HD 6950: LOCATION of temperature sensors?
cmarino
5 (0.00/day)
Hello,
how many temperature sensors does the 6950 physically have, and where are they located? I tried researching on the Internet but couldn't find it.
The reason I'm asking is because I just found out that GPU-Z comes up with THREE different temperatures, and what worries me is that one of the three is SIGNIFICANTLY higher than the other 2!
Does this look normal to you?
Since my 6950 is modded (I removed the noisy stock fan and replaced with a "fanless" Accelero S1 rev2.0, with added fans), I used to keep an eye on the Speedfan's "GPU" value (which was usually ok), but didn't know there were other sensors to check!
Can anybody tell me all the GPU-Z readings are accurate, and if they belong to ACTUAL hardware sensors on the board? (for example...: where is the "voltage regulator temperature" sensor???
Thank you!
FreedomEclipse
~Technological Technocrat~
24,442 (3.76/day)
Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
I cant recommend enough that you attach a 120mm fan at the bottom of that heatsink. 6950s are not the kind of cards that you can have a fanless solution with, they are just too powerful and create too much heat. If thats your cards idle temps - youre already overheating.
so unless you want a dead 6950 and a lengthly RMA period - bolt a 120mm fan on that cooler NOW
I just hope you havent been stupid enough to game on it in its current state otherwise you could have done more damage then good.
43,619 (6.43/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
All three GPU temperatures are on the GPU die itself.
cadaveca
My name is Dave
17,232 (2.50/day)
Temp 1 is shader cores.
Temp2 is Mem I/O
Temp 3 is Display I/O.
All are DTS sensors in the silicon itself, as erocker mentioned.
Temp1 is what will be displayed by CCC, is listed as GPU temp in GPU-Z, etc.
I'd be checking the cooler mounting/thermal-paste spread. The temps being slightly higher is normal, but not the 20c difference you got there, nope. Bad heatsink contact most likely.
cmarino
5 (0.00/day)
Good... Then, maybe, the reason of that "difference" means I need to reseat the copper heatsink properly on the GPU; that tiny Accelero S1 copper plate is not in complete contact with the GPU.
And... yes, OF COURSE i have a fan attached to the Accelero S1!! :laugh: I have TWO Enermax 120mm ultra quiet thermistor fans attached to it. But even running both at full speed I keep getting #2 incredibly hot, while #1 and #3 don't even go over 60°.
There must be something... Probably, as cadaveca mentioned, it's a wrong GPU/heatisink match.
These S1 heatsinks have a very light structure holding them to the GPU... They're cheap and not very well made. The brackets even bend if you push them too hard, and I noticed that they must be custom bent to ensure a proper contact between GPU and copper heatsink!!
What a waste of Arctic Silver thermal paste :cry: tomorrow I'll clean and reapply the heatsink hoping that temps won't get even worse than before... I have the feeling that it will take me a long time reseating the sink and retesting the GPU temps before obtaining a proper match :(
cadaveca
My name is Dave
17,232 (2.50/day)
I'm interested to see how this works out for ya. Keep us updated, PLOX.
43,538 (6.77/day)
last time i seen a separate temp sensor was on an AMD Skt A Motherboard.
cmarino
5 (0.00/day)
Uhm, i believe even "modern" motherboards contain a separate temp sensor, embedded into a DFI's ITE Smart Guardian chip:
I thought the video card had something like this.
43,538 (6.77/day)
W1zzard
Administrator
28,181 (3.72/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
http://www.legitreviews.com/images/reviews/266/DFI_RDX200_ITE.jpg
that's just the monitoring IC, the actual sensor is located in the cpu and connected to that IC. many of these ICs also measure their own temperature which is often called "motherboard temperature"
Temp2 is Mem I/O
while this is true for older cards (where gpuy shows those names), on newer GPUs i dont have any reliable information as to the sensor location (other than that they are located inside the gpu silicon).
thats why gpuy uses more generic names. other developers like aida64 chose to stick with the existing names, even though the locations might have changed
43,538 (6.77/day)
Ya as on the SKT A CPUs the sensor is right in the middle of the socket itself.
The NB contained the system temperature (did direct temp gun measurement of both CPU and NB)
hojoom
2 (0.00/day)
Temp2 is Mem I/O
Hi i have R9 290 . GPU (1) is hot temp 80 c When I open network or games : 150 c temp ?
