Alexandre gomes
- Aug 18, 2020
- 4 (0.00/day)
can someone help me with this video card i boug
ht it in china it its bios is like geforce 750 ti plus the graphics chip on it is the gf 106.
System Name | BOX |
Processor | Core i7 6950X @ 4,26GHz (1,28V) |
Motherboard | X99 SOC Champion (BIOS F23c + bifurcation mod) |
Cooling | Thermalright Venomous-X + 2x Delta 38mm PWM (Push-Pull) |
Memory | Patriot Viper Steel 4000MHz CL16 4x8GB (@3240MHz CL12.12.12.24 CR2T @ 1,48V) |
Video Card(s) | Titan V (~1650MHz @ 0.77V, HBM2 1GHz, Forced P2 state [OFF]) |
Storage | WD SN850X 2TB + Samsung EVO 2TB (SATA) + Seagate Exos X20 20TB (4Kn mode) |
Display(s) | LG 27GP950-B |
Case | Fractal Design Meshify 2 XL |
Audio Device(s) | Motu M4 (audio interface) + ATH-A900Z + Behringer C-1 |
Power Supply | Seasonic X-760 (760W) |
Mouse | Logitech RX-250 |
Keyboard | HP KB-9970 |
Software | Windows 10 Pro x64 |
System Name | Dx12 is not real |
Processor | i7 870x @5Ghz 1.632v (1.7v back of socket) |
Motherboard | MSI Big Bang - Trinergy P55 |
Cooling | Hailea HC-500A Water Chiller (CPU) EK 240mm Predator (GPU) |
Memory | 4GB HyperX H20 @1333 9-10-9 Timings @ 1.65V |
Video Card(s) | HD 6990 @1Ghz core/stock mem/Danger Den block |
Storage | OCZ RevoDrive 3 X2 480GB |
Display(s) | ThinkVision S27i-10 27″ LED Monitor |
Case | Xigmatek Elysium |
Power Supply | Aerocool Project 7 P7 650W |
Mouse | G102 |
Keyboard | ThinkPad Compact BT |
Software | Windows 7 |
Benchmark Scores | FS: https://www.3dmark.com/fs/22627228 |
Processor | i7-13700k |
Motherboard | Asus Tuf Gaming z790-plus |
Cooling | Coolermaster Hyper 212 RGB |
Memory | Corsair Vengeance RGB 32GB DDR5 7000mhz |
Video Card(s) | Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts) |
Storage | 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate |
Display(s) | Acer Predator XB273u 27inch IPS G-Sync 165hz |
Power Supply | Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service) |
Mouse | Logitech G502 hero |
Keyboard | Logitech G710+ |
add a picture of the cooler that was used as likely gonna be only way to possibly ID the card as no other marks on the card that i can seeI have already rewritten several bios, so far I have only found 2 bios that the video has more on the screen.
Does anyone know a manufacturer that can help me with this problem.?
System Name | Lenovo ThinkCentre |
Processor | AMD 5650GE |
Motherboard | Lenovo |
Memory | 32 GB DDR4 |
Display(s) | AOC 24" Freesync 1m.s. 75Hz |
Mouse | Lenovo |
Keyboard | Lenovo |
Software | W11 Pro 64 bit |
thanks for the help but I already tested this bios and it didn't work, I found one from https://www.techpowerup.com/vgabios/145061/145061 that worked I will try to see if everything is right.Try this one.
System Name | 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing |
Processor | 1.3900x @stock 2. i7 7700k @5. 3. i7 7700hq |
Motherboard | 1.aorus x570 ultra 2. z270 Maximus IX Hero,4 MR9A PRO ATX X99 |
Cooling | 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO |
Memory | 1.Gskill neo @3600 32gb 2.hyperxfury 32gb @3000 3. 16gb hyperx @2400 4 64GB 2133 in quad channel |
Video Card(s) | 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb |
Storage | 1 M.2 500gb , 2 3tb HDs 2. 256gb ssd, 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd |
Display(s) | 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z |
Case | 1. Thermaltake P5 2. Thermaltake P3 4. some cheapo case that should not be named. |
Audio Device(s) | 1 Onboard 2 Onboard 3 Onboard 4. onboard. |
Power Supply | 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w |
Mouse | 1 ROG Gladius 2 Corsair m65 pro |
Keyboard | 1. ROG Strix Flare 2. Corsair F75 RBG 3. steelseries RBG |
VR HMD | rift and rift S and Quest 2. |
Software | 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro |
Benchmark Scores | 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847 2. 1106 cb 3.cb 970 |
