HDR Not supported - But my monitor does support it
2,690 (0.40/day)
Republic Of Ireland
System Name The Metadis
Motherboard Asrock B650 RS Pro
Cooling MSI MAG CoreLiquid 360R V2
Memory 32GB G-Skill Trident Z5 Neo 6000mhz CL32
Video Card(s) Asus Tuf RX 7900XTX OC 24GB
Storage Crucial P5 Plus 2TB Gen4 nvme + Sabrent Rocket Pro 500GB Nvme Gen3
Display(s) LG C2 42" 4K 120hz OLED
Case NZXT H6 Flow
Audio Device(s) Hifiman Edition XS - Ifi Zen DAC V2 - Topping D90 discrete
Power Supply Seasonic G12 GM - 850W 80 Plus Gold
Mouse Razer DeathAdder Essential (6400 DPI Optical Sensor)
Keyboard AULA F2088 Typewriter Style Mechanical Gaming Keyboard Blue Switch - Retro Punk Round Keycaps
VR HMD Meta Quest 3
Software Windows 11 64-bit
Hi guys,
I am having an issue with turning on HDR from windows display settings.
I have recently just upgraded to Windows 11 and have noticed that HDR is completely greyed out and it just says that it isn't supported but it is! It worked on Windows 10 just fine.
Does anyone have any suggestions as to what to do to sort this out?
FreedomEclipse
~Technological Technocrat~
24,310 (3.75/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Make/model of monitor?
and have you tried installing any sort of drivers related to said make and model of monitor?
If not it could be just a w11 problem
2,690 (0.40/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
32" UltraGear GP850 1440p 180Hz IPS-NANO.
I updated to the latest Radeon drivers but that didn't fix it. I Guess maybe it is a windows 11 issue I would say.. pity.
1,188 (0.27/day)
Denmark
Processor R9 5950x/i5 6400
Video Card(s) 7900XTX/6900XT
Case Custom builds
Audio Device(s) -
Do you have a second monitor enabled? HDR isnt possible in Eyefinity setups but dont know about dual screen setups
310 (0.06/day)
System Name Uzuki Toune
Processor AMD RYZEN 7 7700X (ASUS PBO 90C Mode)
Motherboard Asus ROG Strix X670E-E Gaming WIFI
Cooling Thermalright Frostspirit 140 White V3 ARGB
Memory 32GB DDR6000 CL36 Kingston (EXPO)(16GBx2)
Video Card(s) Zotac GTX 1050TI
Storage 2TB Kingston KC3000 + 1TB Crucial P2 + 480GB Samsung Evo 850 + 480GB Kingston A400
Display(s) Dell U2723QE + Philips 221V8 (Portrait)
Case NZXT H510
Audio Device(s) Auzen X-FI Forte + Onboard Realtek 4080 -> Creative Gigaworks T40II
Power Supply EVGA G+ 650W
Mouse Logitech MX Master 3 (Work) & G103 (Play)
Keyboard iRocks K71M
HDR works fine on multi screen setups. Although in my case I have one HDR and one non HDR display in extended configuration, and I can enable HDR for that one monitor just fine. I'm on Windows 10 though.
2,690 (0.40/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
I have just the 1 monitor is all
9,340 (5.21/day)
Louisiana
Keyboard G710+x3
Use the actual monitor settings buttons to see if you can turn on hdr
I personally disable it, hell all it does is the same thing as gaming mode does it just exaggerates colors.
2,690 (0.40/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
I tried that but there isn't any option to turn it on. It just shows OFF. It shows me what is active and it shows 180 hz, Freesync response time and motion blur reduction.
Sadly no option to turn it on or off!
I checked reviews and it does show that HDR has a slight improvement with this monitor but nothing special or mind blowing. But it's enough for me to want to give it a shot and see for myself!
averyk
2 (0.00/day)
Okay, for those still searching for a method to implement hdr on the 6000 series gpu I figured it out after hours of trying and finding nothing.
Done everything down to switching to pro drivers...it worked then disappeared.
So, it seems it was unnecessary to change drivers now.
The one thing that worked...and it will sound stupid, turn OFF 10-Bit Pixel Format.
Vuala...that is all and I want to . Hours for that.
Also, just enable 10 bit color by using 10bpc
2,690 (0.40/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
Is that right :eek:..... I will try that out tonight so! Hopefully it finally works! Thank you.
  • Like
Reactions: Lei
averyk
2 (0.00/day)
It does. Afterwards I googled the 10-bit pixel format and it seems that I could easily find the answer from that, but not from googling the problem‍
