GTX 295 or 2x4890's
KMS
4 (0.00/day)
Egypt
Ok guys, i'm building a new PC and i need your help on what to get
GTX 295 or two 4890's ?
i've read almost every review out there, some show that 4890 CF is better
other reviews show that GTX 295 is better and i'm torn in the middle :)
money is really not an issue since both options almost cost the same in my country
difference is like ... 18$ or something around that, so money is out of the equation
i'll stick with my samsung 23inch monitor so i'll be gaming at 1920x1080
also i'm getting HEC Cougar 1200w, so can this PSU handle two 4890's/GTX 295 ?
... that's all
i'm leaning just a little bit towards the 4890's CF but i hear they're very noisy
so which is better in terms of performance, heat and noise
thanks in advance
hat
Enthusiast
21,744 (3.33/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Meh... I would go with the 295 since most games are optomized for Nvidia GPUs, plus you get physx (if that means anything to you). That and the 295 is a lot more compact than 2 4890s.
9,247 (1.61/day)
Montreal, Canada
System Name Homelabs
I would say 4890 would be a better choice (I thought 4970x2 and gtx 295 were close? so wouldn't 4890CF beat the 295?) if you are not using PhysX or folding... but I would get a single 4890 if I were you and wait for the GT 300 and 58xx to come out ( end 09 early 10)
but yea, physX or if you are folding, gtx 295
ShadowFold
16,918 (2.76/day)
Omaha, NE
System Name The ShadowFold Draconis (Ordering soon)
Processor AMD Phenom II X6 1055T 2.8ghz
Motherboard ASUS M4A87TD EVO AM3 AMD 870
Cooling Stock
Memory Kingston ValueRAM 4GB DDR3-1333
Video Card(s) XFX ATi Radeon HD 5850 1gb
Storage Western Digital 640gb
Display(s) Acer 21.5" 5ms Full HD 1920x1080P
Case Antec Nine-Hundred
Audio Device(s) Onboard + Creative "Fatal1ty" Headset
Power Supply Antec Earthwatts 650w
Software Windows 7 Home Premium 64bit
Benchmark Scores -❶-❸-❸-❼-
What do you think :p 4890's are FAST.
Charper2013
1,388 (0.24/day)
Macon, Georgia
Processor AMD Athlon 64 X2 7750 Kuma Black Edition @ 3.2GHz 16x200
Motherboard ASUS M3A78-EM AM2+/AM2 AMD 780G HDMI Micro ATX AMD Motherboard
Cooling XIGMATEK Dark Knight-S1283V Long Life Bearing CPU Cooler
Memory OCZ Platinum 2GB (2 x 1GB) DDR2 800 & Corsair Dominator (2 x 1GB) DDR2 1250
Video Card(s) HIS Radeon HD 5770 1GB 128-bit GDDR5
Storage Western Digital 3.25 Inch SATA 320GB Drive
Display(s) SAMSUNG ToC T240HD Rose-Black 24" 5ms HDMI Widescreen HDTV Monitor
Case LIAN LI Lancool PC-K62 Mid Tower Computer Case
Audio Device(s) Onboard Realtek ALC1200 8 Channel Audio
Power Supply Corsair 650HX ATX12V SLI Ready 80 PLUS Certified Modular PSU
Software Windows 7 Ultimate x64 Proffesional
But with the heat and mnoise deal... I say 295..
9,247 (1.61/day)
Montreal, Canada
depends... he probably has a nicely cooled case (since he has so much $$ :p) so yea... maybe a bit noise... but I think he'd prefer 9% more performance over a little less noise...
I would only get 1 and save for GT 300 or the ATi's card
3,779 (0.65/day)
Latin America, Uruguay
System Name The Lizard v2.4
Processor Intel Celeron G1840 (for the time being
Motherboard Gigabyte GA-H81-S2PH
Cooling Intel Stock Fan
Memory 16GB Kingston HyperX 1600
Video Card(s) MSI Gaming GTX 750Ti (For the time being)
Storage 500GB Samsung F1, 160GB Maxtor "Older than god"
Display(s) AOC 28' LCD
Case Coolermaster N200
Power Supply Antec VP500P
Benchmark Scores No crashes in the last 24 minutes.
4890 = GTX 275
GTX 275 * 2 = GTX 295
So basically, they like the same, i would go with the gtx 295 as is easier to deal with, less power, more silent and has phsyx.
2,863 (0.48/day)
Brasil
System Name Sovereign // HTPC
Processor i7 3770k 4.2 // i7 3770k 4.2
Motherboard Maximus V Gene // Sabertooth Z77
Cooling Noctua D14 // Intel HSF
Memory 16GB Samsung // 16GB VengeanceLP
Video Card(s) Deciding // 660 DC2
Storage OS (X25-M), Data (Seagate 1TB) // Samsung 840 120GB & bunch of drives
Display(s) Samsung T240HD // LG TV
Case TJ08e // Grandia GD08
Audio Device(s) DT880 Pro 250 ohm // TV speakers
Power Supply Seasonic Plat 1000 // Seasonic Gold 760
Software Windows 8 Pro x64 // Windows 7 Pro x64
Uhm, if you buy two 4890 with no aftermarket coolers, you will get similar performance, but much higher noise. But two of those with aftermarket coolers would go a lot more expensive than a GTX295. And if you get the 295 you get the BEST VGA of the moment, opposed to 2 great ones. Hehe
9,247 (1.61/day)
Montreal, Canada
but CF scales better than SLI! IMO, get one 4890 or flip a coin if you really want one of the 2 choices... or if you actually mind more heat noise and no PhysX and suckyness of folding over a little bit of performance, then get the GTX 295 or else get the CF
643 (0.11/day)
System Name PIA
Processor Ryzen 5 3600
Motherboard ASRock B550M Steel Legend
Cooling Corsair H50
Memory 2x8GB Gskill DDR4 3600
Video Card(s) MSI GTX 1660 Super
Storage Samsung EVO 970 1TB
Display(s) 2xAOC Curved 24" 144hz
Case Cooler Master MasterBox Q300L
Power Supply CORSAIR RMX (White) RM750x
Mouse Logitech G305
Keyboard Logitech G915 TKL
I'd go with the 4890's. I tend to like 2x cards rather then x2 cards if I want to have multiple gpu's at all.
But either choice will work. You planning on folding? Because then the choice should be obvious.
10,563 (1.71/day)
Austin Texas
System Name Planet Espresso
Processor 13700KF @ 5.4GHZ UV - 220W cap
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard 65% HE Keyboard
I would like to see where CF scales better than SLI... Most reviews I read have SLI having wider support, less issues, and more frequent driver updates. Not one review I have ever read said that CF scales better.
Also 295 has slower clocks than a 275, so 275 SLI > 295 by 10%
http://www.tomshardware.com/reviews/geforce-gtx-sli,2298.html
+10% to a 295 is identical to 4890 CF performance.
AsRock
TPU addict
19,005 (3.01/day)
UK\USA
295 then your more guaranteed performance. And also takes out any messing about if CF gives you issue's.
9,247 (1.61/day)
Montreal, Canada
wtv about the scaling lol :p I'm not sure if it was CF>SLI or SLI>CF :wtf:
how come TH says 4890CF>GTX 295 then?
Yea GTX 275 SLI... is that an option?
3,779 (0.65/day)
well, oc the 295 a little to 275 clocks.
10,563 (1.71/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
Mouse Xlite V2
because 4890 = 275, but the 295 is a :nutkick:'ed set of 275's (with lower clockspeeds)... so 4890's end up being 9% faster and SLI'd 275's are 10% faster than the 295 (lol if you followed my writing you deserve a cookie).
9,247 (1.61/day)
Montreal, Canada
So basically GTX 275 SLI = 4890 CF... but is that (GTX 275 SLI) an option for him? is he getting an i7 mobo? if so yes it is... if not, he needs a SLI mobo...
fire2havoc
133 (0.02/day)
Processor i7 920 @ 3.8 GHz + HT, 1.25v
Motherboard Gigabyte EX58-UD5
Cooling Thermalright Ultra-120 Extreme
Memory 6GB G.Skill DDR3 1600
Video Card(s) HIS 6950 2GB
Storage WD 640GB Black + 2x WD 1TB Green
Display(s) 30" Dell U3011 H-IPS
Case Antec P180B
Audio Device(s) On-Board Sound
Power Supply Corsair 850TX
Software Windows 7 Professional x64
I always prefer a single-card setup (to avoid excess noise, heat, and CF issues) so my vote goes to the GTX 295.
11,119 (1.66/day)
System Name Apple Bite
Processor Intel I5
Motherboard Apple
Memory 40gb of DDR 4 2700
Video Card(s) ATI Radeon 500
Storage Fusion Drive 1 TB
Display(s) 27 Inch IMac late 2017
enaher
416 (0.07/day)
System Name One does not simply have enough cash for INTEL
Processor Athlon II 450 3.8ghz
Motherboard Gigabyte 990FX-UD3
Cooling Cooler Master 212+
Memory 4x4gb Corsair DDR3
Video Card(s) 2x 5830 Sapphire 950c/1150m CF
Storage 2x Seagate 500GB Raid0 + Samsung 1TB
Display(s) BenQ G2220HDA
Case Xigmatek ASGARD PRO
Power Supply SeasonicX 750w
Software W7 x64 Ultimate
go for the 295 far less hassle, and you gte physix and cuda if its worth something to you;)
KMS
4 (0.00/day)
Egypt
there'll always be something around the corner, so why ever wait?
besides those cards would take like months after the release date until they hit the local markets in my country
and i'm not sure if i could afford one then
but i'm sure of two things
1- i can afford GTX 295 or two 4890's right now
2- i'm really really tired of waiting
and yes i'm getting i7 and GIGABYTE EX58-UD4P 3way SLI/CF
but unfortunately GTX 275 is not an option since we don't have it here yet
i'm planning on folding either way
i know ATI sucks at folding
but that shouldn't be the reason not to get 4890's if they were the best choice and perform faster
the reason i leaned towards 4890's in the first place
was bcuz i thought they're faster than GTX 295
the main question here :
would the diff be noticeable in most games? especially the demanding ones ?
if there was no noticeable diff and they're both around the same performance then i'll go with GTX 295
(mainly bcuz of the heat/noise thing) + PhysX and for simplicity's sake
and i can see that all of you guys agree that GTX 295 runs cooler and quieter than two 4890's
and thanks guys i really appreciate your help
9,247 (1.61/day)
Montreal, Canada
at 1920x1080, you'll barely see a difference between 1 4890 and a gtx 295 or CF... get the GTX 295 :D less (barely) hassle and better for folding... and less space taken... PhysX n Cuda...
ShadowFold
16,918 (2.76/day)
Omaha, NE
Cooling Stock
How is it "less hassle", it's still a dual GPU card.
3,459 (0.59/day)
Processor ???
Motherboard 760
Cooling HK
Memory 3x1gb
Video Card(s) 285 Classified / EVGA 480
Display(s) 22" Acer /42" Toshiba
Case Stacker
Power Supply Toughpower 1000w / Coolmaster 650w
Software All of them
if money is no object then go with a triple sli gtx 285 they will beat the sli gtx 295
KMS
4 (0.00/day)
Egypt
nope, can't go with triple sli GTX 285
unless i go with Q9550 or Q6600 instead of i7
and in this case it'd bottleneck the hell out of them :)
4,987 (0.82/day)
NC, USA
System Name Cosmos F1000
Processor Ryzen 9 7900X3D
Motherboard MSI PRO B650-S WIFI AM5
Cooling Corsair H100x, Panaflo's on case
Memory G.Skill DDR5 Trident 64GB (32GBx2)
Video Card(s) MSI Gaming Radeon RX 7900 XTX 24GB GDDR6
Storage 4TB Firecuda M.2 2280
Display(s) MSI Optix G273QF 27"
Case CM Cosmos 1000
Audio Device(s) logitech 5.1 system (midrange quality)
Power Supply CORSAIR RM1000e 1000watt
Mouse G400s Logitech, white Razor Mamba
Keyboard K65 RGB Corsair Tenkeyless Cherry Red MX
VR HMD Steam Valve Index
Software Win10 Pro, Win11
GTX 295 because its stable with much more mature drivers. GTX 295 has alot of OC headroom and a better cooling solution when tweaked with Rivatuner.
GTX 295's folding power walks all over 4890's by what..... ten fold? Also Nvidia is the only one with Physx support.
Its pretty clear IMO that a GTX 295 is better, but they are in short supply. They are much more expensive to produce also.
I like ATi but when it comes to high end gaming I achieve the most desired stable results using Nvidia.
