- Mar 23, 2005
- 4,084 (0.57/day)
- Ancient Greece, Acropolis (Time Lord)
System Name | RiseZEN Gaming PC |
Processor | AMD Ryzen 7 5800X @ Auto |
Motherboard | Asus ROG Strix X570-E Gaming ATX Motherboard |
Cooling | Corsair H115i Elite Capellix AIO, 280mm Radiator, Dual RGB 140mm ML Series PWM Fans |
Memory | G.Skill TridentZ 64GB (4 x 16GB) DDR4 3200 |
Video Card(s) | ASUS DUAL RX 6700 XT DUAL-RX6700XT-12G |
Storage | Corsair Force MP500 480GB M.2 & MP510 480GB M.2 - 2 x WD_BLACK 1TB SN850X NVMe 1TB |
Display(s) | ASUS ROG Strix 34” XG349C 180Hz 1440p + Asus ROG 27" MG278Q 144Hz WQHD 1440p |
Case | Corsair Obsidian Series 450D Gaming Case |
Audio Device(s) | SteelSeries 5Hv2 w/ Sound Blaster Z SE |
Power Supply | Corsair RM750x Power Supply |
Mouse | Razer Death-Adder + Viper 8K HZ Ambidextrous Gaming Mouse - Ergonomic Left Hand Edition |
Keyboard | Logitech G910 Orion Spectrum RGB Gaming Keyboard |
Software | Windows 11 Pro - 64-Bit Edition |
Benchmark Scores | I'm the Doctor, Doctor Who. The Definition of Gaming is PC Gaming... |
Specs:
AMD Phenom II X4 940 @ 3.60GHz
Sapphire Radeon HD6970 2GB GDDR5 (Used to be CrossfireX'ed with 2 x 4870's)
Asus VE248H 24" WS 1080p, 2ms, LED, 10,000,000:1
Asus M3A79-T Deluxe AM2+ 790FX/SB750
OCZ DDR2-1066 8GB (4x2GB) Reaper HPC (5-5-5-15)
Corsair H50 CPU Cooling
WD 250GB SATA300 w/16MB buffer x 2 (RAID 0)
WD 1TB SATA300 w/ 32MB buffer
LG GGC H20L Blu-ray/HD DVD/DVD/RW, SATA
HAF 932 Red Dragon MOD (Custom)
Corsair TX Series 750W
Windows 7 Ultimate x64
Mods:
Prep, Primed & Painted. The sanding was tricky along with the taping. It took me some time to tape up the "HAF" on the side of the case. I did not sand the plastic. Big mistake, DO NOT SAND THE PLASTIC because it's not plastic, its PVC piping plastic. If you sand it it comes out like spaghetti. I stopped just in time and prevented damage to my case. Just clean it with soap & water, then give it about 4 to 5 thin coats of primer to get it fully covered. Then paint away. It seems as though CoolerMaster put some sort of residue on the exposed steel parts of the case. So sanding then priming is a must.
Finished the 2 x 230mm Black fans. Added RED LED's on them and painted the fins bright Chrome Metallic. I'll be adding new photos in the coming days.
Air blowing inside the case from the side, bottom & back fans and hot air blowing out of the case from the top fans (230mm & 120mm).
Hope you all like my Mod...
Specs:
Mods:
