Having trouble with the Intel 7260 Wireless/BT
2,965 (0.64/day)
Fort Worth, TX
System Name LGA775 | BoX-Server
Processor Xeon E5450 OC3.6GHZ from 3GHZ | i3 3.4GHZ
Motherboard ASUS PQ5-EM | ASRock
Cooling 120MM Heatsink (2-FANs) | Custom HSK 90mm
Memory DDR2 2GB-x4=8GB | 8GB 2x4GB=8GB
Video Card(s) NVIDIA Quadro K2200 4GB | Intel
Storage 500\500/240/240GB SSDs 120GB Laptop IDE
Display(s) Asus 24"
Case DIYPC N1e-SPORT | CoolerMaster 110
Power Supply EVGA 550WATT | Rosewill 530WATT
Mouse Rosewill RGB
Keyboard Rosewill RGB
Software WiN10ET/WiN11ET
Hello guy's,
OK so long story short I had have this card before but stupidity of me didn't take the antennas out which yes bent the left one so that pcie card was useless but my bud bought another but the card sees BT in windows but no Wi-Fi. I booted into Linux MINT and both worked fine. I installed driver booster and it listed the device as faulty lol. So what gives? Yes I uninstall and this/that
Is the wifi card on a motherboard or laptop by any chance. Sometime the driver booster gets the driver for the same model but not the original one from the manufacturer site. Try getting it from Intel website.
Possible causes for it to failing to work or not seeing wifi around you it can be as simple as a wifi switch on the laptop could be turned off or a corrupted driver.
I didn't use driver booster I know better. I use 3Dp but seeing this being used as a Desktop Wi-Fi but it worked perfectly fine before *It's on a PCI-E mSata
What operating system are you using and is it a PC or laptop
I've had that happen with wired NICs. Windows being dumb, I had to use a usb rj45 in windows, but a real install of Mint was happily fine with MB nic that windows didnt even detect. Eventually, didnt care, as i stuck to the Mint install.
Ah right I think it to do with the compatibility issue with windows 11 and certain driver for that motherboard. Try this driver it windows 10 64bits if you are using windows 11 bits it should work
All drivers are pretty much the same. That's just BT not wireless. BT works fine
It apparently something to do with reinstalling drivers and putting tape on a certain pin to enable wifi might be something that is fixable.
Is the wifi card on a pcie adaptor or can you show a picture of it
Taped pin # 20 and pin # 51 on the Intel 7260 AC Wifi card, and reinstalled in system. The wireless and bluetooth functionality is now recognized.
Used the diagram below to locate corresponding pins on the Wifi card. Hope this helps someone..
Here
Why fail
Ah I see it now it a laptop wifi/bt card converted to pcie adaptor for desktop. Yeah looks like you might to try the tape method to cover pin 21 and test it to see if it comes up on wifi
Here more info
This one enabled bluetooth/wifi which it shows how to do this by using tape method so yeah it need pin 20 and 51 to be covered to enable wifi. Might be trial and error to get it right
That the reason why it failed to install in the first place due to the wifi is not enabled
It just kills me that I have to do this just to get the wifi working where Linux sees it just fine. I already ordered a different card but this is msata and not M.2
