Help! best color for gaming!!! YCBCr444 8bpc vs YCBCr442 12bpc Vs RGB 12bpc
156 (0.04/day)
System Name 2022 PC / 2020 PC
Processor Ryzen7 7700X / Ryzen7 5800X
Motherboard ROG X670e EXTREME / ROG Crosshair VIII Hero
Cooling Rog Ryujinn II ARGB / Capellix H100i
Memory F5-6000J3636F16GX2-TZ5NR X2 / Trident z Royal 3200Mhz Cl14
Video Card(s) Zotac AMP Triniti RTX 4090 /EVGA FTW3 ULTRA 3080
Storage Kingston 2TB Fury Renegade / Aorus PCIE4 1TB
Display(s) S95B / S95C
Case anidees AI Crystal PC / Infiniti 2
Power Supply Thermaltake Toughpower GF 3 1000W / TT Toughpower GF1 ARGB 850w
Mouse Razer Basilisk V3
Keyboard Asus Animate ii/ Corsair KG100
Software windows 11 X2
I have a 75 inch 4k TV with HDR! i have a question for gaming..
First of all I know the best is YCBCr444 at 12bpc but it is NOT supported at 60Hz
so my question regarding games is this one:
Which mode offers the best vivid colors for gaming?
1:) YCBCr4:4:4 at 8bpc at 60hz?
2:) YCBCr4:4:2 at 12bpc at 60hz?
3:) RGB at 12 bpc at full spectrum, at 6ohz?
Thank you and i value your input
12,314 (2.28/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
I'm not sure but I think anyone that may know might want to know the make and model
9,404 (3.29/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
As you said 4:4:4 is the best , even in 8bit. All other modes will either crush the blacks or make the colors look off.
I'd say full range RGB is probably the second best bet.
2,929 (0.51/day)
Riverside, California
Motherboard AsRock X670E Phantom Gaming Lightning
Cooling Be Quiet! Dark Rock 4
Memory G.SKILL Trident Z5 Neo DDR5-6000 32GB (2 x 16GB)
Video Card(s) Sapphire Radeon RX 7900 XTX
Storage Samsung 980 PRO Series 1TB, Samsung 980 PRO Series 1TB, Crucial P3 NVMe M.2 2TB
Display(s) LG OLED55G2PUA
Case Lian Li O11 Dynamic XL ROG Certified
Audio Device(s) Digital out to high end dac and amps.
Power Supply EVGA GQ 1000W
Mouse Logitech G600
Keyboard Logitech G413 Carbon
VR HMD Oculus Rift CV1, Oculus Rift S, Quest 2, Quest 3
RGB and 4:4:4 for sure.
Both look very good with my HDR TV and work equally well for gaming.
You know you can just swap back and forth and use your eyes though? lol
370 (0.10/day)
System Name hp OMEN X 900-000NX
Processor Intel Core i7-6700K
Motherboard hp Munich-S Z170
Cooling Asetek liquid cooling
Memory 32 GB DDR4-2133 Hynix
Video Card(s) hp GTX1080 Founders
Storage 256GB M2 Samsung (system)+ 1GB SSD WD BLUE edition GAMING(2x500 RAID 0 config)+2TB SATA (storage)
Display(s) LG TV 43 UJ670V active HDR
Case hp OMEN desktop X 900
Audio Device(s) ASUS XONAR DSX (Active) ,SBZ (inactive), onboard Realtek ALC1150
Power Supply hp 600W
Mouse Logitech G620
Keyboard SteelSeries hp OMEN
Software Windows10 64bit hp OMEN edition
YCBCr4:4:2 10 bpc , windows use HDR10 so forcing 12 is overkill as it will be downsized to 10 ...so for HDR under current windows condition YCBCr4:4:2 10 bpc
22,341 (6.03/day)
4:4:4 8bpc unless you have content that requires higher bpc. Simple enough
or Full Range RGB
Regeneration
NGOHQ.COM
3,122 (0.45/day)
Full RGB suppose to be the most authentic for source. Each TV reacts differently to color spaces, just try them all and pick the one you like the most.
