[Help] Asus Z87-PRO USB BIOS Flashing method doesn't not work!
47 (0.03/day)
System Name My PC Master Race
Processor AMD Ryzen 5 5600X
Motherboard AsRock B550M PG Riptide
Cooling Thermalright U120EX REV.4 BLACK
Memory G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16
Video Card(s) Asus ROG STRIX RX480 8GB GAMING OC
Storage 1: MSI Spatium M450 500GB 2: SK Hynix Gold S31 500GB; 3: Seagate Barracuda 2TB
Display(s) ViewSonic VX2263 22" IPS Full HD
Case BitFenix Nova Mesh M ARGB
Audio Device(s) Logitech Z213 2.1 Stereo Speakers
Power Supply Thermaltake 850W GF1 80+ Gold
Mouse Razer Basilisk v2
Keyboard Razer Huntsman Tournament Edition
Software Atlas OS v0.4.1 (24H2)
Hello everyone
As the tittle says i'm having trouble trying to update the bios of my motherboard...
Recently i bough a new motherboard the Asus Z87 PRO for replace my old one but when i installed i notice that the system don't boot or give me video any image to the monitor, saying "No signal found" also the board CPU LED it's on with the red light and the QCode is 00.
I don't know wich is the actual BIOS version from the factory but i think is and old because don't reconiced my i7-4790.. I also try flashing the BIOS using this method but the green light don't start to blink just keep remains on and if i press the button for a more than 5 sec it's start to blink but stop when i leave the push.
Please help me!
My PC specs are:
CPU: Intel Core i7-4790 @ 3.60GHz
Ram: Patriot Viper III 16GB DDR3 1600Mhz
GPU: Asus ROG STRIX RX 480 8GB GAMING
PSU: EVGA 600BQ 80+ Bronze
Mth: Asus Z87-PRO
SSD: SK Hynix Gold S31 500GB
Hdd: 500GB WD Blue Caviar 7,2 Rpm
https://valid.x86.fr/m73qvb
42 (0.02/day)
Processor Intel® Core™ i5-6600K
Motherboard ASUS MAXIMUS VIII RANGER
Cooling Arctic Freezer 34 eSports DUO
Memory 16GB KINGSTON HyperX SAVAGE 3000MHz
Video Card(s) GIGABYTE GTX 970 G1 Gaming
Storage Samsung 850 EVO
Display(s) Dell 24 Inch
Case ABKONCORE CRONOS 710S
Audio Device(s) Onboard Realtek ALC1150/ASUS SupremeFX
Power Supply Corsair RM850x 850W V2
Software Windows 10 PRO x64
Download latest BIOS Version 2103, extract and rename it to Z87P.CAP
Copy bios to the USB flash drive and put that USB flash to this USB port
Then press USB BIOS FLASCHBACK button for three seconds, and the BIOS is updated automatically
47 (0.03/day)
I already do it don't work... the green light don't start to blink
42 (0.02/day)
Do you have another usb flash drive, are you formated usb to the FAT32?
47 (0.03/day)
Yes i only have 1 USB 2.0 is an Kingston DT101 G2 8GB in FAT32
42 (0.02/day)
47 (0.03/day)
Done! I go to upload the video doing the flashing step by step!
42 (0.02/day)
Try extract BIOS and only rename to Z87P without CAP, file name extensions might be hidden.
Then copy to the USB flash drive and try.
47 (0.03/day)
42 (0.02/day)
You should try with another USB flash drive.
14,286 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
00 usually means dead with Asus Motherboards.
Was it bought second hand and used?
47 (0.03/day)
[update]
I started the motherboard with a G3220 and it's run perfectly, the motherboard it's ok no problem, and i noticed that the factory bios was v1405 and i update it to the latest version v2103
But ... the problem persist, either having updated the BIOS my motherboard don't recognize i7-4790 the same don't initialize ... if you try to tell me the cpu is the problem don't do it ... i tested the CPU in another motherboard and its works perfectly ...
42 (0.02/day)
You have one RAM stick in DIMM_A1, try put that stick in the DIMM_A2 slot.
And after that try CLEAR CMOS:
1,223 (0.65/day)
Loose in space
System Name "The black one in the dining room" / "The Latest One"
Processor Intel Xeon E5 2699 V4 22c/44t / i9 14900K @5.8GHz
Motherboard Asus X99 Deluxe / ASRock Z790 Taichi
Cooling Arctic Liquid Freezer II 240 w/4 Silverstone FM121 fans / Arctic LF II 280 w Silverstone FHP141's
Memory 64GB G.Skill Ripjaws V DDR4 2400 (8x8) / 96GB G.Skill Trident Z5 DDR5 6800
Video Card(s) EVGA RTX 1080 Ti FTW3 / Asus Tuff OC 4090 24GB
Storage Samsung 970 Evo Plus, 1TB Samsung 860, 4 Western Digital 2TB / 2TB Solidigm P44 Pro & more.
Display(s) 43" Samsung 8000 series 4K / 65" Hisense U8N 4K
Case Modded Corsair Carbide 500R / Modded Corsair Graphite 780 T
Audio Device(s) Asus Xonar Essence STX/ Asus Xonar Essence STX II
Mouse Logitech Performance MX, Microsoft Intellimouse Explorer 3.0
Keyboard Logitech K750 Solar, Logitech K800
Software Win 10 Enterprise LTSC 2021 IoT / Win 11 Enterprise IoT LTSC 24H2
Benchmark Scores https://www.passmark.com/baselines/V11/display.php?id=202122048229
Since it does power up I'd try replacing the BIOS chip. I just looked on Ebay and they're $11-14. It's at least worth a try if you want to save that mobo.
42 (0.02/day)
It power up with Intel Pentium Processor G3220, but won't with I7-4790.
47 (0.03/day)
[Update #2]
I fixed the problem
1) I Started the motherboard with a compatible CPU, with a clean Windows Installation and of course with the old BIOS version v1405.
2) Installed the Intel Management Engine interface v9.0.0.1323 (is obligatory this version or the ASUS Bios Update Utility don't go to work either with a lower o newer version is exactly the IME programmed to run)
3) Started the BIOS updater for New 4th Gen Intel Core Processors selecting the current BIOS version and update it!
4) Finally! the motherboard recognize the i7-4790
this is the only way to run the motherboard and similar series of ASUS with +4th generation of Intel Processors no matter what you do this is the proper method
schwally4
1 (0.00/day)
[Update #2]
I fixed the problem
I sent you a message also. Where did you find the Intel Management Engine interface v9.0.0.1323 download? Thanks
