Gtx 580 sli
Shadow_ID
74 (0.01/day)
Processor Core i7 950 socket 1366 @ 4Ghz
Motherboard Gigabyte GA-X58-G1-GUERILLA X58 Socket 1366
Cooling Corsair H80 cooling (idl - 35c - full load - 60c)
Memory 4GB Corsire Dominator GT 2000Mgz 10-10-10-25
Video Card(s) 2X GAINWARD GTX580 SLI 772 clock/1005 memory/1544 shader
Storage 2x Western Digital WD5000AAKS 500GB SATA II 7200RPM 16MB Cache
Display(s) Monitor 1: 23" ASUS VG236HE 3D Monitor 2: Samsung BX2331
Case Antec 900
Power Supply Antec 850W High Current Pro
Software Windows 7 Home x64
Just got myself two Gainward GTX 580s and running them in SLI... These bad boys get HOT!
I have dropped the clocks a little to give me a few degrees less but I am having to use a desk fan to cool then at the moment as without they hit the die point of about 98c then just crashes out... with the fan i can get away with it. Problem is though is there not going to last long at these temperature really... They are cooking
Any tips on what i could do to try getting them down abit?
229 (0.05/day)
Kilmarnock Scotland
System Name White Phantom
Processor i5 2500K @ 4.4ghz = 1.360-1.368 vcore
Motherboard asrock p67 pro (not pro3)
Cooling prolimatech megahalem with 2x nocuta in push pull (thanks to the 54thvoid) ;) , stock phantom fans
Memory 16gb Kingston hyper x ddr3 1600mhz
Video Card(s) Asus strix 970 ocd 1.5ghz core
Storage 240gb ssd , 1tb Western digital Black, western digital 320gb
Display(s) samsung syncmaster p2450 via DVI @1080p 60hz
Case White and blue NZXT Phantom (carbon fibred sides/door)
Audio Device(s) onboard , philips AMBX pro speakers 80watts rms
Power Supply Xfx750
Mouse Rat 3
Keyboard Act cheapo "gaming"
Software windows 10
Benchmark Scores world record for most amount of times machine has pissed me off ....
change to aftermarket coolers if possible?
add more intakes in your case?
if got some spare cash make a gpu loop for water cooling?
just suggestions if no use just ignore them lol :)
1,743 (0.36/day)
Asheville, North Carolina
System Name Red Giant
Processor Intel Core i7-12700K
Motherboard MSI Pro Z690
Cooling Corsair H100i elite
Memory Corsair Vengeance Pro 32GB
Video Card(s) MSI 4070TI Super
Storage 960 GB Sandisk SSD
Display(s) 27 inch Predator 144 hz 2k
Case CoolerMaster HAF X
Power Supply Corsair AX1200
Keyboard Corsair K95 Platinum
Have you tried setting custom fan profiles? They definitely should not be reaching any temperature close to that under decent fan speeds. Also are your case fans clean and do you have proper cable management to improve airflow?
Shadow_ID
74 (0.01/day)
Case Antec 900
Ive been checking the fan speeds and both end up ramped upto 100% within about 10 minutes of being under full load... if not sooner.
System is generally clean... Cables could do with a good sort out and i do need more fans in the case anyway... I think it might be a good time for a new case and getting some aftermarket water cooling for the 580s.
Failing that just try loosing the case all together?
sneekypeet
not-so supermod
29,659 (4.32/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Scratch what I just had, I see you already had the fans at 100%.
I assume these cards are stacked right on top of each other (havent looked at the mobo yet) hanging a fan on the side or blowing in the rear is something a lot of Fermi owners have done to help combat this issue.
If you use the top green slot and the lower green slot, does that run the cards at 8X by 8X (as you dont really need 16x) Downloading the manual, but its slow;)
Shadow_ID
74 (0.01/day)
Case Antec 900
Got a fan on the side...
Just put fans to 100% during idle with the fan on the side... cant get them less than 45c!
My last card which was a 285 never got more than 60c under full load.... that was a Gainward too that was the reason i went for the gainwards over the PNYs as i knew the cooling was good on them... these have two fans on each card!
sneekypeet
not-so supermod
29,659 (4.32/day)
System Name EVA-01
Even my 470s were scorchers, 45* at idle seems around average. I too had temperature issues in SLI (inside of an 800D), went water to solve my issues, as most good aftermarket air coolers use 3 slots these days:(
With the dual fan models you have, they need space between the cards to draw in enough air....why I mentioned using 8X8 versus 16X16 to space the cards. I assume the bottom card isn't hitting the same temperature?
Shadow_ID
74 (0.01/day)
Case Antec 900
No the bottom card isnt hitting the same temps... it gets into the late 80s and sometimes the beginning or the 90s but not to the point that the card starts dropping voltage etc
I was thinking about doing what you said... to use it in 8X8 mode but how much performance would i loose?
The only downfall for me in doing that would i would loose the slot for my sound card as the card would take up two slots of space
sneekypeet
not-so supermod
29,659 (4.32/day)
System Name EVA-01
I lost like 100-200 3D marks...lol Synthetics you will see it, but its like 3% loss overall.
Shadow_ID
74 (0.01/day)
Case Antec 900
Suppose thats not really that bad then. I will give it a go now... Thanks... i will post on the results of doing so
sneekypeet
not-so supermod
29,659 (4.32/day)
System Name EVA-01
I would still expect high 80s but it should keep running. Last thing I can advise if you are using the stock coolers is to replace the TIM with something better.
Shadow_ID
74 (0.01/day)
Case Antec 900
Ok just got it running in 8X8 and temps are alot better with the extra space now... GPU 1 diddnt even hit 78c and GPU 2 hit highest of 88c
I will give it a go with some long testing. thanks for the help
