- Jan 3, 2020
- 6 (0.00/day)
System Name | Toshiba Satellite Pro A50-A |
Processor | Intel Core i3-4000M, SR1HC |
Motherboard | Toshiba FAWGSY3 |
Cooling | Toshiba G61C0001H210 + Delta KDB0605HB |
Memory | SK hynix HMT425S6AFR6A-PB 2 GiB DDR3L-1600 x2 |
Video Card(s) | Intel HD Graphics 4600 @ 1.1 GHz |
Storage | HGST HTS545032A7E380, 320 GB, 5400 RPM, 8 MiB buffer, SATA 2.6 |
Display(s) | LG LP156WH4-TLD1, TN, 1366x768, 60 Hz, 6-bit, 1 channel, FPD-Link |
Case | Toshiba Satellite Pro/Tecra A50-A |
Audio Device(s) | Realtek ALC283 HD Audio Codec 1.0 |
Power Supply | Delta SADP-65KB A, 19 V, 3.42 A, 65 W |
Mouse | ALPS TouchPad, PS/2 |
Keyboard | Toshiba G83C000DU2JP, PS/2 |
VR HMD | Toshiba dynaEdge AR100 |
Software | Microsoft Windows 7 Ultimate Edition x64, Service Pack 1 |
I believe this issue has something to do with the HD 4600's power limits, but I'm not exactly sure if that's the actual problem. According to ThrottleStop 8.70.6, it indicates a red 'GPU POWER' box to display that it's throttling hard.
This is how it looks under the influence of power limit throttling. The power limit seems to only kick in under GPU-intensive tasks, and not under CPU-intensive tasks.
My previous power limited run was done with this configuration set (Turbo Power Limits, FIVR Control). In another run, I've tried using PowerCut to trick the Core i3-4000M into thinking that it used far less power to prevent the power limits from setting in. Unfortunately, that didn't work either. The 'GPU POWER' box still popped up with PowerCut enabled. Then I tried another way to get around this annoying problem, MMIO addresses FED159A0 and FED159A4, which stored the long and short term power limits. Again, unfortunately it appears that my laptop doesn't seem to use the MMIO method to control the power limits. At least that's what I could tell from the values in there, I might be wrong though.
Under next to no load applied, this is how the Limit Reasons window looks like. I guess you could say it's idling.
Does anyone have a clue on what's going on with my laptop? I'm completely lost in this, seeing that adjusting the values in ThrottleStop's power limit window had no effect.
