HDTV Tuner for my computer
2,686 (0.42/day)
Republic Of Ireland
System Name The Metadis
Motherboard Asrock B650 RS Pro
Cooling MSI MAG CoreLiquid 360R V2
Memory 32GB G-Skill Trident Z5 Neo 6000mhz CL32
Video Card(s) Asus Tuf RX 7900XTX OC 24GB
Storage Crucial P5 Plus 2TB Gen4 nvme + Sabrent Rocket Pro 500GB Nvme Gen3
Display(s) LG C2 42" 4K 120hz OLED
Case NZXT H6 Flow
Audio Device(s) Hifiman Edition XS - Ifi Zen DAC V2 - Topping D90 discrete
Power Supply Seasonic G12 GM - 850W 80 Plus Gold
Mouse Corsair M65 ELITE RGB Optical FPS Gaming Mouse (18000 DPI Optical Sensor)
Keyboard Redragon K648 90% Wired Aluminium Mechanical - Rock-Solid Metal Board Built-in Noise Absorbing Foams
VR HMD Meta Quest 3
Software Windows 11 64-bit
Hey lads.
I am interested in buying a HDTV tuner for my desktop.
But I know nothing about how this is done!
I am looking for a USB stick as I do not have a PCI-E slot or PCI slot available.
I was checking out these here:
http://www.hdtvtunerinfo.com/comparetuners.html
But...is it complicated?? Do I just..plug it in and there! HDTV???
Cheers lads!
Phxprovost
Xtreme Refugee
1,217 (0.22/day)
Pennsylvania
System Name Result of Boredom
Processor AMD FX-6350
Motherboard ASUS M5A97
Cooling Enzo Tech Extreme-X
Memory 16gb ddr3
Video Card(s) XFX R9 290
Display(s) Asus 24in (1920X1080) X 2 @144hz
Case NZXT S340
Software WIN7 64bit HP
im pretty sure they dont work anymore because of content providers encrypting the signal...though i could be wrong
2,686 (0.42/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
Ah jayziz then what's the point of selling them?
716 (0.13/day)
C:\Kitteh
Processor i7 2600K | Phenom II 840
Motherboard ASUS P8Z68 Deluxe | ASUS M4A88T-M
Cooling Corsair H60 | Scythe Samurai ZZ
Memory 4x4GB Samsung Green 1600 @ 1866 | 2x2GB Corsair XMS3 1333
Video Card(s) Evga GTX 670 FTW | On Board AMD
Storage 2 x 64GB Samsung 830, Velociraptor 300GB,1TB Black,1.5TB Black |10TB server
Display(s) HP 2509m 25" 1080p
Case Lian Li PC-V1020A | Lian Li PC-V354A
Audio Device(s) Azuntech Bravuria 7.1 | On-Board (Disabled)
Power Supply Seasonic X-series 760 , Seasonic X-series 760
Software Windows 7 Ultimate X64 | UnRaid (CentOS)
He's right. I just researched the whole lot for my own setup. I ended up buying a TiVo HD.
Your options are a Tivo (or similar)
Or a Cable Card adapter for your PC, then renting a cable card form your service provider. (Quite expensive for the adapter)
2,686 (0.42/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
argh!!! forget it!
sneekypeet
Retired Super Moderator
29,423 (4.41/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
How do you recieve the signal into the house?
See here we get like 70 channels through a coax that are unscrambled. To get pay channels it requires a converter box.
If you can just run the cable to the TV and get a signal, the same can be done on a PC.
If a converter box is a must, its is sort of fail at that point.
MohawkAngel
1,864 (0.33/day)
HAUPPAUGE are better than Asus on tv tuner card. Look for Hauppauge website and choose the card you want...simple website all specs are there and they do all updates often. I update drivers 3 times since i bougt it 3 months ago. Believe me their quality and service are amazing.
HDTV you will be lucky.
With my normal model 1250 i can receive antenna signal, over the air signal, cable coax sighnal, unscrambled for box signal....hdtv will be amazing ! They even included a power signal bar indicator in their programs.
TheCrow
398 (0.06/day)
Lincoln, UK
Processor Intel i7-930 @ 4.oghz
Motherboard Asus Rampage Gene III Extreme
Cooling Noctua NHU12F
Memory 6GB Kingston HyperX @ 1600mhz
Video Card(s) Gigabyte GTX560TI OC
Storage OCZ Agility 3 90GB SSD, 4x Seagate 500GB
Display(s) Acer 22" Widescreen LCD
Case Thermaltake Soprano VB1000BWS
Audio Device(s) Onboard XFI
Power Supply Corsair CX600V2
Software Windows Se7en 64 Extreme Edition
I noticed you in ireland which means either Virgin Cable, Sky Satellite or Freeview.
As freeview aint HD that cancels that out.
Virgin cable do carry a few HD channels, but the only way your gonna get them is with a box from them, they don't make anything for the pc and wont.
That leave's you with satellite.
I just purchased a compro Videomate s350 which i've been using to watch bbc HD & ITV HD, it works great. Although you will need to fit a dish, etc. There are usb satellite recievers available.
But for just 2 channels its not really worth spending a fortune.
2,686 (0.42/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
Ahh well.. I don't want to spend lots of cash just for TV.
I think I will stick to using Readon Player :(
Thing is... I kinda figured all I would need... is some kind of USB connection and maybe a small little box. But I guess that is asking too much!
There really is no simple solution is there?? :(
2,686 (0.42/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
Will this work properly for me?? if so I should get this :D
TheCrow
398 (0.06/day)
Lincoln, UK
It will work fine, except nothing is broadcast in HD to us yet except sky over satellite. So all you will recieve is normal SD channels.
Plus the people who are deciding how are HD will be broadcast haven't decided on what format, so you could be spending all that cash and it will never work.
I would just stick to SD for now mate, the Uk & Ireland have a long way to go before we need to start looking for HD stuff. Christ I cant pick up channel five still and I have an aerial the size of a rocket ship!
10,881 (1.60/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
In the US, almost all OTA (over the air) channels have been broadcasting in HD for years, along with a simultaneous SD signal for older TV's. Now the SD part is being broadcast in digital, and the HD is still there.
So my point is if you recieve OTA HD stations all you need is a tuner. I don't pretend to know what broadcasting is like in Ireland, though!
926 (0.16/day)
Akron, OH
System Name Main Rig
Processor Athlon 5350
Motherboard AsRock mITX
Memory 4gb
Storage 120gb Kingston HyperX SSD
Display(s) Samsung Syncmaster 740N
Power Supply Corsair 430 watt
Right, here it in the States it works great--you jam a PCI or USB HDTV tuner in your PC, connect an antenna to it, and you get beautiful HDTV. You use the Media Center features of Vista Home Premium or Win 7 Home Premium to record and playback everything. Really simple stuff. Unfortunately, I don't know if there are any HDTV broadcasts in Ireland.
vbx
720 (0.13/day)
Processor E8500 Core 2 Duo
Motherboard ASUS P5Q-EM
Cooling Cooler Master Hyper Z600
Memory Gskill 4gb DDR2 1066
Video Card(s) HIS 4670
Storage WD 320gb black
Display(s) Asus MS226H 21.5 monitor
Case Antec P180 Mini
Power Supply Antec NEO ECO 620C
Software Windows 7 x64
I have time warner cable. No HD broadcasting on my line. But there are some HD channels available on the TV hooked up to the set top box. Most of them are blocked out and you need to "Pay" for them.
Basically, in order for me to get HD channels, I have to hook up the set top box to my computer. I don't believe HD channels are avaiable thru the antenna. Yes, its DIGITAL, but it's not HD.
I think HD channels have the HD logo or wording somewhere on that channel.
2,686 (0.42/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
Jayziz!
I just don't see myself buying a tuner for ancient SD channels!!
I want HD dammit!!
I do want to just buy it...but I think I would be disappointed with the results :p
If I was to go ahead and get a tuner... How many SD channels am I expected to get??
10,881 (1.60/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Do you have a TV with antenna in your house? What you get on that will tell about SD stations.
The history of broadcast OTA channels starts back in 1941 when NTSC broadcast format was introduced. Virtually all analog TV's have an NTSC tuner built in for SD signals.
Enter the digital world. Now ATSC is the standard for OTA digital signals. This includes both SD digital and HD digital. If a monitor is listed as HDTV, it MUST have an ATSC tuner in it.
Go one step further with cable, and there is the QAM tuner, that allows viewing of unencrypted QAM signals that many cable carriers have (and don't really tell you about). I get about 10-20 QAM channels on my 40" sony LCD, with about 8 or so being 720p or 1080i
So look for a tuner that supports NTSC, ATSC and QAM.
2,686 (0.42/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
I have a Samsung HDTV with 1080p support.
No idea about ATSC or anything to that effect!
At this rate there seems so much to do for some SD channels!
I really don't think it's worth it right now :p
