HDD only works after I replug it
18 (0.02/day)
Processor Intel Core I5 4460
Motherboard ECS H81H3-M4
Cooling Stock cooler
Memory Muhskin 8Gb
Video Card(s) XFX RX 470 Triple X
Storage Toshiba 1Tb
Case Zalman T6
Power Supply Cooler Master MWE White 500W
after a power outage HDD doesn't turning on and making sound like the head inside it turning right and left 2x and then spin up a bit and spin down for more than 3 times, I tried to replug the SATA and power connector and it did the same spin up and down sound but this time I was able to use OS. and if I shutdown the comp and start HDD does the same spin up & down sound 7~8 times then it just shuts off but comp stays on. is it a hdd problem or motherboard? should I replace it? adobe photoshop files are corrupted too, it doesn't run just stays at crashes at loader screen.
3,127 (2.38/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
There is no conceivable way I would ever trust that HDD to function reliably and correctly even if I could get it to spin up and read data.
I'd replace it and put that computer on a UPS.
18 (0.02/day)
Memory Muhskin 8Gb
Storage Toshiba 1Tb
Case Zalman T6
got it, UPS is not possible for me nowadays but thanks for advice
3,127 (2.38/day)
Your data, your call, your headache. If you had a UPS, you probably would not have made this post.
You are welcome for the advice, that's what you asked for.
No one here is going to tell you that you should expect many years of error-free and reliable service from that HDD.
18 (0.02/day)
Memory Muhskin 8Gb
Storage Toshiba 1Tb
Case Zalman T6
Today I tried it with another hdd and it did the same sound, now its definitely not only the hdd
1,875 (0.32/day)
UK Warwickshire
System Name PC-Chips
Processor AMD Ryzen 7 5700x3D
Motherboard Asus ROG Strix B550-F Gaming.
Cooling White arctic liquid freezer iii 360 a-rgb AIO.
Memory Patriot Viper 32gig dual channel 3600mhz
Video Card(s) PowerColor HellHound RX 7900 GRE OC.
Storage 2 Samsung 860 EVO's 500gig / 2TB crucial P3-NVME / WD-BLUE SN550 1TB M.2 / SP A55 512gig / 8TB HDD
Display(s) TCL 50-inch 4k TV freesync HDR
Case White NZXT H9 Flow Dual-Chamber
Audio Device(s) Realtek S1220A - Yamaha A-S501 AMP - Wharfedale diamond 9.1 speakers - Wharfedale SW150 sub
Power Supply EVGA SuperNOVA G6 750W 80+ Gold
Mouse Some cheap wireless thing
Keyboard Razer Cynosa lite
VR HMD Oculus Quest 2 128gig version
Software Windows 11 pro 64bit
Try a different sata cable and power connector if not done so already.
18 (0.02/day)
Memory Muhskin 8Gb
Storage Toshiba 1Tb
Case Zalman T6
I dont have spare sata cable, I tried to use the power connector from other cable coming from psu but it didn't work, I also tried different sata port
it is so strange it works good after I completely turn off the comp and disconnect all the cables then hold power button 15 seconds and after firing it up hdd does some spin up and down while booting windows and after around 5~10 minutes it just works normally without any strange sound
955 (0.52/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
Have you tried and see the SMART results? Can you sahre with us?
437 (0.24/day)
Panama City Beach, Florida
System Name EventHorizon
Processor Intel® Core™ Processor i9-13900KF 8P/16 + 16E 3.00GHz [Turbo 5.7GHz] 36MB Cache LGA1700
Motherboard ASUS PRIME Z790-P
Cooling CyberpowerPC MasterLiquid Lite 240mm ARGB CPU Liquid Cooler
Memory 32GB (16GBx2) DDR5/6000MHz Dual Channel Memory (KINGSTON FURY BEAST RGB)
Video Card(s) GeForce RTX™ 4080 16GB
Storage 2TB WD BLACK SN850X (PCIe Gen4) NVMe M.2 SSD - Seq R/W: Up to 7300/6600 MB/s, Rnd R/W up to 1200/110
Display(s) LG 34''
Case CyberPowerPC HYTE Y60 Dual Chamber Mid-Tower Gaming Case w/ Panoramic View Tempered Glass + 2x120mm
Audio Device(s) Asus Strix w/Alan Finote mod for Windows 11
Power Supply High Power 1300W 80+ GOLD Full Modular w/ PCIE 12+4Pins Connector for PCIe 5.0 graphics cards
Mouse Steelseries Rival 600 wired
Keyboard Steelseries Apex 7 TKL red Switch
Software Win 11 Pro
18 (0.02/day)
Memory Muhskin 8Gb
Storage Toshiba 1Tb
Case Zalman T6
9,340 (5.18/day)
Louisiana
Keyboard G710+x3
Restoring a system image on the hdd would be the first thing I'd try or if you have a clone or files on a backup hdd just replace the corrupted files but this would take a lot of time.
System imaging is free and easy now days but another hdd is needed to hold it obviously so there is some additional costs but back up is mandatory if you care about your data that is.
AsRock
TPU addict
19,150 (2.98/day)
UK\USA
Sure UPS i get it but backups is what sounds like the issue well that a long with trusting ANY kind of storage devices.
Always make backups, and if the data is worth it find some one who can restore the data from it.
18 (0.02/day)
Memory Muhskin 8Gb
Storage Toshiba 1Tb
Case Zalman T6
I dont have any data worth backup except the edits and I already keeping them in cloud
9,340 (5.18/day)
Louisiana
Keyboard G710+x3
Cloud will work to transfer speed is usually crap
I don't use it for anything I care about since I have local backups.
18 (0.02/day)
Memory Muhskin 8Gb
Storage Toshiba 1Tb
Case Zalman T6
Since my files aren't very large, the transfer speed didn't matter to me
5,248 (3.73/day)
Colorado, U.S.A.
Software Windows 11 Home
How about a good surge protector?
Makes me wonder about the power supply
2,963 (0.82/day)
Long Island
One of these with a spare storage device is a cheap answer to data security. They are also great when storage devices malfunction ... for whatever reason I have been able to recover malfunctiong storage devices when connected to one of these , when having already failed when connected o SATA.
Every storage device can fail ....
Things sitting on shelf in my office as a reminder ....
SSHD 1 ..... died after 9.5 years
SSHD 2... died after 1 week, replaced under warranty
SSD 1 .....died after 3.5 years
SSD 2 ... died after2,5 years, replaced under warranty
SSD 3 .... warranty replacement for above ... died after little over a year
Have other piled there, but they were mostly retired as machines were upgraded.
Avoid a sense of complacency after buying big box store surge protector. If your wallet didn't feel a bit of a pinch, it will when the thing craps out
5,248 (3.73/day)
Colorado, U.S.A.
2,373 (0.57/day)
Audio Device(s) A LOT
1,755 (1.16/day)
Having to repeatedly plug and unplug a HDD to get it to work was one of the problems I had with my Toshiba HDD that recently died. I'd vote to replace it or at least make sure I have regular backups of everything important on the HDD in question
18 (0.02/day)
Memory Muhskin 8Gb
Storage Toshiba 1Tb
Case Zalman T6
This. Do you have another system/PSU you can use to double check?
it was the psu, now I am using the pc with my old psu
