HD tune Pro results for my laptop HDD ... need help
75 (0.02/day)
System Name AliveHunter
Processor AMD FX(tm)-6300 Six-Core Processor
Motherboard ASUS M5A97 R2.0
Cooling Cooler Master Hyper 212X
Memory G.Skill DDR3: F3-12800CL9-4GBXL [X2]
Video Card(s) ATI Radeon R9 270X, 2GB DDR5
Storage WD BLACK 2 TB + 1TB WD Portable USB3.0
Display(s) DELL S2240L
Case Cooler Master: K380 + 2 x 120mm Fan : Deepcool
Power Supply Antech VP550P V2
Software Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601)
15 days back I re-installed Win7 (fresh) on my laptop.. after 2 days of installation the Windows would get stuck / very very slow (not even able to open start menu). I thought some problem with the windows / System Drivers.
then I again re-installed fresh win7 .. but still the same issue...
I suspected the HDD so preformed the HD Tune test...
Following are the results for my Laptop HDD test @ HD Tune Pro 5.5 -
can someone help me out to understand this results and wht should i do next?
HD Tune Pro: ST500LM012 HN-M500MBB Error Scan
Scanned data : 498 gB
Damaged Blocks : 0.3 %
Elapsed Time : 2:10:44
1 Error at 41009 MB (LBA 83987106)
2 Error at 41016 MB (LBA 84002722)
3 Error at 41039 MB (LBA 84048930)
4 Error at 41045 MB (LBA 84061986)
5 Error at 41491 MB (LBA 84975368)
6 Error at 41514 MB (LBA 85020936)
7 Error at 67192 MB (LBA 137610682)
Error Scan snapshot attached
11,877 (1.73/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Run chkdisk on it with both boxes checked, reboot and do something else for awhile.
"Scan for and attempt recovery of bad sectors"
Also upload the report from the health tab, it should contain the smart data to see if the disk controler has picked up any faulty sectors, or if all the reserve sectors have been used.
Next make a backup.
7,351 (1.46/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
From my experience... don't bother, get a new drive as fast you can... I wouldn't dare to waste my time on a ticking time bomb.
392 (0.09/day)
Processor Ryzen 7 5800x @ 4,85Ghz
Motherboard AORUS MASTER X570
Cooling Costume External Water Loop 1080 Rad
Memory Patriot Viper Steel DDR4-3600 16GB @3800 mhz cl16
Video Card(s) RTX 3090 Water
Storage Raid0 4 x Sasmsung 850 EVo, 980 1TB M.2
Display(s) ASUS Swift
Case Open test bench
Power Supply Be quiet! 850 P10
Mouse G703
Keyboard Old USB Dell Keyboard x2
VR HMD Rift S
Once a HDD runs out of Free sectors to repair damged secorts it is only hill down from that point.
Replace your HDD Save your Files.
11,877 (1.73/day)
Motherboard Asus
Keyboard Razer
Software A lot.
Its not the bad clocks that concern me, its the fact they show up at all, the drive is supposed to correct for damaged blocks and all modern drives have reserve blocks to account for damage and failure, it just why its not doing it on its own, and if it has ran out there may be something causing surface damage to the drive which will kill it.
Kursah
Super Moderator
14,709 (2.25/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
Many don't know or realize, every HDD ever has bad sectors out of the chute. You're just not made aware of this. You are made aware of what is being reported, and usually by that time, you'll be running low on free sectors to move data/free space sectors to. Too many little moving parts that are more cheaply made than ever, cheaper media for the physical writing, we're living in an era where HDD's don't last 10 years+ anymore. I still have old SCSI and PATA and even SATA-1 drives that are still usable and show with a good rating. I've seen more HDD failures in the last 5 years than the 15 before it.
It should also be mentioned that smaller laptop HDD's are the most common failing component of a laptop. Small, usually not well ventilated so run warmer, more power cycles, more thrashing around and impacts, etc. If you could afford an SSD and backup media I'd run an SSD in your laptop, and run weekly backups.
:toast:
newtekie1
Semi-Retired Folder
28,473 (4.15/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Backup and replace the hard drive. They are so cheap, it isn't worth thinking twice about it once it starts to report bad sectors.
This might be a nice time to upgrade to an SSD.;)
75 (0.02/day)
Health Tab details uploaded from HD Tune Pro
75 (0.02/day)
