GTX1070 FE PCIE Gate
Status
Not open for further replies.
5,717 (0.94/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
Well Toms did it again! In their latest review of 1070 from the Nvidia team they have also found 1070 draws over the 75watt limit of PCIE slots. Well what's the difference this time? If it is AMD then all hell broke loose. Now NV has been exposed of doing this as well for their FE card, all I can hear is crickets chirping.
TomsPCI-E Gate said:
This is almost exactly where Nvidia’s GeForce GTX 1070 Founders Edition ends up, with spikes well in excess of 75W. They're not particularly dangerous, but can cause audible artifacts if you're using on-board audio on a poorly-designed motherboard.
The other graphics cards fare a lot better due to their additional power phases. MSI's GeForce GTX 980 Ti Lightning doesn’t use the motherboard’s PCIe slot at all. Instead, it has an additional six-pin power connector on top of the expected pair of eight-pin connectors.
http://www.tomshardware.com/reviews/nvidia-geforce-gtx-1070-8gb-pascal-performance,4585-7.html
It took AMD a week to fix this. Let's this how long it takes nvidia to fix it this time.
5,717 (0.94/day)
And the average is?
Spikes are super common and was not the issue. The issue was constant average power draw over 75W.
Jesus, how many times should this be repeated.
Just giving nvidia some of the pcie gate love as well.
Waiting for hordes of fanboys to pour in for NV's defense. I am waiting for:
1. Irrelevent discussion
2. Personal attack on me
3. Shifting of topic
Bring it on!:roll:
Aquinus
Resident Wat-man
13,167 (2.81/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
Except it's not because small spikes over aren't unrealistic. That graph probably looks a lot like the RX 480 after AMD fixed it.
5,717 (0.94/day)
Will nvidia fix this that is the question. Probably NV will just release a statement saying users don't need to concern with it too much. A statement maybe too much though. It requires a 3.5GB VRAM gate to warrant a statement from NV.
415 (0.09/day)
The question I have for you is "What will they fix?". Since you have misunderstood the whole problem and is crying wolf for no reason.
Here are some aspects to keep in mind:
  • Capacitors deals well with noisy spikes, they are not really an issue.
  • Spikes are most certainly enhanced by the equipment used to measure it, since they are so very brief.
  • But most importantly, the problem lies with the average power draw.
317 (0.07/day)
System Name scrapper
Processor Intel i5-6600k @ 4.0Ghz
Motherboard ASUS Z-170A
Cooling H100i
Memory Corsair Vengence 16gb ddr4 @3000
Video Card(s) GTX 1070 EVGA SC
Storage 2x 500GB Samsung 850 SSD
Display(s) CrossOver 27" 1440p LG IPS @ 120Hz
Case Corsair 650D
Power Supply AX-850W
I htink you're missing the point, there is nothing for NV to fix.
go back and look at GTX 9xx / r9 3xx and older generations, power SPIKES will always happen, controllers aren't fast enough to react to instant power request properly. you have essentially started a thread to bash a company for a "error" you found that is not an error at all and expected behavior.
The problem with AMD cards is the averages was well above 75W, not just spiking over the limit but staying there constantly sucking more power.
Source: I work as an EE at a measurement devices company and this is literally my career.
5,717 (0.94/day)
The MSI Gaming X 1070 does not have this PCI-E over draw problem. So it is only due to the FE design problem. MSI Gaming X never get even close to the 75watt. FE 1070 should be in the same ball park as well. Not going over the 75watt limit.
415 (0.09/day)
Atleast I know where the problem lies, and its not in the 1070 FE....
You should really read up on the measurements and the theory behind it before you start these kinds of threads.
Frick
Fishfaced Nincompoop
19,537 (2.86/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
The word "gate" should be banned from every conversation that does not include gates.
317 (0.07/day)
Cooling H100i
Case Corsair 650D
you're still missing my point. it is totally valid to draw up to 75W on PCIe, there is nothing wrong with that, as that is what it is rated for. In that rating is also a spec for over power spikes that it is expected to handle.
your statement only shows that MSI has a 6+8 pin power and therefore draws mostly all of its power directly from the PSU instead of the PCIe power that is available.
I'll make this clear again since you don't understand, There isn't anything wrong with the graph you showed, it is below spec with expected spikes for a power controller. I am an EE who works at a company that creates measurement instruments and I do this day in day out so I kind of know a little bit about what i'm talking about here. If you don't trust what i'm saying then idk what to tell you besides you are being somewhat ignorant if you continue to think there is a problem with that graph after you read this.
The FE card uses a single 6 Pin power paired with PCIe Power which you are comparing to an MSI card that uses 6+8 pin power and a tad of PCIe power and saying that you conclude the MSI uses less PCIe power so therefore it is doing it right while NV is doing it wrong. this conclusion of yours is just missing just a little bit of something called logic.
Tatty_Two
Gone Fishing
25,939 (3.77/day)
Worcestershire, UK
Software Win 11 Home x64
Bring it on!:roll:
Maybe not, I don't like deliberate flamebait fanboist threads..... just call me old fashioned..... it's closed.
Status
