HD 7950 aftermarket cooling suggestions?
4,012 (0.72/day)
Sarasota, Florida, USA
System Name Awesomesauce 4.3 | Laptop (MSI GE72VR 6RF Apache Pro-023)
Processor Intel Core i7-5820K 4.16GHz 1.28v/3GHz 1.05v uncore | Intel Core i7-6700HQ @ 3.1GHz
Motherboard Gigabyte GA-X99-UD5 WiFi LGA2011-v3| Stock
Cooling Corsair H100i v2 w/ 2x EK Vardar F4-120ER + various 120/140mm case fans | Stock
Memory G.Skill RJ-4 16GB DDR4-2666 CL15 quad channel | 12GB DDR4-2133
Video Card(s) EVGA GTX 1080 Ti Hybrid SC2 11GB @ 2012/5151 boost | NVIDIA GTX 1060 6GB +200/+500 + Intel 530
Storage Samsung 840 EVO 500GB + Seagate 3TB 7200RPM + others | Kingston 256GB M.2 SATA + 1TB 7200RPM
Display(s) Acer G257HU 1440p 60Hz AH-IPS 4ms | 17.3" 1920*1080 60Hz wide angle TN notebook panel
Case Fractal Design Define XL R2 | MSI
Audio Device(s) Creative Sound Blaster Z | Realtek with quad stereo speakers and subwoofer
Power Supply Corsair HX850i Platinum | 19.5v 180w Delta brick
Software Windows 10 Pro x64 | Windows 10 Home x64
Hey guys,
My XFX DD HD7950 is driving me up the wall with its atrocious cooling solution that seems to be becoming worse. The card has been running in the high 80s with a modest overclock (1050/1400, stock volts) and as I played more Far Cry 3 the temperature has been seemingly getting higher and higher, with 90-92c being common. Tonight, I carefully took apart my GPU, using needle nose pliers to loosen the two screws with XFX warranty stickers on them, cleaned off the old crusty TIM and applied a rice grain sized blob of new TIM, and reassembled the card using a pencil eraser to set the stickered screws and the pliers again to tighten them.
Now, my card is running even hotter and at stock 800MHz core speed in Far Cry 3, my GPU core is at 85c (overclocking now causes the card to shut off a minute into the game) and my VRM temps are 80/82c as well. Seeing as I tightened all the screws properly and properly applied the TIM, I'm going to have to guess that the vapor chamber is probably screwed on this already crappy stock cooler unless the rather cheap CM IceFusion paste I used incredibly sucks, which I'm doubtful of since I use it on all my CPUs without issue.
So, after having one XFX warranty stickered springloaded screw fly across my room (used a spare equivalent screw since it is now MIA) and now worse temperature results that are preventing me from using the card effectively, what aftermarket air cooler choices are out there? Is the Arctic Cooling Accelero 7970 the only one, does it have effective VRM cooling, and will I actually be able to play a game without my computer sounding like it is ready to take off into space?
6,762 (1.38/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
I had the artic accelero 7970 and it worked great on gpu temps but worse than stock on vrm temps. It sure was quiet. The ati red mod is an effective solution that you might want to look into.
These were with the accellero.
4,012 (0.72/day)
Wow, those are some nice temps. At stock my GPU is pulling ~130w in Far Cry 3 and running at 86c, so the Accelero has to be a lot better. Interesting read on "the red mod" though after seeing KieX's Corsair H100 spontaneously explode and destroy his motherboard and RAM, I'm a bit turned off as far as water cooling goes.
Anyway, another problem I am facing is actually getting the Accelero Xtreme to fit in any of my cases. My rig is in a Rosewill Challenger-U3 and my stock XFX barely fits in that. I also have a NZXT Source 210 and HEC Blitz (aka Rosewill Destroyer) but I have no idea if it fits in any of them.
6,762 (1.38/day)
Processor 7800x3d
Case ThermalTake P3
The accellero is pretty huge. Look how much longer it is than the pcb. It easily takes 3 slots. I could not of fit it if I couldn't take out the upper drive cage of my 550d.
It is pretty low odds that an AIO cooler would explode. Most people who do it use an antec 920 and they get same to better temps than I did with the accellero.
This is the place to read about others experience with the mod.
AsRock
TPU addict
19,073 (3.00/day)
UK\USA
Did you check all the temps of the card with some thing like GPU-Z ?, just to check if there is bad contact at some points of the gpu core.
Did you take the cooler fully apart to remove all the dust ?
Contact XFX and tell them the temps are getting really bad and you would like to check if changing the tim and dismantle the cooler to remove all possible dust and possible try a 3rd party cooler and if any of the following would void the warranty.
The length of the warranty as got shorter but in the US i think your allowed to change it if you ask them 1st unless they changed that policy too.
854 (0.16/day)
Nairobi, Kenya
Processor Intel Core i7-14700K
Motherboard ASUS ROG STRIX Z790-H
Cooling DeepCool AK500 WH
Memory Crucial Pro 32GB Kit (16GB x 2) DDR5-5600 (CP2K16G56C46U5)
Video Card(s) Intel ARC A770 Limited Edition
Storage Solidigm P44 Pro (2TB x 2) / PNY CS3140 2TB
Display(s) Philips 32M1N5800A
Case Lian Li O11 Air Mini (White)
Power Supply Seasonic Prime Fanless Titanium 600W
Keyboard Dell KM714 Wireless
Software Windows 11 Pro x64
I like this statement right here^ :laugh: It must seriously piss you off. Lets hope for the best for you. I don't know much about after market GPU coolers i wish i cold be of more help, thanks for the laugh i needed it.
4,012 (0.72/day)
Yep, cooler was actually really clean when I took it apart. When I shut down the computer to take out the GPU, the heatsink was extremely hot to the touch. Been monitoring it with GPU-Z and the VRM temps nearly match the core at all times. I've taken the side panel off of my case but it made no difference. The fans on the card reach 3000 RPM and after exiting Far Cry 3, the GPU cools down by 10c in about 8 seconds and 20c in about 15-20 seconds. I think this cooler just can't dump the heat fast enough as it has a small vapor chamber and no heat pipes, but for some reason it has gotten even worse very recently. Can't RMA it now until I find the missing original screw that flew across the room somewhere, but considering I had to RMA my first brand new card 3 weeks after I bought it because a fan died, I think it's probably time for a big boy cooler.
EDIT: Found the screw. Luckily I heard it whack something on my floor behind me when it escaped. Next time I'll be more careful when using the eraser end of a pencil to initially thread and tighten the screws with the stickers on them. :)
6,762 (1.38/day)
Processor 7800x3d
Case ThermalTake P3
You will have to tell us how that artic works for ya
cadaveca
My name is Dave
17,232 (2.54/day)
I was told by XFX that the stickers are noob catchers.
Call 'em up, tell them of the problem, and that you want to re-paste. They should tell you that it's fine, but if you RMA, your card will go under much closer examination for physical damage than is normal. Any damage to the card immediately will disqualify your card for RMA.
They'll swap the card out for you too, although, really, those temps seem fine to me. :p When it starts crashing, or performance drops, then worry. :p
4,012 (0.72/day)
I bypassed the n00b catchers quite easily with needlenose pliers and an unused wooden pencil. Use the pliers on the sides of the screw to loosen it, and use the pencil eraser to push down and twist the screw into place, then finish up tightening with the pliers. No sticker damage done. :)
Even if the temperatures are normal, I got sick of the noise and the heat on this card when my 6950 was very quiet and cooler (and yes, I am aware of the power consumption differences). I'd like lower temperatures and the Accelero Xtreme 7970 that I ordered should bring me lower temps and a better OC hopefully. The only thing that is going to piss me off though is that damn 2 part thermal glue because I put some fet coolers on my AM2NF3-VSTA yesterday and they still haven't completely set nearly 24 hours later (I bought an Accelero L2 Plus for a GT 440 and didn't use the sinks until now).
6,762 (1.38/day)
Processor 7800x3d
Case ThermalTake P3
one thing to mention about the accellero. It dumps all that heat into your case and you will need a lot of exaughts. It made everything in my case run at the temp of the gpu. 60c.
Norton
Moderator - Returning from the Darkness
14,108 (2.99/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
You may not need the extra heatsinks and likely can reuse the factory VRM one if it is a decent quality. Try it without them first ;)
I had a Visiontek 5870 with a factory installed AC Twin Turbo Pro- it didn't have the extra sinks on it (only a small one on the VRM) and it always ran cool (flow from the fans over the board was plenty)
4,012 (0.72/day)
I'll be switching to my NZXT Source 210 with 3 120mm exhausts and 4 120mm intakes. My current Rosewill Challenger likely doesn't have enough room for the cooler and only has 4 usable fan areas anyway. I have some new 2000rpm 120mm fans (they are cheap though) and another fan controller arriving soon for them.
376 (0.08/day)
The city with the former druggie Mayor
System Name That computer
Processor Intel I7 960 OC @ 4GHz
Motherboard Gigabyte G.1 Guerilla
Cooling Corsair H80
Memory 12gb G.Skill DDR3 1333MHz
Video Card(s) Gigabyte Radeon 6950 2GB
Storage 120GB Samsung 840, 2x 1TB WD Black Raid 0
Display(s) 2X ACER S232HL
Case Thermaltake Amour A90
Audio Device(s) Asus Xonar DX
Power Supply 600W OCZ MODXSTREAM PRO
http://i.imgur.com/ilRHC.jpg
HAHA have the same cooler for a 580 and that thing is HUGE! It also took two people and alot of confusion to install that cooler, or maybe that's just me.
I got around 80 degrees c with the stock cooler but now I get 55 with the accellero
4,012 (0.72/day)
With that kind of length it's possible that I may have to use one of my HEC Blitz cases (since it has all 5.25" bays) but I'd rather avoid it and use my Source 210 if possible.
6,762 (1.38/day)
Processor 7800x3d
Case ThermalTake P3
Did you not read the length in the product description before buying? The thing is like 15 inches long if I remember correctly.
@n3rdfight3r
Took me 20 minutes, and 10 of that was me messing up putting the paste on. I just used the stock heatsinks and not the ones that came with it though. No confusion.
4,012 (0.72/day)
