Morgoth
Fueled by Sapphire
- Aug 4, 2007
- 4,234 (0.69/day)
- Netherlands
System Name | Wopr "War Operation Plan Response" |
Processor | 5900x ryzen 9 12 cores 24 threads |
Motherboard | aorus x570 pro |
Cooling | air (GPU Liquid graphene) rad outside case mounted 120mm 68mm thick |
Memory | kingston 32gb ddr4 3200mhz ecc 2x16gb |
Video Card(s) | sapphire RX 6950 xt Nitro+ 16gb |
Storage | 300gb hdd OS backup. Crucial 500gb ssd OS. 6tb raid 1 hdd. 1.8tb pci-e nytro warp drive LSI |
Display(s) | AOC display 1080p |
Case | SilverStone SST-CS380 V2 |
Audio Device(s) | Onboard |
Power Supply | Corsair 850MX watt |
Mouse | corsair gaming mouse |
Keyboard | Microsoft brand |
Software | Windows 10 pro 64bit, Luxion Keyshot 7, fusion 360, steam |
Benchmark Scores | timespy 19 104 |
so when i set ACHi to RAID there are no drives dettected... and when i try the UEFI raid it says turn off CSM support then RAIDXpert 2 configuration should be visible under settings in bios
wel i tryed that to but the RAIDXpet 2 configuration doest show up at all...
i tryd to install drivers from the website of the mainboard manufacturer but they dont seem to be working :/
so the filles unpack with a strange format no .exe in them. or it says this OS is not supported :/
i also updated the bios to the lates version that doest help either
