TB SN850X + 2x 4 TB Lexar NM790
Display(s) 32" 4K/240 Hz W-OLED w/ 1080P/480Hz Mode + 39" 3440x1440 240 Hz W-OLED
Case Lian Li O11 Mini
Audio Device(s) Kali LP-UNF + Audeze Maxwell
Power Supply Corsair RM1000x
Mouse Logitech G502 X Plus
Keyboard Keychron Q6 Pro
Does anyone have a laptop with a GTX 1660 TI, if so what speed does it run at?
I'm confused why every site I see says they're supposed to run at a base clock speed of 1455 mhz, and boost up to 1590 mhz.
Mine seems to run at 1800 mhz base clock and turbo to 1955 mhz, without me overclocking it. When I add +195 mhz to the core, GPU-Z and HWINFO both show it reaching ~2130 mhz.
14,064 (3.82/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
ixi
1,451 (0.39/day)
For curiosity, what laptop do you have? Will buy soon for gf laptop but still waiting for amd 4xxx series to show up in my country for laptops.
Solaris17
Super Dainty Moderator
26,885 (3.82/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
When you increase core clock boost clock also increases.
657 (0.11/day)
Auburn Hills, MI
Is it this one?
It has a faster memory speed than the regular TU116
No, it's a 1660 TI, and it's running at 1800 mhz base clock instead of the 1455 most everything says it should run at.
I'm aware.
That still doesn't come close to accounting for the speed it's running at.
1455 base, 1590 boost, it's instead running at 1800 base, and 1955 boost, and that's without me overclocking, if I overclock it runs at 2130 boost and 1995 base.
It's a Maingear Vector.
That shows the expected clocks, it's only the sensor tab that shows it running far faster.
Actually, I wonder if the sensor is combining the clockrate of the 1660 TI and the Intel integrated GPU together.
Dutchie
2 (0.00/day)
i had the same problem because my latop also runs at 1800mhz and boosted to 1955 mhz but i think i figure it out why it does that its because it has the gpu boost 4.0 and from what i found out about it, it will boost your card higher then the standard clock speed if it hasnt reached its limit and thats why you and i see an higher then standerd clockspeed (here is a video that explanse what i mean
18,584 (2.70/day)
System Name AlderLake
It will boost when temperature allows.
Dutchie
2 (0.00/day)
Yea so long it hasn't reach it voltage/temp limit and it's max power draw then you can expect higher then standard clockspeed so 10,16,20 series have an automatic overclock in there cards if you can put it that way
