Having some trouble with networking - advice needed
t_ski
Former Staff
11,960 (1.76/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
It never fails: I always seem to come up with some kind of problem no one has ever seen before, nor have any idea how to fix. However, with my desparation (ie: the wife is very pissed @ me right now), I figured I'd put our new Networking forum to the test and see if you guys can figure this one out. Let's start at the beginning...
I have one PC running Windows XP Pro SP2 (the one in my sig & System Profile) which is wired into a DSL modem/gateway/router/WAP. I also have two laptops with b/g Broadcom cards preinstalled (with no PCMCIA slots available to use). I previously had the network running smoothly, sharing files on each machine as well as a printer connected to the main PC. For security, I was using 128-bit WEP. After taking several classes dealing with wireless and security, I felt WEP was no longer a wise choice, and wanted to switch to WPA-PSK.
At first, I was able to get WPA-PSK configured and working, but my wife's laptop kept getting the "Limited connection or no availability" warning whenever she booted the laptop. Every single time she turned it on, she would have to go in and "repair" the connection for it to work. It seemed as though this may have something to do with DHCP, as the error occurred with the laptop's IP address being outside the pool. I tried to assign a static IP address, and that worked everytime i rebooted. However, the first time it powered down completely and then back up, the error was back.
In the process of trying to figure this out, I realized that the machines were no longer connecting to each other, although the laptops could still access the internet just fine. I talked with two of my teachers, who gave me the standard line about updating drivers and firmware. I updated the drivers on the wife's laptop, as well as the HP Wireless Assistant. I also updated the firmware on my DSL modem to the latest one available. Unfortunately, nothing is working. The firmware update may have even caused more issues, because I can't even get back to WEP.
Things I have tried:
Reset the DSL modem - no change
Made sure the computers were in the same network - MSHOME
Tried renaming the network to HomeNetwork - no change
Pinged the main PC's loopback address - works
Pinged the main PC's IP address (192.168.1.35) - works
Pinged the laptop's IP address (192.168.1.33) from the main PC - times out (as it should if it is not finding anything in Network Places anyway)
Pinged the laptop's loopback address - works
Pinged the laptop's IP address - works
Pinged the main PC's IP address from the laptop - times out (as it should if it is not finding anything in Network Places anyway)
Ran Window's Network Connection Wizard - no change
Ran Window's Wireless Network Connection Wizard - no change
Probably tried a few other things too, but I can't remember them offhand. I'll add them as I remember them.
Anybody have any suggestions?
DaMulta
My stars went supernova
16,168 (2.43/day)
Oklahoma T-Town
System Name Work in progress
Processor AMD 955---4Ghz
Motherboard MSi GD70
Cooling OcZ Phase/water
Memory Crucial2GB kit (1GBx2), Ballistix 240-pin DIMM, DDR3 PC3-16000
Video Card(s) CrossfireX 2 X HD 4890 1GB OCed to 1000Mhz
Storage SSD 64GB
Display(s) Envision 24'' 1920x1200
Case Using the desk ATM
Audio Device(s) Sucky onboard for now :(
Power Supply 1000W TruePower Quattro
Install IPX and see what happens.
t_ski
Former Staff
11,960 (1.76/day)
Why do you suggest that? IPX is necessary for (older) Netware systems, but not really for MS or most other current OSs.
DaMulta
16,168 (2.43/day)
Oklahoma T-Town
Storage SSD 64GB
That's what I always do when windows gives me a fit with a network.
It seems to fix all of those mind headache problems that pleage windows from time to time(Without reinstalling).
It's funny my dads a network engineer for BP and I still get confused with network systems.
t_ski
Former Staff
11,960 (1.76/day)
Yeah, well I'm a second year student in a NetAdmin program and have CompTIA Network+ certification, and this baffles me.
DaMulta
16,168 (2.43/day)
Oklahoma T-Town
Storage SSD 64GB
try the ipx just to see what it does.
t_ski
Former Staff
11,960 (1.76/day)
OK, I installed it on one laptop and the main PC, but it made no difference.
DaMulta
16,168 (2.43/day)
Oklahoma T-Town
Storage SSD 64GB
last resort didn't help.....
did you reset your router?
Start with the basics check the wires.
1,958 (0.27/day)
The Kingdom of Norway
Processor Ryzen 5900X
Motherboard Gigabyte B550I AORUS PRO AX 1.1
Cooling Noctua NB-U12A
Memory 2x 32GB Fury DDR4 3200mhz
Video Card(s) PowerColor Radeon 7800 XT Hellhound
Storage Kingston FURY Renegade 2TB PCIe 4.0
Display(s) 2x Dell U2412M
Case Phanteks P400A
Audio Device(s) Hifimediy Sabre 9018 USB DAC
Power Supply Corsair AX850 (from 2012)
Software Windows 10?
firewall on laptop?
t_ski
Former Staff
11,960 (1.76/day)
Yes, I did reset the router (several times actually). As for wires, the main PC connects to the internet through the DSL modem/router just fine, so the cable should not be faulty. As for the laptop, its connection is wireless, so there are no wires to check :slap:
However, your suggestion did give me an idea. I connected the laptop to the switch directly with a cable, and disabled the wireless connection. I'm getting an error that says "network is not accessible. You may not have permission to use this network source... (yada-yada-yada)... The list of servers for this workgroup is not currently available."
@ wiak - I have McAfee's firewall on the laptop, the same as it always was. I had it on the PC, too, but the subscription for the Internet Security Suite expired, so I uninstalled it, set up XP's standard firewall on the PC, and have installed Avast for anti-virus. I can try XP's firewall on the laptop, too.
DaMulta
16,168 (2.43/day)
Oklahoma T-Town
Storage SSD 64GB
Are you on DSL? Does your DLS modem have it's own IP address?(Which shouldn't matter)
But d(ame it sliped my mind on what it was) at work we had DSL for 2 weeks and they where using this old old system that messed with ours.(But I think it was the incomming FTP and so on)it was a few months ago.
Do you have a crossover cable to try one computer to another.
Has the internet been working?
t_ski
Former Staff
11,960 (1.76/day)
Yes, I'm on DSL. The router's IP address is 192.168.1.1. It's also the default gateway and DNS server by default.
I just uninstalled McAfee and restored the Window's firewall. Still not working. I have a crossover cable I could try...
Namslas90
4,846 (0.73/day)
Earth
Try removing XP Hotfix Q815485 as it tends to corrupt wireless network adaptor software.
Goto Add/remove programs and check box to "show updates" then remove. If it doesn't solve the problem you can always just go back to Windows updates and reload it.
:toast:
t_ski
Former Staff
11,960 (1.76/day)
OK, I installed the crossover cable and it still would not work. Then I turned off the Windows firewall on the laptop and then it found the PC. :banghead::banghead::banghead:
Now how do I set the firewall to allow the PC to connect to the laptop?
t_ski
Former Staff
11,960 (1.76/day)
:toast:
Didn't see that one loaded, but they did have a roll-out that was supposed to fix some of those issues:
http://support.microsoft.com/kb/826942/
7,221 (1.09/day)
Memory 2GB DDR // 8GB FB-DIMM
Audio Device(s) Audigy 2
THIS IS A VERY COMMON PROBLEM WITH WIRELESS IN YOUR NETWORK.
Q: What's causing the problem?
A: After time the router gets difficult maining or issuing new DHCP over wireless, or WPA-SK over wireless. There can also be IP conflicts where more than one device is given the same address and it brings the whole router down. Nothing other than a full network reboot can solve it. Also make sure there arent any devices with "persistant" IP addresses. An unexpected router table might be overriding DHCP.
Your options are as follows:
1./ Do-it-all routers are fine in concept... but a more robust approach is to use a router SEPARATE from your wireless access point SEPARATE from your modem. It means more equipment and more power sockets.... yes I hate that too... but so often these consumer all-in-ones are less than reliable. (Its as much a software and memory management issue as hardware issue on the device).
2./ Put one of those "timer controllers" between the wall socket and the power supply on your router and/or access point so that it gets a "hard reset" in the middle of the night every day, e.g. 3am-3:05 am.
3./ Switch to WEP. Slightly less secure but also less complicated for your router/access point. PS. There are many enterprise wireless devices with ONLY work on WEP for certain functions, e.g. LAN bridging.
4./ Set up an IP address table for your LAN. Put, e.g. your fixed infrastructure e.g. routers and printers in the range x.x.x.1 to x.x.x.99. Put your wired PCs on DHCP in the range x.x.x.100 to x.x.x.199 and but your wireless devices on FIXED in the range x.x.x.200 to x.x.x.255
Repeat: DHCP can fail over wireless when the router is on >24hrs. I know this sounds odd... but sharing from community experience.
7,221 (1.09/day)
NOTE: Some people have solved similar issues just installing the "clunky fix" #2
I fixed the issue by implementing #1, #3, #4. (Didnt need to do #2)
t_ski
Former Staff
11,960 (1.76/day)
The dsl modem/router has a static IP address of 192.168.1.1. The PC and the laptops use DHCP and pull from the pool of 192.168.1.33 to 192.168.1.64. However, the machines always pull the same IP address, even if the leases expire. I have never had any kind of issue with DHCP failing in the past two+ years of using this setup.
Do you have any links to the info you posted? I'd be interested in checking them out - I'm reading everything I can on the subject right now.
However, I do think this has a lot to do with the Windows firewall at the moment. After I was able to get the two to connect with a crossover cable and disabling the XP firewall, it seems to make sense. I'm trying to find some links on setting the firewall to allow each other machine, but I'm not having much luck finding that exact topic. :( Anybody have any links for that?
t_ski
Former Staff
11,960 (1.76/day)
I forgot to mention, I looked in the firewall exceptions and File and Print sharing is allowed (box is checked).
pt
not a suicide-bomber
8,956 (1.31/day)
Portugal
Processor AMD Turion 64 X2 Mobile TL-60 (Trinidad)
Motherboard ASUS F3Ka (ATI RS690M)
Cooling stock
Memory Nanya 2x1GB ddr2 667@5-5-5-15-2T
Video Card(s) ATI Mobility Radeon HD2600 512MB DDR2@ 580mhz/486mhz
Storage 160GB on laptop+250GB external
Display(s) ASUS 15.4
Case Asus Laptop F3Ka chassis
Audio Device(s) on-board
Power Supply 1:30minutes battery
Software "genui xp", 'cause i hated vista
get back to wep, and use a mac adress filter on the router
or just don't use the wep at all, and just the mac, unless you got a 1337 hacker has a neighbour it will be fine
t_ski
Former Staff
11,960 (1.76/day)
That still doesn't help me with the firewall, and does nothing to make sure that private health information doesn't get lost. My wife works for a very big insurance company - if she's working on some insurance policies with your PHI on there, do you want to risk it being stolen? We can't afford the legal bills if it does. :(
7,221 (1.09/day)
Quite simply, WTF is she doing with other people's PHI in your home? That should be on a secure locked down corporate server. What's the name of the insurance company she is working with. I think you have whistleblower protection here... NAME AND SHAME
P.S. 2 people have independently told you to try a different wireless solution. I think you should try their advice.
pt
8,956 (1.31/day)
Portugal
Cooling stock
i have to agree with lemonadesoda here, as far as i can see she shouldn't work with these at home
t_ski
Former Staff
11,960 (1.76/day)
Um, she is allowed to do that. She holds the second highest position in the office, and sometimes needs to bring her laptop home (the same one that docks on her desk). Usually there isn't anything to worry about, but if someone emails her a question about a claim or something, then it could be there. However, she is extremely aware of HIPPA regularions and such more than any of you might be, and she can handle herself in an extremely professional manner. None of this is the point. Besides, she only connects through a VPN, and never through the wireless. It's mearly an afterthought at this point.
If, in the end I need to do that, I may, but for right now I'd like to see if I can work with what I have. It's actually a high-end DSL modem/router and I think I can make it do what I need to.
7,221 (1.09/day)
...extremely aware of HIPPA regularions and such more than any of you might be...
That kind of arrogance wont get you far here mate. If your wife is such a shit hot corporate jetsetter then get her to call her IT department to come round to her house and fix what her husband cant solve. Stop trying to solve everything on a shoestring. We are talking serious security issues and serious liability risk. Your IP has been noted and sent to the NAIC.:shadedshu
